RTEMS 6.1-rc1
I2C HAL module driver. This file provides firmware functions to manage the following functionalities of the Inter Integrated Circuit (I2C) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The I2C HAL driver can be used as follows: (#) Declare a I2C_HandleTypeDef handle structure, for example: I2C_HandleTypeDef hi2c; (#)Initialize the I2C low level resources by implementing the HAL_I2C_MspInit() API: (##) Enable the I2Cx interface clock (##) I2C pins configuration (+++) Enable the clock for the I2C GPIOs (+++) Configure I2C pins as alternate function open-drain (##) NVIC configuration if you need to use interrupt process (+++) Configure the I2Cx interrupt priority (+++) Enable the NVIC I2C IRQ Channel (##) DMA Configuration if you need to use DMA process (+++) Declare a DMA_HandleTypeDef handle structure for the transmit or receive stream or channel depends on Instance (+++) Enable the DMAx interface clock using (+++) Configure the DMA handle parameters (+++) Configure the DMA Tx or Rx stream or channel depends on Instance (+++) Associate the initialized DMA handle to the hi2c DMA Tx or Rx handle (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx or Rx stream or channel depends on Instance (#) Configure the Communication Clock Timing, Own Address1, Master Addressing mode, Dual Addressing mode, Own Address2, Own Address2 Mask, General call and Nostretch mode in the hi2c Init structure. (#) Initialize the I2C registers by calling the HAL_I2C_Init(), configures also the low level Hardware (GPIO, CLOCK, NVIC...etc) by calling the customized HAL_I2C_MspInit(&hi2c) API. (#) To check if target device is ready for communication, use the function HAL_I2C_IsDeviceReady() (#) For I2C IO and IO MEM operations, three operation modes are available within this driver : *** Polling mode IO operation *** ================================= [..] (+) Transmit in master mode an amount of data in blocking mode using HAL_I2C_Master_Transmit() (+) Receive in master mode an amount of data in blocking mode using HAL_I2C_Master_Receive() (+) Transmit in slave mode an amount of data in blocking mode using HAL_I2C_Slave_Transmit() (+) Receive in slave mode an amount of data in blocking mode using HAL_I2C_Slave_Receive() *** Polling mode IO MEM operation *** ===================================== [..] (+) Write an amount of data in blocking mode to a specific memory address using HAL_I2C_Mem_Write() (+) Read an amount of data in blocking mode from a specific memory address using HAL_I2C_Mem_Read() *** Interrupt mode IO operation *** =================================== [..] (+) Transmit in master mode an amount of data in non-blocking mode using HAL_I2C_Master_Transmit_IT() (+) At transmission end of transfer, HAL_I2C_MasterTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MasterTxCpltCallback() (+) Receive in master mode an amount of data in non-blocking mode using HAL_I2C_Master_Receive_IT() (+) At reception end of transfer, HAL_I2C_MasterRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MasterRxCpltCallback() (+) Transmit in slave mode an amount of data in non-blocking mode using HAL_I2C_Slave_Transmit_IT() (+) At transmission end of transfer, HAL_I2C_SlaveTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_SlaveTxCpltCallback() (+) Receive in slave mode an amount of data in non-blocking mode using HAL_I2C_Slave_Receive_IT() (+) At reception end of transfer, HAL_I2C_SlaveRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_SlaveRxCpltCallback() (+) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and users can add their own code by customization of function pointer HAL_I2C_ErrorCallback() (+) Abort a master I2C process communication with Interrupt using HAL_I2C_Master_Abort_IT() (+) End of abort process, HAL_I2C_AbortCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_AbortCpltCallback() (+) Discard a slave I2C process communication using __HAL_I2C_GENERATE_NACK() macro. This action will inform Master to generate a Stop condition to discard the communication. *** Interrupt mode or DMA mode IO sequential operation *** ========================================================== [..] (@) These interfaces allow to manage a sequential transfer with a repeated start condition when a direction change during transfer [..] (+) A specific option field manage the different steps of a sequential transfer (+) Option field values are defined through I2C_XFEROPTIONS and are listed below: (++) I2C_FIRST_AND_LAST_FRAME: No sequential usage, functional is same as associated interfaces in no sequential mode (++) I2C_FIRST_FRAME: Sequential usage, this option allow to manage a sequence with start condition, address and data to transfer without a final stop condition (++) I2C_FIRST_AND_NEXT_FRAME: Sequential usage (Master only), this option allow to manage a sequence with start condition, address and data to transfer without a final stop condition, an then permit a call the same master sequential interface several times (like HAL_I2C_Master_Seq_Transmit_IT() then HAL_I2C_Master_Seq_Transmit_IT() or HAL_I2C_Master_Seq_Transmit_DMA() then HAL_I2C_Master_Seq_Transmit_DMA()) (++) I2C_NEXT_FRAME: Sequential usage, this option allow to manage a sequence with a restart condition, address and with new data to transfer if the direction change or manage only the new data to transfer