RTEMS 6.1-rc1
This file provides firmware functions to manage the following functionalities of the Graphic MMU (GFXMMU) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] *** Initialization *** ====================== [..] (#) As prerequisite, fill in the HAL_GFXMMU_MspInit() : (++) Enable GFXMMU clock interface with __HAL_RCC_GFXMMU_CLK_ENABLE(). (++) If interrupts are used, enable and configure GFXMMU global interrupt with HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ(). (#) Configure the number of blocks per line, default value, physical buffer addresses, cache and pre-fetch parameters and interrupts using the HAL_GFXMMU_Init() function. *** LUT configuration *** ========================= [..] (#) Use HAL_GFXMMU_DisableLutLines() to deactivate all LUT lines (or a range of lines). (#) Use HAL_GFXMMU_ConfigLut() to copy LUT from flash to look up RAM. (#) Use HAL_GFXMMU_ConfigLutLine() to configure one line of LUT. *** Force flush and/or invalidate of cache *** ============================================== [..] (#) Use HAL_GFXMMU_ConfigForceCache() to flush and/or invalidate cache. *** Modify physical buffer addresses *** ======================================= [..] (#) Use HAL_GFXMMU_ModifyBuffers() to modify physical buffer addresses. *** Modify cache and pre-fetch parameters *** ============================================= [..] (#) Use HAL_GFXMMU_ModifyCachePrefetch() to modify cache and pre-fetch parameters. *** Error management *** ======================== [..] (#) If interrupts are used, HAL_GFXMMU_IRQHandler() will be called when an error occurs. This function will call HAL_GFXMMU_ErrorCallback(). Use HAL_GFXMMU_GetError() to get the error code. *** De-initialization *** ========================= [..] (#) As prerequisite, fill in the HAL_GFXMMU_MspDeInit() : (++) Disable GFXMMU clock interface with __HAL_RCC_GFXMMU_CLK_ENABLE(). (++) If interrupts has been used, disable GFXMMU global interrupt with HAL_NVIC_DisableIRQ(). (#) De-initialize GFXMMU using the HAL_GFXMMU_DeInit() function. *** Callback registration *** ============================= [..] The compilation define USE_HAL_GFXMMU_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use functions HAL_GFXMMU_RegisterCallback() to register a user callback. [..] Function HAL_GFXMMU_RegisterCallback() allows to register following callbacks: (+) ErrorCallback : GFXMMU error. (+) MspInitCallback : GFXMMU MspInit. (+) MspDeInitCallback : GFXMMU MspDeInit. [..] This function takes as parameters the HAL peripheral handle, the callback ID and a pointer to the user callback function. [..] Use function HAL_GFXMMU_UnRegisterCallback() to reset a callback to the default weak (surcharged) function. HAL_GFXMMU_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the callback ID. [..] This function allows to reset following callbacks: (+) ErrorCallback : GFXMMU error. (+) MspInitCallback : GFXMMU MspInit. (+) MspDeInitCallback : GFXMMU MspDeInit. [..] By default, after the HAL_GFXMMU_Init and if the state is HAL_GFXMMU_STATE_RESET all callbacks are reset to the corresponding legacy weak (surcharged) functions: examples HAL_GFXMMU_ErrorCallback(). Exception done for MspInit and MspDeInit callbacks that are respectively reset to the legacy weak (surcharged) functions in the HAL_GFXMMU_Init and HAL_GFXMMU_DeInit only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_GFXMMU_Init and HAL_GFXMMU_DeInit keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in READY state only. Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_GFXMMU_RegisterCallback before calling HAL_GFXMMU_DeInit or HAL_GFXMMU_Init function. [..] When the compilation define USE_HAL_GFXMMU_REGISTER_CALLBACKS is set to 0 or not defined, the callback registering feature is not available and weak (surcharged) callbacks are used.
