RTEMS 6.1-rc1
DSI HAL module driver. This file provides firmware functions to manage the following functionalities of the DSI peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The DSI HAL driver can be used as follows: (#) Declare a DSI_HandleTypeDef handle structure, for example: DSI_HandleTypeDef hdsi; (#) Initialize the DSI low level resources by implementing the HAL_DSI_MspInit() API: (##) Enable the DSI interface clock (##) NVIC configuration if you need to use interrupt process (+++) Configure the DSI interrupt priority (+++) Enable the NVIC DSI IRQ Channel (#) Initialize the DSI Host peripheral, the required PLL parameters, number of lances and TX Escape clock divider by calling the HAL_DSI_Init() API which calls HAL_DSI_MspInit(). *** Configuration *** ========================= [..] (#) Use HAL_DSI_ConfigAdaptedCommandMode() function to configure the DSI host in adapted command mode. (#) When operating in video mode , use HAL_DSI_ConfigVideoMode() to configure the DSI host. (#) Function HAL_DSI_ConfigCommand() is used to configure the DSI commands behavior in low power mode. (#) To configure the DSI PHY timings parameters, use function HAL_DSI_ConfigPhyTimer(). (#) The DSI Host can be started/stopped using respectively functions HAL_DSI_Start() and HAL_DSI_Stop(). Functions HAL_DSI_ShortWrite(), HAL_DSI_LongWrite() and HAL_DSI_Read() allows respectively to write DSI short packets, long packets and to read DSI packets. (#) The DSI Host Offers two Low power modes : (++) Low Power Mode on data lanes only: Only DSI data lanes are shut down. It is possible to enter/exit from this mode using respectively functions HAL_DSI_EnterULPMData() and HAL_DSI_ExitULPMData() (++) Low Power Mode on data and clock lanes : All DSI lanes are shut down including data and clock lanes. It is possible to enter/exit from this mode using respectively functions HAL_DSI_EnterULPM() and HAL_DSI_ExitULPM() (#) To control DSI state you can use the following function: HAL_DSI_GetState() *** Error management *** ======================== [..] (#) User can select the DSI errors to be reported/monitored using function HAL_DSI_ConfigErrorMonitor() When an error occurs, the callback HAL_DSI_ErrorCallback() is asserted and then user can retrieve the error code by calling function HAL_DSI_GetError() *** DSI HAL driver macros list *** ============================================= [..] Below the list of most used macros in DSI HAL driver. (+) __HAL_DSI_ENABLE: Enable the DSI Host. (+) __HAL_DSI_DISABLE: Disable the DSI Host. (+) __HAL_DSI_WRAPPER_ENABLE: Enables the DSI wrapper. (+) __HAL_DSI_WRAPPER_DISABLE: Disable the DSI wrapper. (+) __HAL_DSI_PLL_ENABLE: Enables the DSI PLL. (+) __HAL_DSI_PLL_DISABLE: Disables the DSI PLL. (+) __HAL_DSI_REG_ENABLE: Enables the DSI regulator. (+) __HAL_DSI_REG_DISABLE: Disables the DSI regulator. (+) __HAL_DSI_GET_FLAG: Get the DSI pending flags. (+) __HAL_DSI_CLEAR_FLAG: Clears the DSI pending flags. (+) __HAL_DSI_ENABLE_IT: Enables the specified DSI interrupts. (+) __HAL_DSI_DISABLE_IT: Disables the specified DSI interrupts. (+) __HAL_DSI_GET_IT_SOURCE: Checks whether the specified DSI interrupt source is enabled or not. [..] (@) You can refer to the DSI HAL driver header file for more useful macros *** Callback registration *** ============================================= [..] The compilation define USE_HAL_DSI_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use Function HAL_DSI_RegisterCallback() to register a callback. [..] Function HAL_DSI_RegisterCallback() allows to register following callbacks: (+) TearingEffectCallback : DSI Tearing Effect Callback. (+) EndOfRefreshCallback : DSI End Of Refresh Callback. (+) ErrorCallback : DSI Error Callback (+) MspInitCallback : DSI MspInit. (+) MspDeInitCallback : DSI MspDeInit. [..] This function takes as parameters the HAL peripheral handle, the callback ID and a pointer to the user callback function. [..] Use function HAL_DSI_UnRegisterCallback() to reset a callback to the default weak function. HAL_DSI_UnRegisterCallback takes as parameters the HAL peripheral handle, and the callback ID. [..] This function allows to reset following callbacks: (+) TearingEffectCallback : DSI Tearing Effect Callback. (+) EndOfRefreshCallback : DSI End Of Refresh Callback. (+) ErrorCallback : DSI Error Callback (+) MspInitCallback : DSI MspInit. (+) MspDeInitCallback : DSI MspDeInit. [..] By default, after the HAL_DSI_Init and when the state is HAL_DSI_STATE_RESET all callbacks are set to the corresponding weak functions: examples HAL_DSI_TearingEffectCallback(), HAL_DSI_EndOfRefreshCallback(). Exception done for MspInit and MspDeInit functions that are respectively reset to the legacy weak (surcharged) functions in the HAL_DSI_Init() and HAL_DSI_DeInit() only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_DSI_Init() and HAL_DSI_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in HAL_DSI_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_DSI_STATE_READY or HAL_DSI_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_DSI_RegisterCallback() before calling HAL_DSI_DeInit() or HAL_DSI_Init() function. [..] When The compilation define USE_HAL_DSI_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
