RTEMS 6.1-rc1
This file provides firmware functions to manage the following functionalities of the Digital Filter for Sigma-Delta Modulators (DFSDM) peripherals: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] *** Channel initialization *** ============================== [..] (#) User has first to initialize channels (before filters initialization). (#) As prerequisite, fill in the HAL_DFSDM_ChannelMspInit() : (++) Enable DFSDMz clock interface with __HAL_RCC_DFSDMz_CLK_ENABLE(). (++) Enable the clocks for the DFSDMz GPIOS with __HAL_RCC_GPIOx_CLK_ENABLE(). (++) Configure these DFSDMz pins in alternate mode using HAL_GPIO_Init(). (++) If interrupt mode is used, enable and configure DFSDMz_FLT0 global interrupt with HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ(). (#) Configure the output clock, input, serial interface, analog watchdog, offset and data right bit shift parameters for this channel using the HAL_DFSDM_ChannelInit() function. *** Channel clock absence detector *** ====================================== [..] (#) Start clock absence detector using HAL_DFSDM_ChannelCkabStart() or HAL_DFSDM_ChannelCkabStart_IT(). (#) In polling mode, use HAL_DFSDM_ChannelPollForCkab() to detect the clock absence. (#) In interrupt mode, HAL_DFSDM_ChannelCkabCallback() will be called if clock absence is detected. (#) Stop clock absence detector using HAL_DFSDM_ChannelCkabStop() or HAL_DFSDM_ChannelCkabStop_IT(). (#) Please note that the same mode (polling or interrupt) has to be used for all channels because the channels are sharing the same interrupt. (#) Please note also that in interrupt mode, if clock absence detector is stopped for one channel, interrupt will be disabled for all channels. *** Channel short circuit detector *** ====================================== [..] (#) Start short circuit detector using HAL_DFSDM_ChannelScdStart() or or HAL_DFSDM_ChannelScdStart_IT(). (#) In polling mode, use HAL_DFSDM_ChannelPollForScd() to detect short circuit. (#) In interrupt mode, HAL_DFSDM_ChannelScdCallback() will be called if short circuit is detected. (#) Stop short circuit detector using HAL_DFSDM_ChannelScdStop() or or HAL_DFSDM_ChannelScdStop_IT(). (#) Please note that the same mode (polling or interrupt) has to be used for all channels because the channels are sharing the same interrupt. (#) Please note also that in interrupt mode, if short circuit detector is stopped for one channel, interrupt will be disabled for all channels. *** Channel analog watchdog value *** ===================================== [..] (#) Get analog watchdog filter value of a channel using HAL_DFSDM_ChannelGetAwdValue(). *** Channel offset value *** ===================================== [..] (#) Modify offset value of a channel using HAL_DFSDM_ChannelModifyOffset(). *** Filter initialization *** ============================= [..] (#) After channel initialization, user has to init filters. (#) As prerequisite, fill in the HAL_DFSDM_FilterMspInit() : (++) If interrupt mode is used , enable and configure DFSDMz_FLTx global interrupt with HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ(). Please note that DFSDMz_FLT0 global interrupt could be already enabled if interrupt is used for channel. (++) If DMA mode is used, configure DMA with HAL_DMA_Init() and link it with DFSDMz filter handle using __HAL_LINKDMA(). (#) Configure the regular conversion, injected conversion and filter parameters for this filter using the HAL_DFSDM_FilterInit() function. *** Filter regular channel conversion *** ========================================= [..] (#) Select regular channel and enable/disable continuous mode using HAL_DFSDM_FilterConfigRegChannel(). (#) Start regular conversion using HAL_DFSDM_FilterRegularStart(), HAL_DFSDM_FilterRegularStart_IT(), HAL_DFSDM_FilterRegularStart_DMA() or HAL_DFSDM_FilterRegularMsbStart_DMA(). (#) In polling mode, use HAL_DFSDM_FilterPollForRegConversion() to detect the end of regular conversion. (#) In interrupt mode, HAL_DFSDM_FilterRegConvCpltCallback() will be called at the end of regular conversion. (#) Get value of regular conversion and corresponding channel using HAL_DFSDM_FilterGetRegularValue(). (#) In DMA mode, HAL_DFSDM_FilterRegConvHalfCpltCallback() and HAL_DFSDM_FilterRegConvCpltCallback() will be called respectively at the half transfer and at the transfer complete. Please note that HAL_DFSDM_FilterRegConvHalfCpltCallback() will be called only in DMA circular mode. (#) Stop regular conversion using HAL_DFSDM_FilterRegularStop(), HAL_DFSDM_FilterRegularStop_IT() or HAL_DFSDM_FilterRegularStop_DMA(). *** Filter injected channels conversion *** =========================================== [..] (#) Select injected channels using HAL_DFSDM_FilterConfigInjChannel(). (#) Start injected conversion using HAL_DFSDM_FilterInjectedStart(), HAL_DFSDM_FilterInjectedStart_IT(), HAL_DFSDM_FilterInjectedStart_DMA() or HAL_DFSDM_FilterInjectedMsbStart_DMA(). (#) In polling mode, use HAL_DFSDM_FilterPollForInjConversion() to detect the end of injected conversion. (#) In interrupt mode, HAL_DFSDM_FilterInjConvCpltCallback() will