RTEMS 6.1-rc1
I2C Extended HAL module driver. This file provides firmware functions to manage the following functionalities of I2C Extended peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### I2C peripheral Extended features ##### ============================================================================== [..] Comparing to other previous devices, the I2C interface for STM32H7xx devices contains the following additional features (+) Possibility to disable or enable Analog Noise Filter (+) Use of a configured Digital Noise Filter (+) Disable or enable wakeup from Stop mode(s) (+) Disable or enable Fast Mode Plus ##### How to use this driver ##### ============================================================================== [..] This driver provides functions to configure Noise Filter and Wake Up Feature (#) Configure I2C Analog noise filter using the function HAL_I2CEx_ConfigAnalogFilter() (#) Configure I2C Digital noise filter using the function HAL_I2CEx_ConfigDigitalFilter() (#) Configure the enable or disable of I2C Wake Up Mode using the functions : (++) HAL_I2CEx_EnableWakeUp() (++) HAL_I2CEx_DisableWakeUp() (#) Configure the enable or disable of fast mode plus driving capability using the functions : (++) HAL_I2CEx_EnableFastModePlus() (++) HAL_I2CEx_DisableFastModePlus()
