RTEMS 6.1-rc1
stm32h7xx_hal_crc.c File Reference
CRC HAL module driver. This file provides firmware functions to manage the following functionalities of the Cyclic Redundancy Check (CRC) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • Peripheral Control functions
  • Peripheral State functions
Attention
                    ##### How to use this driver #####
        (+) Enable CRC AHB clock using __HAL_RCC_CRC_CLK_ENABLE();
        (+) Initialize CRC calculator
            (++) specify generating polynomial (peripheral default or non-default one)
            (++) specify initialization value (peripheral default or non-default one)
            (++) specify input data format
            (++) specify input or output data inversion mode if any
        (+) Use HAL_CRC_Accumulate() function to compute the CRC value of the
            input data buffer starting with the previously computed CRC as
        (+) Use HAL_CRC_Calculate() function to compute the CRC value of the
            input data buffer starting with the defined initialization value
            (default or non-default) to initiate CRC calculation
