RTEMS 6.1-rc1
OPAMP HAL module driver. This file provides firmware functions to manage the following functionalities of the operational amplifier(s) peripheral: More...
#include "stm32h7xx_hal.h"
================================================================================ ##### OPAMP Peripheral Features ##### ================================================================================ [..] The device integrates 2 operational amplifiers OPAMP1 & OPAMP2 (#) The OPAMP(s) provides several exclusive running modes. (++) Standalone mode (++) Programmable Gain Amplifier (PGA) modes (++) Follower mode (#) Each OPAMP(s) can be configured in normal and high speed mode. (#) The OPAMP(s) provide(s) calibration capabilities. (++) Calibration aims at correcting some offset for running mode. (++) The OPAMP uses either factory calibration settings OR user defined calibration (trimming) settings (i.e. trimming mode). (++) The user defined settings can be figured out using self calibration handled by HAL_OPAMP_SelfCalibrate, HAL_OPAMPEx_SelfCalibrateAll (++) HAL_OPAMP_SelfCalibrate: (+++) Runs automatically the calibration in 2 steps. (90% of VDDA for NMOS transistors, 10% of VDDA for PMOS transistors). (As OPAMP is Rail-to-rail input/output, these 2 steps calibration is appropriate and enough in most cases). (+++) Runs automatically the calibration. (+++) Enables the user trimming mode (+++) Updates the init structure with trimming values with fresh calibration results. The user may store the calibration results for larger (ex monitoring the trimming as a function of temperature for instance) (+++) HAL_OPAMPEx_SelfCalibrateAll runs calibration of all OPAMPs in parallel to save search time. (#) Running mode: Standalone mode (++) Gain is set externally (gain depends on external loads). (++) Follower mode also possible externally by connecting the inverting input to the output. (#) Running mode: Follower mode (++) No Inverting Input is connected. (#) Running mode: Programmable Gain Amplifier (PGA) mode (Resistor feedback output) (#) The OPAMP(s) output(s) can be internally connected to resistor feedback output. (#) OPAMP gain can be selected as : (##) Gain of x2, x4, x8 or x16 for non inverting mode with: (+++) VREF- referenced. (+++) Filtering on VINM0, VREF- referenced. (+++) VINM0 node for bias voltage and VINP0 for input signal. (+++) VINM0 node for bias voltage and VINP0 for input signal, VINM1 node for filtering. (##) Gain of x-1, x-3, x-7 or x-15 for inverting mode with: (+++) VINM0 node for input signal and VINP0 for bias. (+++) VINM0 node for input signal and VINP0 for bias voltage, VINM1 node for filtering. (#) The OPAMPs inverting input can be selected according to the Reference Manual "OPAMP functional description" chapter. (#) The OPAMPs non inverting input can be selected according to the Reference Manual "OPAMP functional description" chapter. ##### How to use this driver ##### ================================================================================ [..] *** High speed / normal power mode *** ============================================ [..] To run in high speed mode: (#) Configure the OPAMP using HAL_OPAMP_Init() function: (++) Select OPAMP_POWERMODE_HIGHSPEED (++) Otherwise select OPAMP_POWERMODE_NORMAL *** Calibration *** ============================================ [..] To run the OPAMP calibration self calibration: (#) Start calibration using HAL_OPAMP_SelfCalibrate. Store the calibration results. *** Running mode *** ============================================ [..] To use the OPAMP, perform the following steps: (#) Fill in the HAL_OPAMP_MspInit() to (++) Enable the OPAMP Peripheral clock using macro __HAL_RCC_OPAMP_CLK_ENABLE() (++) Configure the OPAMP input AND output in analog mode using HAL_GPIO_Init() to map the OPAMP output to the GPIO pin. (#) Registrate Callbacks (++) The compilation define USE_HAL_OPAMP_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. (++) Use Functions HAL_OPAMP_RegisterCallback() to register a user callback, it allows to register following callbacks: (+++) MspInitCallback : OPAMP MspInit. (+++) MspDeInitCallback : OPAMP MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. (++) Use function HAL_OPAMP_UnRegisterCallback() to reset a callback to the default weak (surcharged) function. It allows to reset following callbacks: (+++) MspInitCallback : OPAMP MspInit. (+++) MspDeInitCallback : OPAMP MspDeInit. (+++) All Callbacks (#) Configure the OPAMP using HAL_OPAMP_Init() function: (++) Select the mode (++) Select the inverting input (++) Select the non-inverting input (++) If PGA mode is enabled, Select if inverting input is connected. (++) Select either factory or user defined trimming mode. (++) If the user-defined trimming mode is enabled, select PMOS & NMOS trimming values (typically values set by HAL_OPAMP_SelfCalibrate function). (#) Enable the OPAMP using HAL_OPAMP_Start() function. (#) Disable the OPAMP using HAL_OPAMP_Stop() function. (#) Lock the OPAMP in running mode using HAL_OPAMP_Lock() function. Caution: On STM32H7, HAL OPAMP lock is software lock only (not hardware lock as on some other STM32 devices) (#) If needed, unlock the OPAMP using HAL_OPAMPEx_Unlock() function. *** Running mode: change of configuration while OPAMP ON *** ============================================ [..] To Re-configure OPAMP when OPAMP is ON (change on the fly) (#) If needed, fill in the HAL_OPAMP_MspInit() (++) This is the case for instance if you wish to use new OPAMP I/O (#) Configure the OPAMP using HAL_OPAMP_Init() function: (++) As in configure case, select first the parameters you wish to modify. (#) Change from high speed mode to normal power mode (& vice versa) requires first HAL_OPAMP_DeInit() (force OPAMP OFF) and then HAL_OPAMP_Init(). In other words, of OPAMP is ON, HAL_OPAMP_Init can NOT change power mode alone.
Table 1. OPAMPs inverting/non-inverting inputs for the STM32H7 devices:
OPAMP1 | OPAMP2 | ||
Inverting Input | VM_SEL | VINM0-> PC5 | VINM0-> PE8 |
VINM1-> PA7 | VINM1-> PG1 | ||
Internal: | Internal: | ||
ADC1_IN9 | OPAMP2_OUT | ||
ADC2_IN9 | PGA mode | ||
OPAMP1_OUT | |||
PGA mode | |||
Non Inverting | VP_SEL | ||
VP0 -> PB0 (GPIO) | VP0 -> PE9 (GPIO) | ||
Input | DAC1_CH1_int | DAC1_CH2_int | |
ADC1_IN8 | DAC2_CH1_int | ||
ADC2_IN8 | COMP2_INP | ||
COMP1_INP |
[..] Table 2. OPAMPs outputs for the STM32H7 devices:
Output | VOUT | PC4 | PE7 |
| | | & ADC1_IN4| | & COMP2_INN7 if | | | | ADC2_IN4 |connected internally | | | | COMP1_INN7 if | | | | | connected internally | | |--------------—|-----—|--------------------—|------------------—|
