RTEMS 6.1-rc1
RNG HAL module driver. This file provides firmware functions to manage the following functionalities of the Random Number Generator (RNG) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The RNG HAL driver can be used as follows: (#) Enable the RNG controller clock using __HAL_RCC_RNG_CLK_ENABLE() macro in HAL_RNG_MspInit(). (#) Activate the RNG peripheral using HAL_RNG_Init() function. (#) Wait until the 32 bit Random Number Generator contains a valid random data using (polling/interrupt) mode. (#) Get the 32 bit random number using HAL_RNG_GenerateRandomNumber() function. ##### Callback registration ##### ================================== [..] The compilation define USE_HAL_RNG_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. [..] Use Function HAL_RNG_RegisterCallback() to register a user callback. Function HAL_RNG_RegisterCallback() allows to register following callbacks: (+) ErrorCallback : RNG Error Callback. (+) MspInitCallback : RNG MspInit. (+) MspDeInitCallback : RNG MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function HAL_RNG_UnRegisterCallback() to reset a callback to the default weak (surcharged) function. HAL_RNG_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) ErrorCallback : RNG Error Callback. (+) MspInitCallback : RNG MspInit. (+) MspDeInitCallback : RNG MspDeInit. [..] For specific callback ReadyDataCallback, use dedicated register callbacks: respectively HAL_RNG_RegisterReadyDataCallback() , HAL_RNG_UnRegisterReadyDataCallback(). [..] By default, after the HAL_RNG_Init() and when the state is HAL_RNG_STATE_RESET all callbacks are set to the corresponding weak (surcharged) functions: example HAL_RNG_ErrorCallback(). Exception done for MspInit and MspDeInit functions that are respectively reset to the legacy weak (surcharged) functions in the HAL_RNG_Init() and HAL_RNG_DeInit() only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_RNG_Init() and HAL_RNG_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in HAL_RNG_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_RNG_STATE_READY or HAL_RNG_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_RNG_RegisterCallback() before calling HAL_RNG_DeInit() or HAL_RNG_Init() function. [..] When The compilation define USE_HAL_RNG_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and weak (surcharged) callbacks are used.
