RTEMS 6.1-rc1
FDCAN HAL module driver. This file provides firmware functions to manage the following functionalities of the Flexible DataRate Controller Area Network (FDCAN) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] (#) Initialize the FDCAN peripheral using HAL_FDCAN_Init function. (#) If needed , configure the reception filters and optional features using the following configuration functions: (++) HAL_FDCAN_ConfigClockCalibration (++) HAL_FDCAN_ConfigFilter (++) HAL_FDCAN_ConfigGlobalFilter (++) HAL_FDCAN_ConfigExtendedIdMask (++) HAL_FDCAN_ConfigRxFifoOverwrite (++) HAL_FDCAN_ConfigFifoWatermark (++) HAL_FDCAN_ConfigRamWatchdog (++) HAL_FDCAN_ConfigTimestampCounter (++) HAL_FDCAN_EnableTimestampCounter (++) HAL_FDCAN_DisableTimestampCounter (++) HAL_FDCAN_ConfigTimeoutCounter (++) HAL_FDCAN_EnableTimeoutCounter (++) HAL_FDCAN_DisableTimeoutCounter (++) HAL_FDCAN_ConfigTxDelayCompensation (++) HAL_FDCAN_EnableTxDelayCompensation (++) HAL_FDCAN_DisableTxDelayCompensation (++) HAL_FDCAN_EnableISOMode (++) HAL_FDCAN_DisableISOMode (++) HAL_FDCAN_EnableEdgeFiltering (++) HAL_FDCAN_DisableEdgeFiltering (++) HAL_FDCAN_TT_ConfigOperation (++) HAL_FDCAN_TT_ConfigReferenceMessage (++) HAL_FDCAN_TT_ConfigTrigger (#) Start the FDCAN module using HAL_FDCAN_Start function. At this level the node is active on the bus: it can send and receive messages. (#) The following Tx control functions can only be called when the FDCAN module is started: (++) HAL_FDCAN_AddMessageToTxFifoQ (++) HAL_FDCAN_EnableTxBufferRequest (++) HAL_FDCAN_AbortTxRequest (#) After having submitted a Tx request in Tx Fifo or Queue, it is possible to get Tx buffer location used to place the Tx request thanks to HAL_FDCAN_GetLatestTxFifoQRequestBuffer API. It is then possible to abort later on the corresponding Tx Request using HAL_FDCAN_AbortTxRequest API. (#) When a message is received into the FDCAN message RAM, it can be retrieved using the HAL_FDCAN_GetRxMessage function. (#) Calling the HAL_FDCAN_Stop function stops the FDCAN module by entering it to initialization mode and re-enabling access to configuration registers through the configuration functions listed here above. (#) All other control functions can be called any time after initialization phase, no matter if the FDCAN module is started or stopped. *** Polling mode operation *** ============================== [..] (#) Reception and transmission states can be monitored via the following functions: (++) HAL_FDCAN_IsRxBufferMessageAvailable (++) HAL_FDCAN_IsTxBufferMessagePending (++) HAL_FDCAN_GetRxFifoFillLevel (++) HAL_FDCAN_GetTxFifoFreeLevel *** Interrupt mode operation *** ================================ [..] (#) There are two interrupt lines: line 0 and 1. By default, all interrupts are assigned to line 0. Interrupt lines can be configured using HAL_FDCAN_ConfigInterruptLines function. (#) Notifications are activated using HAL_FDCAN_ActivateNotification function. Then, the process can be controlled through one of the available user callbacks: HAL_FDCAN_xxxCallback. *** Callback registration *** ============================================= The compilation define USE_HAL_FDCAN_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use Function HAL_FDCAN_RegisterCallback() or HAL_FDCAN_RegisterXXXCallback() to register an interrupt callback. Function HAL_FDCAN_RegisterCallback() allows to register following callbacks: (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) RxBufferNewMessageCallback : Rx Buffer New Message Callback. (+) HighPriorityMessageCallback : High Priority Message Callback. (+) TimestampWraparoundCallback : Timestamp Wraparound Callback. (+) TimeoutOccurredCallback : Timeout Occurred Callback. (+) ErrorCallback : Error Callback. (+) MspInitCallback : FDCAN MspInit. (+) MspDeInitCallback : FDCAN MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. For specific callbacks ClockCalibrationCallback, TxEventFifoCallback, RxFifo0Callback, RxFifo1Callback, TxBufferCompleteCallback, TxBufferAbortCallback, ErrorStatusCallback, TT_ScheduleSyncCallback, TT_TimeMarkCallback, TT_StopWatchCallback and TT_GlobalTimeCallback, use dedicated register callbacks : respectively HAL_FDCAN_RegisterClockCalibrationCallback(), HAL_FDCAN_RegisterTxEventFifoCallback(), HAL_FDCAN_RegisterRxFifo0Callback(), HAL_FDCAN_RegisterRxFifo1Callback(), HAL_FDCAN_RegisterTxBufferCompleCallback(), HAL_FDCAN_RegisterTxBufferAbortCallback(), HAL_FDCAN_RegisterErrorStatusCallback(), HAL_FDCAN_TT_RegisterScheduleSyncCallback(), HAL_FDCAN_TT_RegisterTimeMarkCallback(), HAL_FDCAN_TT_RegisterStopWatchCallback() and HAL_FDCAN_TT_RegisterGlobalTimeCallback(). Use function HAL_FDCAN_UnRegisterCallback() to reset a callback to the default weak function. HAL_FDCAN_UnRegisterCallback takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) RxBufferNewMessageCallback : Rx Buffer New Message Callback. (+) HighPriorityMessageCallback : High Priority Message Callback. (+) TimestampWraparoundCallback : Timestamp Wraparound Callback. (+) TimeoutOccurredCallback : Timeout Occurred Callback. (+) ErrorCallback : Error Callback. (+) MspInitCallback : FDCAN MspInit. (+) MspDeInitCallback : FDCAN MspDeInit. For specific callbacks ClockCalibrationCallback, TxEventFifoCallback, RxFifo0Callback, RxFifo1Callback, TxBufferCompleteCallback, TxBufferAbortCallback, TT_ScheduleSyncCallback, TT_TimeMarkCallback, TT_StopWatchCallback and TT_GlobalTimeCallback, use dedicated register callbacks : respectively HAL_FDCAN_UnRegisterClockCalibrationCallback(), HAL_FDCAN_UnRegisterTxEventFifoCallback(), HAL_FDCAN_UnRegisterRxFifo0Callback(), HAL_FDCAN_UnRegisterRxFifo1Callback(), HAL_FDCAN_UnRegisterTxBufferCompleCallback(), HAL_FDCAN_UnRegisterTxBufferAbortCallback(), HAL_FDCAN_UnRegisterErrorStatusCallback(), HAL_FDCAN_TT_UnRegisterScheduleSyncCallback(), HAL_FDCAN_TT_UnRegisterTimeMarkCallback(), HAL_FDCAN_TT_UnRegisterStopWatchCallback() and HAL_FDCAN_TT_UnRegisterGlobalTimeCallback(). By default, after the HAL_FDCAN_Init() and when the state is HAL_FDCAN_STATE_RESET, all callbacks are set to the corresponding weak functions: examples HAL_FDCAN_ErrorCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak function in the HAL_FDCAN_Init()/ HAL_FDCAN_DeInit() only when these callbacks are null (not registered beforehand). if not, MspInit or MspDeInit are not null, the HAL_FDCAN_Init()/ HAL_FDCAN_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand) Callbacks can be registered/unregistered in HAL_FDCAN_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_FDCAN_STATE_READY or HAL_FDCAN_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_FDCAN_RegisterCallback() before calling HAL_FDCAN_DeInit() or HAL_FDCAN_Init() function. When The compilation define USE_HAL_FDCAN_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
