RTEMS 6.1-rc1
COMP HAL module driver. This file provides firmware functions to manage the following functionalities of the COMP peripheral: More...
#include "stm32h7xx_hal.h"
================================================================================ ##### COMP Peripheral features ##### ================================================================================ [..] The STM32H7xx device family integrates two analog comparators instances COMP1 and COMP2: (#) The COMP input minus (inverting input) and input plus (non inverting input) can be set to internal references or to GPIO pins (refer to GPIO list in reference manual). (#) The COMP output level is available using HAL_COMP_GetOutputLevel() and can be redirected to other peripherals: GPIO pins (in mode alternate functions for comparator), timers. (refer to GPIO list in reference manual). (#) Pairs of comparators instances can be combined in window mode (2 consecutive instances odd and even COMP<x> and COMP<x+1>). (#) The comparators have interrupt capability through the EXTI controller with wake-up from sleep and stop modes: (++) COMP1 is internally connected to EXTI Line 20 (++) COMP2 is internally connected to EXTI Line 21 [..] From the corresponding IRQ handler, the right interrupt source can be retrieved using macro __HAL_COMP_COMP1_EXTI_GET_FLAG() and __HAL_COMP_COMP2_EXTI_GET_FLAG(). ##### How to use this driver ##### ================================================================================ [..] This driver provides functions to configure and program the comparator instances of STM32H7xx devices. To use the comparator, perform the following steps: (#) Initialize the COMP low level resources by implementing the HAL_COMP_MspInit(): (++) Configure the GPIO connected to comparator inputs plus and minus in analog mode using HAL_GPIO_Init(). (++) If needed, configure the GPIO connected to comparator output in alternate function mode using HAL_GPIO_Init(). (++) If required enable the COMP interrupt by configuring and enabling EXTI line in Interrupt mode and selecting the desired sensitivity level using HAL_GPIO_Init() function. After that enable the comparator interrupt vector using HAL_NVIC_EnableIRQ() function. (#) Configure the comparator using HAL_COMP_Init() function: (++) Select the input minus (inverting input) (++) Select the input plus (non-inverting input) (++) Select the hysteresis (++) Select the blanking source (++) Select the output polarity (++) Select the power mode (++) Select the window mode -@@- HAL_COMP_Init() calls internally __HAL_RCC_SYSCFG_CLK_ENABLE() to enable internal control clock of the comparators. However, this is a legacy strategy. Therefore, for compatibility anticipation, it is recommended to implement __HAL_RCC_SYSCFG_CLK_ENABLE() in "HAL_COMP_MspInit()". In STM32H7,COMP clock enable __HAL_RCC_COMP12_CLK_ENABLE() must be implemented by user in "HAL_COMP_MspInit()". (#) Reconfiguration on-the-fly of comparator can be done by calling again function HAL_COMP_Init() with new input structure parameters values. (#) Enable the comparator using HAL_COMP_Start() or HAL_COMP_Start_IT()to be enabled with the interrupt through NVIC of the CPU. Note: HAL_COMP_Start_IT() must be called after each interrupt otherwise the interrupt mode will stay disabled. (#) Use HAL_COMP_GetOutputLevel() or HAL_COMP_TriggerCallback() functions to manage comparator outputs(output level or events) (#) Disable the comparator using HAL_COMP_Stop() or HAL_COMP_Stop_IT() to disable the interrupt too. (#) De-initialize the comparator using HAL_COMP_DeInit() function. (#) For safety purpose, comparator configuration can be locked using HAL_COMP_Lock() function. The only way to unlock the comparator is a device hardware reset. *** Callback registration *** ============================================= [..] The compilation flag USE_HAL_COMP_REGISTER_CALLBACKS, when set to 1, allows the user to configure dynamically the driver callbacks. Use Functions HAL_COMP_RegisterCallback() to register an interrupt callback. [..] Function HAL_COMP_RegisterCallback() allows to register following callbacks: (+) TriggerCallback : callback for COMP trigger. (+) MspInitCallback : callback for Msp Init. (+) MspDeInitCallback : callback for Msp DeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function HAL_COMP_UnRegisterCallback to reset a callback to the default weak function. [..] HAL_COMP_UnRegisterCallback takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TriggerCallback : callback for COMP trigger. (+) MspInitCallback : callback for Msp Init. (+) MspDeInitCallback : callback for Msp DeInit. [..] By default, after the HAL_COMP_Init() and when the state is HAL_COMP_STATE_RESET all callbacks are set to the corresponding weak functions: example HAL_COMP_TriggerCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak functions in the HAL_COMP_Init()/ HAL_COMP_DeInit() only when these callbacks are null (not registered beforehand). [..] If MspInit or MspDeInit are not null, the HAL_COMP_Init()/ HAL_COMP_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state. [..] Callbacks can be registered/unregistered in HAL_COMP_STATE_READY state only. Exception done MspInit/MspDeInit functions that can be registered/unregistered in HAL_COMP_STATE_READY or HAL_COMP_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. [..] Then, the user first registers the MspInit/MspDeInit user callbacks using HAL_COMP_RegisterCallback() before calling HAL_COMP_DeInit() or HAL_COMP_Init() function. [..] When the compilation flag USE_HAL_COMP_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
Table 1. COMP inputs and output for STM32H7xx devices +------------------------------------------------------—+
COMP1 | COMP2 | ||
IO1 | PB0 | PE9 | |
Input plus | IO2 | PB2 | PE11 |
|-------------—|-------------—|--------------------—| | | 1/4 VrefInt | Available | Available | | | 1/2 VrefInt | Available | Available | | | 3/4 VrefInt | Available | Available | | Input minus | VrefInt | Available | Available | | | DAC1 channel 1 | Available | Available | | | DAC1 channel 2 | Available | Available | | | IO1 | PB1 | PE10 |
IO2 | PC4 | PE7 | |
+------------------------------------------------------—+ | Output | | PC5 (1) | PE8 (1) | | | | PE12 (1) | PE13 (1) | | | | TIM (2) | TIM (2) | +------------------------------------------------------—+ (1) GPIO must be set to alternate function for comparator (2) Comparators output to timers is set in timers instances.
