RTEMS 6.1-rc1
stm32h7xx_hal_irda.c File Reference
IRDA HAL module driver. This file provides firmware functions to manage the following functionalities of the IrDA (Infrared Data Association) Peripheral (IRDA) More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral State and Errors functions
  • Peripheral Control functions
Attention
                      ##### How to use this driver #####
  The IRDA HAL driver can be used as follows:
  (#) Declare a IRDA_HandleTypeDef handle structure (eg. IRDA_HandleTypeDef hirda).
  (#) Initialize the IRDA low level resources by implementing the HAL_IRDA_MspInit() API
      in setting the associated USART or UART in IRDA mode:
      (++) Enable the USARTx/UARTx interface clock.
      (++) USARTx/UARTx pins configuration:
          (+++) Enable the clock for the USARTx/UARTx GPIOs.
          (+++) Configure these USARTx/UARTx pins (TX as alternate function pull-up, RX as alternate function Input).
      (++) NVIC configuration if you need to use interrupt process (HAL_IRDA_Transmit_IT()
           and HAL_IRDA_Receive_IT() APIs):
          (+++) Configure the USARTx/UARTx interrupt priority.
          (+++) Enable the NVIC USARTx/UARTx IRQ handle.
          (+++) The specific IRDA interrupts (Transmission complete interrupt,
                RXNE interrupt and Error Interrupts) will be managed using the macros
                __HAL_IRDA_ENABLE_IT() and __HAL_IRDA_DISABLE_IT() inside the transmit and receive process.
      (++) DMA Configuration if you need to use DMA process (HAL_IRDA_Transmit_DMA()
           and HAL_IRDA_Receive_DMA() APIs):
          (+++) Declare a DMA handle structure for the Tx/Rx channel.
          (+++) Enable the DMAx interface clock.
          (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters.
          (+++) Configure the DMA Tx/Rx channel.
          (+++) Associate the initialized DMA handle to the IRDA DMA Tx/Rx handle.
          (+++) Configure the priority and enable the NVIC for the transfer
                complete interrupt on the DMA Tx/Rx channel.
  (#) Program the Baud Rate, Word Length and Parity and Mode(Receiver/Transmitter),
      the normal or low power mode and the clock prescaler in the hirda handle Init structure.
  (#) Initialize the IRDA registers by calling the HAL_IRDA_Init() API:
      (++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
           by calling the customized HAL_IRDA_MspInit() API.
       -@@- The specific IRDA interrupts (Transmission complete interrupt,
  (#) Three operation modes are available within this driver :
   *** Polling mode IO operation ***
     (+) Send an amount of data in blocking mode using HAL_IRDA_Transmit()
     (+) Receive an amount of data in blocking mode using HAL_IRDA_Receive()
   *** Interrupt mode IO operation ***
     (+) Send an amount of data in non-blocking mode using HAL_IRDA_Transmit_IT()
     (+) At transmission end of transfer HAL_IRDA_TxCpltCallback() is executed and user can
          add his own code by customization of function pointer HAL_IRDA_TxCpltCallback()
     (+) Receive an amount of data in non-blocking mode using HAL_IRDA_Receive_IT()
     (+) At reception end of transfer HAL_IRDA_RxCpltCallback() is executed and user can
          add his own code by customization of function pointer HAL_IRDA_RxCpltCallback()
     (+) In case of transfer Error, HAL_IRDA_ErrorCallback() function is executed and user can
          add his own code by customization of function pointer HAL_IRDA_ErrorCallback()
   *** DMA mode IO operation ***
     (+) Send an amount of data in non-blocking mode (DMA) using HAL_IRDA_Transmit_DMA()
     (+) At transmission half of transfer HAL_IRDA_TxHalfCpltCallback() is executed and user can
          add his own code by customization of function pointer HAL_IRDA_TxHalfCpltCallback()
     (+) Receive an amount of data in non-blocking mode (DMA) using HAL_IRDA_Receive_DMA()
     (+) At reception half of transfer HAL_IRDA_RxHalfCpltCallback() is executed and user can
          add his own code by customization of function pointer HAL_IRDA_RxHalfCpltCallback()
   *** IRDA HAL driver macros list ***
     Below the list of most used macros in IRDA HAL driver.
     (+) __HAL_IRDA_ENABLE: Enable the IRDA peripheral
     (+) __HAL_IRDA_DISABLE: Disable the IRDA peripheral
     (+) __HAL_IRDA_GET_FLAG : Check whether the specified IRDA flag is set or not
     (+) __HAL_IRDA_CLEAR_FLAG : Clear the specified IRDA pending flag
     (+) __HAL_IRDA_ENABLE_IT: Enable the specified IRDA interrupt
     (+) __HAL_IRDA_DISABLE_IT: Disable the specified IRDA interrupt
     (+) __HAL_IRDA_GET_IT_SOURCE: Check whether or not the specified IRDA interrupt is enabled
     (@) You can refer to the IRDA HAL driver header file for more useful macros
  ##### Callback registration #####
  The compilation define USE_HAL_IRDA_REGISTER_CALLBACKS when set to 1
  allows the user to configure dynamically the driver callbacks.
  Use Function HAL_IRDA_RegisterCallback() to register a user callback.
  Function HAL_IRDA_RegisterCallback() allows to register following callbacks:
  (+) TxHalfCpltCallback        : Tx Half Complete Callback.
  (+) TxCpltCallback            : Tx Complete Callback.
  (+) RxHalfCpltCallback        : Rx Half Complete Callback.
  (+) RxCpltCallback            : Rx Complete Callback.
  (+) ErrorCallback             : Error Callback.
  (+) AbortCpltCallback         : Abort Complete Callback.
  (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback.
  (+) AbortReceiveCpltCallback  : Abort Receive Complete Callback.
  (+) MspInitCallback           : IRDA MspInit.
  (+) MspDeInitCallback         : IRDA MspDeInit.
  This function takes as parameters the HAL peripheral handle, the Callback ID
  and a pointer to the user callback function.
  Use function HAL_IRDA_UnRegisterCallback() to reset a callback to the default
  weak (surcharged) function.
  HAL_IRDA_UnRegisterCallback() takes as parameters the HAL peripheral handle,
  and the Callback ID.
  This function allows to reset following callbacks:
  By default, after the HAL_IRDA_Init() and when the state is HAL_IRDA_STATE_RESET
  all callbacks are set to the corresponding weak (surcharged) functions:
  examples HAL_IRDA_TxCpltCallback(), HAL_IRDA_RxHalfCpltCallback().
  Exception done for MspInit and MspDeInit functions that are respectively
  reset to the legacy weak (surcharged) functions in the HAL_IRDA_Init()
  and HAL_IRDA_DeInit() only when these callbacks are null (not registered beforehand).
  If not, MspInit or MspDeInit are not null, the HAL_IRDA_Init() and HAL_IRDA_DeInit()
  keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
  Callbacks can be registered/unregistered in HAL_IRDA_STATE_READY state only.
  Exception done MspInit/MspDeInit that can be registered/unregistered
  in HAL_IRDA_STATE_READY or HAL_IRDA_STATE_RESET state, thus registered (user)
  MspInit/DeInit callbacks can be used during the Init/DeInit.
  In that case first register the MspInit/MspDeInit user callbacks
  using HAL_IRDA_RegisterCallback() before calling HAL_IRDA_DeInit()
  or HAL_IRDA_Init() function.
  When The compilation define USE_HAL_IRDA_REGISTER_CALLBACKS is set to 0 or
  not defined, the callback registration feature is not available
  and weak (surcharged) callbacks are used.
