RTEMS 6.1-rc1
stm32h7xx_hal_ramecc.c File Reference
RAMECC HAL module driver. This file provides firmware functions to manage the following functionalities of the RAM ECC monitoring (RAMECC) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • Monitoring operation functions
  • Error information functions
  • State and error functions
Attention
                      ##### How to use this driver #####
 (#) Enable and latch error information through HAL_RAMECC_Init().
 (#) For a given Monitor, enable and disable interrupt through
     HAL_RAMECC_EnableNotification().
     To enable a notification for a given RAMECC instance, use global
     interrupts.
     To enable a notification for only RAMECC monitor, use monitor interrupts.
     All possible notifications are defined in the driver header file under
     RAMECC_Interrupt group.
   *** Silent mode ***
        (+) Use HAL_RAMECC_StartMonitor() to start RAMECC latch failing
            information without enabling any notification.
   *** Interrupt mode ***
        (+) Use HAL_RAMECC_EnableNotification() to enable interrupts for a
            given error.
        (+) Configure the RAMECC interrupt priority using
            HAL_NVIC_SetPriority().
        (+) Enable the RAMECC IRQ handler using HAL_NVIC_EnableIRQ().
        (+) Start RAMECC latch failing information using HAL_RAMECC_StartMonitor().
   *** Failing information ***
   (#) Use HAL_RAMECC_GetFailingAddress() function to return the RAMECC
       failing address.
   (#) Use HAL_RAMECC_GetFailingDataLow() function to return the RAMECC
       failing data low.
   (#) Use HAL_RAMECC_GetFailingDataHigh() function to return the RAMECC
       failing data high.
   (#) Use HAL_RAMECC_GetHammingErrorCode() function to return the RAMECC
       Hamming bits injected.
   (#) Use HAL_RAMECC_IsECCSingleErrorDetected() function to check if a single
       error was detected and corrected.
   (#) Use HAL_RAMECC_IsECCDoubleErrorDetected() function to check if a double
       error was dedetected.
   *** RAMECC HAL driver macros list ***
     Below the list of used macros in RAMECC HAL driver.
    (+) __HAL_RAMECC_ENABLE_IT  : Enable the specified ECCRAM Monitor
                                  interrupts.
    (+) __HAL_RAMECC_DISABLE_IT : Disable the specified ECCRAM Monitor
                                  interrupts.
    (+) __HAL_RAMECC_GET_FLAG   : Return the current RAMECC Monitor selected
                                  flag.
    (+) __HAL_RAMECC_CLEAR_FLAG : Clear the current RAMECC Monitor selected
                                  flag.