if no direction change and without a final stop condition in both cases (++) I2C_LAST_FRAME: Sequential usage, this option allow to manage a sequance with a restart condition, address and with new data to transfer if the direction change or manage only the new data to transfer if no direction change and with a final stop condition in both cases (++) I2C_LAST_FRAME_NO_STOP: Sequential usage (Master only), this option allow to manage a restart condition after several call of the same master sequential interface several times (link with option I2C_FIRST_AND_NEXT_FRAME). Usage can, transfer several bytes one by one using HAL_I2C_Master_Seq_Transmit_IT or HAL_I2C_Master_Seq_Receive_IT or HAL_I2C_Master_Seq_Transmit_DMA or HAL_I2C_Master_Seq_Receive_DMA with option I2C_FIRST_AND_NEXT_FRAME then I2C_NEXT_FRAME. Then usage of this option I2C_LAST_FRAME_NO_STOP at the last Transmit or Receive sequence permit to call the opposite interface Receive or Transmit without stopping the communication and so generate a restart condition. (++) I2C_OTHER_FRAME: Sequential usage (Master only), this option allow to manage a restart condition after each call of the same master sequential interface. Usage can, transfer several bytes one by one with a restart with slave address between each bytes using HAL_I2C_Master_Seq_Transmit_IT or HAL_I2C_Master_Seq_Receive_IT or HAL_I2C_Master_Seq_Transmit_DMA or HAL_I2C_Master_Seq_Receive_DMA with option I2C_FIRST_FRAME then I2C_OTHER_FRAME. Then usage of this option I2C_OTHER_AND_LAST_FRAME at the last frame to help automatic generation of STOP condition. (+) Different sequential I2C interfaces are listed below: (++) Sequential transmit in master I2C mode an amount of data in non-blocking mode using HAL_I2C_Master_Seq_Transmit_IT() or using HAL_I2C_Master_Seq_Transmit_DMA() (+++) At transmission end of current frame transfer, HAL_I2C_MasterTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MasterTxCpltCallback() (++) Sequential receive in master I2C mode an amount of data in non-blocking mode using HAL_I2C_Master_Seq_Receive_IT() or using HAL_I2C_Master_Seq_Receive_DMA() (+++) At reception end of current frame transfer, HAL_I2C_MasterRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MasterRxCpltCallback() (++) Abort a master IT or DMA I2C process communication with Interrupt using HAL_I2C_Master_Abort_IT() (+++) End of abort process, HAL_I2C_AbortCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_AbortCpltCallback() (++) Enable/disable the Address listen mode in slave I2C mode using HAL_I2C_EnableListen_IT() HAL_I2C_DisableListen_IT() (+++) When address slave I2C match, HAL_I2C_AddrCallback() is executed and users can add their own code to check the Address Match Code and the transmission direction request by master (Write/Read). (+++) At Listen mode end HAL_I2C_ListenCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_ListenCpltCallback() (++) Sequential transmit in slave I2C mode an amount of data in non-blocking mode using HAL_I2C_Slave_Seq_Transmit_IT() or using HAL_I2C_Slave_Seq_Transmit_DMA() (+++) At transmission end of current frame transfer, HAL_I2C_SlaveTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_SlaveTxCpltCallback() (++) Sequential receive in slave I2C mode an amount of data in non-blocking mode using HAL_I2C_Slave_Seq_Receive_IT() or using HAL_I2C_Slave_Seq_Receive_DMA() (+++) At reception end of current frame transfer, HAL_I2C_SlaveRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_SlaveRxCpltCallback() (++) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and users can add their own code by customization of function pointer HAL_I2C_ErrorCallback() (++) Discard a slave I2C process communication using __HAL_I2C_GENERATE_NACK() macro. This action will inform Master to generate a Stop condition to discard the communication. *** Interrupt mode IO MEM operation *** ======================================= [..] (+) Write an amount of data in non-blocking mode with Interrupt to a specific memory address using HAL_I2C_Mem_Write_IT() (+) At Memory end of write transfer, HAL_I2C_MemTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MemTxCpltCallback() (+) Read an amount of data in non-blocking mode with Interrupt from a specific memory address using HAL_I2C_Mem_Read_IT() (+) At Memory end of read transfer, HAL_I2C_MemRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MemRxCpltCallback() (+) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and users can add their own code by customization of function pointer HAL_I2C_ErrorCallback() *** DMA mode IO operation *** ============================== [..] (+) Transmit in master mode an amount of data in non-blocking mode (DMA) using HAL_I2C_Master_Transmit_DMA() (+) At transmission end of transfer, HAL_I2C_MasterTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MasterTxCpltCallback() (+) Receive in master mode an amount of data in non-blocking mode (DMA) using HAL_I2C_Master_Receive_DMA() (+) At reception end of transfer, HAL_I2C_MasterRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MasterRxCpltCallback() (+) Transmit in slave mode an amount of data in non-blocking mode (DMA) using HAL_I2C_Slave_Transmit_DMA() (+) At transmission end of transfer, HAL_I2C_SlaveTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_SlaveTxCpltCallback() (+) Receive in