RTEMS 6.1-rc1
PSSI HAL module driver. This file provides firmware functions to manage the following functionalities of the Parallel Synchronous Slave Interface (PSSI) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The PSSI HAL driver can be used as follows: (#) Declare a PSSI_HandleTypeDef handle structure, for example: PSSI_HandleTypeDef hpssi; (#) Initialize the PSSI low level resources by implementing the @ref HAL_PSSI_MspInit() API: (##) Enable the PSSIx interface clock (##) PSSI pins configuration (+++) Enable the clock for the PSSI GPIOs (+++) Configure PSSI pins as alternate function open-drain (##) NVIC configuration if you need to use interrupt process (+++) Configure the PSSIx interrupt priority (+++) Enable the NVIC PSSI IRQ Channel (##) DMA Configuration if you need to use DMA process (+++) Declare DMA_HandleTypeDef handles structure for the transmit and receive (+++) Enable the DMAx interface clock (+++) Configure the DMA handle parameters (+++) Configure the DMA Tx and Rx (+++) Associate the initialized DMA handle to the hpssi DMA Tx and Rx handle (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx and Rx (#) Configure the Communication Bus Width, Control Signals, Input Polarity and Output Polarity in the hpssi Init structure. (#) Initialize the PSSI registers by calling the @ref HAL_PSSI_Init(), configure also the low level Hardware (GPIO, CLOCK, NVIC...etc) by calling the customized @ref HAL_PSSI_MspInit(&hpssi) API. (#) For PSSI IO operations, two operation modes are available within this driver : *** Polling mode IO operation *** ================================= [..] (+) Transmit an amount of data by byte in blocking mode using @ref HAL_PSSI_Transmit() (+) Receive an amount of data by byte in blocking mode using @ref HAL_PSSI_Receive() *** DMA mode IO operation *** ============================== [..] (+) Transmit an amount of data in non-blocking mode (DMA) using @ref HAL_PSSI_Transmit_DMA() (+) At transmission end of transfer, @ref HAL_PSSI_TxCpltCallback() is executed and user can add his own code by customization of function pointer @ref HAL_PSSI_TxCpltCallback() (+) Receive an amount of data in non-blocking mode (DMA) using @ref HAL_PSSI_Receive_DMA() (+) At reception end of transfer, @ref HAL_PSSI_RxCpltCallback() is executed and user can add his own code by customization of function pointer @ref HAL_PSSI_RxCpltCallback() (+) In case of transfer Error, @ref HAL_PSSI_ErrorCallback() function is executed and user can add his own code by customization of function pointer @ref HAL_PSSI_ErrorCallback() (+) Abort a PSSI process communication with Interrupt using @ref HAL_PSSI_Abort_IT() (+) End of abort process, @ref HAL_PSSI_AbortCpltCallback() is executed and user can add his own code by customization of function pointer @ref HAL_PSSI_AbortCpltCallback() *** PSSI HAL driver macros list *** ================================== [..] Below the list of most used macros in PSSI HAL driver. (+) @ref HAL_PSSI_ENABLE : Enable the PSSI peripheral (+) @ref HAL_PSSI_DISABLE : Disable the PSSI peripheral (+) @ref HAL_PSSI_GET_FLAG : Check whether the specified PSSI flag is set or not (+) @ref HAL_PSSI_CLEAR_FLAG : Clear the specified PSSI pending flag (+) @ref HAL_PSSI_ENABLE_IT : Enable the specified PSSI interrupt (+) @ref HAL_PSSI_DISABLE_IT : Disable the specified PSSI interrupt *** Callback registration *** ============================================= Use Functions @ref HAL_PSSI_RegisterCallback() or @ref HAL_PSSI_RegisterAddrCallback() to register an interrupt callback. Function @ref HAL_PSSI_RegisterCallback() allows to register following callbacks: (+) TxCpltCallback : callback for transmission end of transfer. (+) RxCpltCallback : callback for reception end of transfer. (+) ErrorCallback : callback for error detection. (+) AbortCpltCallback : callback for abort completion process. (+) MspInitCallback : callback for Msp Init. (+) MspDeInitCallback : callback for Msp DeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. Use function @ref HAL_PSSI_UnRegisterCallback to reset a callback to the default weak function. @ref HAL_PSSI_UnRegisterCallback takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxCpltCallback : callback for transmission end of transfer. (+) RxCpltCallback : callback for reception end of transfer. (+) ErrorCallback : callback for error detection. (+) AbortCpltCallback : callback for abort completion process. (+) MspInitCallback : callback for Msp Init. (+) MspDeInitCallback : callback for Msp DeInit. By default, after the @ref HAL_PSSI_Init() and when the state is @ref HAL_PSSI_STATE_RESET all callbacks are set to the corresponding weak functions: examples @ref HAL_PSSI_TxCpltCallback(), @ref HAL_PSSI_RxCpltCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak functions in the @ref HAL_PSSI_Init()/ @ref HAL_PSSI_DeInit() only when these callbacks are null (not registered beforehand). If MspInit or MspDeInit are not null, the @ref HAL_PSSI_Init()/ @ref HAL_PSSI_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state. Callbacks can be registered/unregistered in @ref HAL_PSSI_STATE_READY state only. Exception done MspInit/MspDeInit functions that can be registered/unregistered in @ref HAL_PSSI_STATE_READY or @ref HAL_PSSI_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. Then, the user first registers the MspInit/MspDeInit user callbacks using @ref HAL_PSSI_RegisterCallback() before calling @ref HAL_PSSI_DeInit() or @ref HAL_PSSI_Init() function. [..] (@) You can refer to the PSSI HAL driver header file for more useful macros