be called at the end of injected conversion. (#) Get value of injected conversion and corresponding channel using HAL_DFSDM_FilterGetInjectedValue(). (#) In DMA mode, HAL_DFSDM_FilterInjConvHalfCpltCallback() and HAL_DFSDM_FilterInjConvCpltCallback() will be called respectively at the half transfer and at the transfer complete. Please note that HAL_DFSDM_FilterInjConvCpltCallback() will be called only in DMA circular mode. (#) Stop injected conversion using HAL_DFSDM_FilterInjectedStop(), HAL_DFSDM_FilterInjectedStop_IT() or HAL_DFSDM_FilterInjectedStop_DMA(). *** Filter analog watchdog *** ============================== [..] (#) Start filter analog watchdog using HAL_DFSDM_FilterAwdStart_IT(). (#) HAL_DFSDM_FilterAwdCallback() will be called if analog watchdog occurs. (#) Stop filter analog watchdog using HAL_DFSDM_FilterAwdStop_IT(). *** Filter extreme detector *** =============================== [..] (#) Start filter extreme detector using HAL_DFSDM_FilterExdStart(). (#) Get extreme detector maximum value using HAL_DFSDM_FilterGetExdMaxValue(). (#) Get extreme detector minimum value using HAL_DFSDM_FilterGetExdMinValue(). (#) Start filter extreme detector using HAL_DFSDM_FilterExdStop(). *** Filter conversion time *** ============================== [..] (#) Get conversion time value using HAL_DFSDM_FilterGetConvTimeValue(). *** Callback registration *** ============================= [..] The compilation define USE_HAL_DFSDM_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use functions HAL_DFSDM_Channel_RegisterCallback(), HAL_DFSDM_Filter_RegisterCallback() or HAL_DFSDM_Filter_RegisterAwdCallback() to register a user callback. [..] Function HAL_DFSDM_Channel_RegisterCallback() allows to register following callbacks: (+) CkabCallback : DFSDM channel clock absence detection callback. (+) ScdCallback : DFSDM channel short circuit detection callback. (+) MspInitCallback : DFSDM channel MSP init callback. (+) MspDeInitCallback : DFSDM channel MSP de-init callback. [..] This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Function HAL_DFSDM_Filter_RegisterCallback() allows to register following callbacks: (+) RegConvCpltCallback : DFSDM filter regular conversion complete callback. (+) RegConvHalfCpltCallback : DFSDM filter half regular conversion complete callback. (+) InjConvCpltCallback : DFSDM filter injected conversion complete callback. (+) InjConvHalfCpltCallback : DFSDM filter half injected conversion complete callback. (+) ErrorCallback : DFSDM filter error callback. (+) MspInitCallback : DFSDM filter MSP init callback. (+) MspDeInitCallback : DFSDM filter MSP de-init callback. [..] This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] For specific DFSDM filter analog watchdog callback use dedicated register callback: HAL_DFSDM_Filter_RegisterAwdCallback(). [..] Use functions HAL_DFSDM_Channel_UnRegisterCallback() or HAL_DFSDM_Filter_UnRegisterCallback() to reset a callback to the default weak function. [..] HAL_DFSDM_Channel_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. [..] This function allows to reset following callbacks: (+) CkabCallback : DFSDM channel clock absence detection callback. (+) ScdCallback : DFSDM channel short circuit detection callback. (+) MspInitCallback : DFSDM channel MSP init callback. (+) MspDeInitCallback : DFSDM channel MSP de-init callback. [..] HAL_DFSDM_Filter_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. [..] This function allows to reset following callbacks: (+) RegConvCpltCallback : DFSDM filter regular conversion complete callback. (+) RegConvHalfCpltCallback : DFSDM filter half regular conversion complete callback. (+) InjConvCpltCallback : DFSDM filter injected conversion complete callback. (+) InjConvHalfCpltCallback : DFSDM filter half injected conversion complete callback. (+) ErrorCallback : DFSDM filter error callback. (+) MspInitCallback : DFSDM filter MSP init callback. (+) MspDeInitCallback : DFSDM filter MSP de-init callback. [..] For specific DFSDM filter analog watchdog callback use dedicated unregister callback: HAL_DFSDM_Filter_UnRegisterAwdCallback(). [..] By default, after the call of init function and if the state is RESET all callbacks are reset to the corresponding legacy weak functions: examples HAL_DFSDM_ChannelScdCallback(), HAL_DFSDM_FilterErrorCallback(). Exception done for MspInit and MspDeInit callbacks that are respectively reset to the legacy weak functions in the init and de-init only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the init and de-init keep and use the user MspInit/MspDeInit callbacks (registered beforehand) [..] Callbacks can be registered/unregistered in READY state only. Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the init/de-init. In that case first register the MspInit/MspDeInit user callbacks using HAL_DFSDM_Channel_RegisterCallback() or HAL_DFSDM_Filter_RegisterCallback() before calling init or de-init function. [..] When The compilation define USE_HAL_DFSDM_REGISTER_CALLBACKS is set to 0 or not defined, the callback registering feature is not available and weak callbacks are used.