slave mode an amount of data in non-blocking mode (DMA) using HAL_I2C_Slave_Receive_DMA() (+) At reception end of transfer, HAL_I2C_SlaveRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_SlaveRxCpltCallback() (+) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and users can add their own code by customization of function pointer HAL_I2C_ErrorCallback() (+) Abort a master I2C process communication with Interrupt using HAL_I2C_Master_Abort_IT() (+) End of abort process, HAL_I2C_AbortCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_AbortCpltCallback() (+) Discard a slave I2C process communication using __HAL_I2C_GENERATE_NACK() macro. This action will inform Master to generate a Stop condition to discard the communication. *** DMA mode IO MEM operation *** ================================= [..] (+) Write an amount of data in non-blocking mode with DMA to a specific memory address using HAL_I2C_Mem_Write_DMA() (+) At Memory end of write transfer, HAL_I2C_MemTxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MemTxCpltCallback() (+) Read an amount of data in non-blocking mode with DMA from a specific memory address using HAL_I2C_Mem_Read_DMA() (+) At Memory end of read transfer, HAL_I2C_MemRxCpltCallback() is executed and users can add their own code by customization of function pointer HAL_I2C_MemRxCpltCallback() (+) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and users can add their own code by customization of function pointer HAL_I2C_ErrorCallback() *** I2C HAL driver macros list *** ================================== [..] Below the list of most used macros in I2C HAL driver. (+) __HAL_I2C_ENABLE: Enable the I2C peripheral (+) __HAL_I2C_DISABLE: Disable the I2C peripheral (+) __HAL_I2C_GENERATE_NACK: Generate a Non-Acknowledge I2C peripheral in Slave mode (+) __HAL_I2C_GET_FLAG: Check whether the specified I2C flag is set or not (+) __HAL_I2C_CLEAR_FLAG: Clear the specified I2C pending flag (+) __HAL_I2C_ENABLE_IT: Enable the specified I2C interrupt (+) __HAL_I2C_DISABLE_IT: Disable the specified I2C interrupt *** Callback registration *** ============================================= [..] The compilation flag USE_HAL_I2C_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use Functions HAL_I2C_RegisterCallback() or HAL_I2C_RegisterAddrCallback() to register an interrupt callback. [..] Function HAL_I2C_RegisterCallback() allows to register following callbacks: (+) MasterTxCpltCallback : callback for Master transmission end of transfer. (+) MasterRxCpltCallback : callback for Master reception end of transfer. (+) SlaveTxCpltCallback : callback for Slave transmission end of transfer. (+) SlaveRxCpltCallback : callback for Slave reception end of transfer. (+) ListenCpltCallback : callback for end of listen mode. (+) MemTxCpltCallback : callback for Memory transmission end of transfer. (+) MemRxCpltCallback : callback for Memory reception end of transfer. (+) ErrorCallback : callback for error detection. (+) AbortCpltCallback : callback for abort completion process. (+) MspInitCallback : callback for Msp Init. (+) MspDeInitCallback : callback for Msp DeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] For specific callback AddrCallback use dedicated register callbacks : HAL_I2C_RegisterAddrCallback(). [..] Use function HAL_I2C_UnRegisterCallback to reset a callback to the default weak function. HAL_I2C_UnRegisterCallback takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) MasterTxCpltCallback : callback for Master transmission end of transfer. (+) MasterRxCpltCallback : callback for Master reception end of transfer. (+) SlaveTxCpltCallback : callback for Slave transmission end of transfer. (+) SlaveRxCpltCallback : callback for Slave reception end of transfer. (+) ListenCpltCallback : callback for end of listen mode. (+) MemTxCpltCallback : callback for Memory transmission end of transfer. (+) MemRxCpltCallback : callback for Memory reception end of transfer. (+) ErrorCallback : callback for error detection. (+) AbortCpltCallback : callback for abort completion process. (+) MspInitCallback : callback for Msp Init. (+) MspDeInitCallback : callback for Msp DeInit. [..] For callback AddrCallback use dedicated register callbacks : HAL_I2C_UnRegisterAddrCallback(). [..] By default, after the HAL_I2C_Init() and when the state is HAL_I2C_STATE_RESET all callbacks are set to the corresponding weak functions: examples HAL_I2C_MasterTxCpltCallback(), HAL_I2C_MasterRxCpltCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak functions in the HAL_I2C_Init()/ HAL_I2C_DeInit() only when these callbacks are null (not registered beforehand). If MspInit or MspDeInit are not null, the HAL_I2C_Init()/ HAL_I2C_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state. [..] Callbacks can be registered/unregistered in HAL_I2C_STATE_READY state only. Exception done MspInit/MspDeInit functions that can be registered/unregistered in HAL_I2C_STATE_READY or HAL_I2C_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. Then, the user first registers the MspInit/MspDeInit user callbacks using HAL_I2C_RegisterCallback() before calling HAL_I2C_DeInit() or HAL_I2C_Init() function. [..] When the compilation flag USE_HAL_I2C_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions. [..] (@) You can refer to the I2C HAL driver header file for more useful macros
