RTEMS 6.1-rc1
I2S HAL module driver. This file provides firmware functions to manage the following functionalities of the Integrated Interchip Sound (I2S) peripheral: More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### How to use this driver ##### =============================================================================== [..] The I2S HAL driver can be used as follow: (#) Declare a I2S_HandleTypeDef handle structure. (#) Initialize the I2S low level resources by implement the HAL_I2S_MspInit() API: (##) Enable the SPIx interface clock. (##) I2S pins configuration: (+++) Enable the clock for the I2S GPIOs. (+++) Configure these I2S pins as alternate function pull-up. (##) NVIC configuration if you need to use interrupt process (HAL_I2S_Transmit_IT() and HAL_I2S_Receive_IT() APIs). (+++) Configure the I2Sx interrupt priority. (+++) Enable the NVIC I2S IRQ handle. (##) DMA Configuration if you need to use DMA process (HAL_I2S_Transmit_DMA() and HAL_I2S_Receive_DMA() APIs: (+++) Declare a DMA handle structure for the Tx/Rx Stream/Channel. (+++) Enable the DMAx interface clock. (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters. (+++) Configure the DMA Tx/Rx Stream/Channel. (+++) Associate the initialized DMA handle to the I2S DMA Tx/Rx handle. (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx/Rx Stream/Channel. (#) Program the Mode, Standard, Data Format, MCLK Output, Audio frequency and Polarity using HAL_I2S_Init() function. -@- The specific I2S interrupts (Transmission complete interrupt, RXNE interrupt and Error Interrupts) will be managed using the macros __HAL_I2S_ENABLE_IT() and __HAL_I2S_DISABLE_IT() inside the transmit and receive process. (+@) External clock source is configured after setting correctly the define constant EXTERNAL_CLOCK_VALUE in the stm32h7xx_hal_conf.h file. (#) Three mode of operations are available within this driver : *** Polling mode IO operation *** ================================= [..] (+) Send an amount of data in blocking mode using HAL_I2S_Transmit() (+) Receive an amount of data in blocking mode using HAL_I2S_Receive() *** Interrupt mode IO operation *** =================================== [..] (+) Send an amount of data in non blocking mode using HAL_I2S_Transmit_IT() (+) At transmission end of half transfer HAL_I2S_TxHalfCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_TxHalfCpltCallback (+) At transmission end of transfer HAL_I2S_TxCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_TxCpltCallback (+) Receive an amount of data in non blocking mode using HAL_I2S_Receive_IT() (+) At reception end of half transfer HAL_I2S_RxHalfCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_RxHalfCpltCallback (+) At reception end of transfer HAL_I2S_RxCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_RxCpltCallback (+) In case of transfer Error, HAL_I2S_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_I2S_ErrorCallback *** DMA mode IO operation *** ============================== [..] (+) Send an amount of data in non blocking mode (DMA) using HAL_I2S_Transmit_DMA() (+) At transmission end of half transfer HAL_I2S_TxHalfCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_TxHalfCpltCallback (+) At transmission end of transfer HAL_I2S_TxCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_TxCpltCallback (+) Receive an amount of data in non blocking mode (DMA) using HAL_I2S_Receive_DMA() (+) At reception end of half transfer HAL_I2S_RxHalfCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_RxHalfCpltCallback (+) At reception end of transfer HAL_I2S_RxCpltCallback is executed and user can add his own code by customization of function pointer HAL_I2S_RxCpltCallback (+) In case of transfer Error, HAL_I2S_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_I2S_ErrorCallback (+) Pause the DMA Transfer using HAL_I2S_DMAPause() (+) Resume the DMA Transfer using HAL_I2S_DMAResume() (+) Stop the DMA Transfer using HAL_I2S_DMAStop() *** I2S HAL driver macros list *** =================================== [..] Below the list of most used macros in I2S HAL driver. (+) __HAL_I2S_ENABLE: Enable the specified SPI peripheral (in I2S mode) (+) __HAL_I2S_DISABLE: Disable the specified SPI peripheral (in I2S mode) (+) __HAL_I2S_ENABLE_IT : Enable the specified I2S interrupts (+) __HAL_I2S_DISABLE_IT : Disable the specified I2S interrupts (+) __HAL_I2S_GET_FLAG: Check whether the specified I2S flag is set or not [..] (@) You can refer to the I2S HAL driver header file for more useful macros *** I2S HAL driver macros list *** =================================== [..] Callback registration: (#) The compilation flag USE_HAL_I2S_REGISTER_CALLBACKS when set to 1UL allows the user to configure dynamically the driver callbacks. Use Functions HAL_I2S_RegisterCallback() to register an interrupt callback. Function HAL_I2S_RegisterCallback() allows to register following callbacks: (+) TxCpltCallback : I2S Tx Completed callback (+) RxCpltCallback : I2S Rx Completed callback (+) TxRxCpltCallback : I2S TxRx Completed callback (+) TxHalfCpltCallback : I2S Tx Half Completed callback (+) RxHalfCpltCallback : I2S Rx Half Completed callback (+) TxRxHalfCpltCallback : I2S TxRx Half Completed callback (+) ErrorCallback : I2S Error callback (+) MspInitCallback : I2S Msp Init callback (+) MspDeInitCallback : I2S Msp DeInit callback This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. (#) Use function HAL_I2S_UnRegisterCallback to reset a callback to the default weak function. HAL_I2S_UnRegisterCallback takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxCpltCallback : I2S Tx Completed callback (+) RxCpltCallback : I2S Rx Completed callback (+) TxRxCpltCallback : I2S TxRx Completed callback (+) TxHalfCpltCallback : I2S Tx Half Completed callback (+) RxHalfCpltCallback : I2S Rx Half Completed callback (+) TxRxHalfCpltCallback : I2S TxRx Half Completed callback (+) ErrorCallback : I2S Error callback (+) MspInitCallback : I2S Msp Init callback (+) MspDeInitCallback : I2S Msp DeInit callback By default, after the HAL_I2S_Init() and when the state is HAL_I2S_STATE_RESET all callbacks are set to the corresponding weak functions: examples HAL_I2S_MasterTxCpltCallback(), HAL_I2S_MasterRxCpltCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak functions in the HAL_I2S_Init()/ HAL_I2S_DeInit() only when these callbacks are null (not registered beforehand). If MspInit or MspDeInit are not null, the HAL_I2S_Init()/ HAL_I2S_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state. Callbacks can be registered/unregistered in HAL_I2S_STATE_READY state only. Exception done MspInit/MspDeInit functions that can be registered/unregistered in HAL_I2S_STATE_READY or HAL_I2S_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. Then, the user first registers the MspInit/MspDeInit user callbacks using HAL_I2S_RegisterCallback() before calling HAL_I2S_DeInit() or HAL_I2S_Init() function. When The compilation define USE_HAL_I2S_REGISTER_CALLBACKS is set to 0 or not defined, the callback registering feature is not available and weak (surcharged) callbacks are used.
