RTEMS 6.1-rc1
stm32h7xx_hal_rtc_ex.c File Reference
Extended RTC HAL module driver. This file provides firmware functions to manage the following functionalities of the Real Time Clock (RTC) Extended peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • RTC Time Stamp functions
  • RTC Tamper functions
  • RTC Wake-up functions
  • Extended Control functions
  • Extended RTC features functions
Attention
                ##### How to use this driver #####
  (+) Enable the RTC domain access.
  (+) Configure the RTC Prescaler (Asynchronous and Synchronous) and RTC hour
      format using the HAL_RTC_Init() function.
*** RTC Wakeup configuration ***
  (+) To configure the RTC Wakeup Clock source and Counter use the HAL_RTCEx_SetWakeUpTimer()
      function. You can also configure the RTC Wakeup timer with interrupt mode
      using the HAL_RTCEx_SetWakeUpTimer_IT() function.
  (+) To read the RTC WakeUp Counter register, use the HAL_RTCEx_GetWakeUpTimer()
      function.
*** Outputs configuration ***
[..]  The RTC has 2 different outputs:
  (+) RTC_ALARM: this output is used to manage the RTC Alarm A, Alarm B
      and WaKeUp signals.
      To output the selected RTC signal, use the HAL_RTC_Init() function.
  (+) RTC_CALIB: this output is 512Hz signal or 1Hz.
      To enable the RTC_CALIB, use the HAL_RTCEx_SetCalibrationOutPut() function.
  (+) Two pins can be used as RTC_ALARM or RTC_CALIB (PC13, PB2) managed on
      the RTC_OR register.
  (+) When the RTC_CALIB or RTC_ALARM output is selected, the RTC_OUT pin is
      automatically configured in output alternate function.
*** Smooth digital Calibration configuration ***
  (+) Configure the RTC Original Digital Calibration Value and the corresponding
      calibration cycle period (32s,16s and 8s) using the HAL_RTCEx_SetSmoothCalib()
      function.
*** TimeStamp configuration ***
  (+) Enable the RTC TimeStamp using the HAL_RTCEx_SetTimeStamp() function.
      You can also configure the RTC TimeStamp with interrupt mode using the
      HAL_RTCEx_SetTimeStamp_IT() function.
  (+) To read the RTC TimeStamp Time and Date register, use the HAL_RTCEx_GetTimeStamp()
      function.
*** Internal TimeStamp configuration ***
  (+) Enable the RTC internal TimeStamp using the HAL_RTCEx_SetInternalTimeStamp() function.
      User has to check internal timestamp occurrence using __HAL_RTC_INTERNAL_TIMESTAMP_GET_FLAG.
      function.
*** Tamper configuration ***
  (+) Enable the RTC Tamper and configure the Tamper filter count, trigger Edge
      or Level according to the Tamper filter (if equal to 0 Edge else Level)
      value, sampling frequency, NoErase, MaskFlag,  precharge or discharge and
      Pull-UP using the HAL_RTCEx_SetTamper() function. You can configure RTC Tamper
      with interrupt mode using HAL_RTCEx_SetTamper_IT() function.
  (+) The default configuration of the Tamper erases the backup registers. To avoid
      erase, enable the NoErase field on the RTC_TAMPCR register.
*** Backup Data Registers configuration ***
  (+) To write to the RTC Backup Data registers, use the HAL_RTCEx_BKUPWrite()
      function.
  (+) To read the RTC Backup Data registers, use the HAL_RTCEx_BKUPRead()
      function.
