RTEMS 6.1-rc1
CEC HAL module driver. This file provides firmware functions to manage the following functionalities of the High Definition Multimedia Interface Consumer Electronics Control Peripheral (CEC). More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### How to use this driver ##### =============================================================================== [..] The CEC HAL driver can be used as follow: (#) Declare a CEC_HandleTypeDef handle structure. (#) Initialize the CEC low level resources by implementing the HAL_CEC_MspInit ()API: (##) Enable the CEC interface clock. (##) CEC pins configuration: (+++) Enable the clock for the CEC GPIOs. (+++) Configure these CEC pins as alternate function pull-up. (##) NVIC configuration if you need to use interrupt process (HAL_CEC_Transmit_IT() and HAL_CEC_Receive_IT() APIs): (+++) Configure the CEC interrupt priority. (+++) Enable the NVIC CEC IRQ handle. (+++) The specific CEC interrupts (Transmission complete interrupt, RXNE interrupt and Error Interrupts) will be managed using the macros __HAL_CEC_ENABLE_IT() and __HAL_CEC_DISABLE_IT() inside the transmit and receive process. (#) Program the Signal Free Time (SFT) and SFT option, Tolerance, reception stop in in case of Bit Rising Error, Error-Bit generation conditions, device logical address and Listen mode in the hcec Init structure. (#) Initialize the CEC registers by calling the HAL_CEC_Init() API. [..] (@) This API (HAL_CEC_Init()) configures also the low level Hardware (GPIO, CLOCK, CORTEX...etc) by calling the customed HAL_CEC_MspInit() API. *** Callback registration *** ============================================= The compilation define USE_HAL_CEC_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use Functions HAL_CEC_RegisterCallback() or HAL_CEC_RegisterXXXCallback() to register an interrupt callback. Function HAL_CEC_RegisterCallback() allows to register following callbacks: (+) TxCpltCallback : Tx Transfer completed callback. (+) ErrorCallback : callback for error detection. (+) MspInitCallback : CEC MspInit. (+) MspDeInitCallback : CEC MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. For specific callback HAL_CEC_RxCpltCallback use dedicated register callbacks HAL_CEC_RegisterRxCpltCallback(). Use function HAL_CEC_UnRegisterCallback() to reset a callback to the default weak function. HAL_CEC_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxCpltCallback : Tx Transfer completed callback. (+) ErrorCallback : callback for error detection. (+) MspInitCallback : CEC MspInit. (+) MspDeInitCallback : CEC MspDeInit. For callback HAL_CEC_RxCpltCallback use dedicated unregister callback : HAL_CEC_UnRegisterRxCpltCallback(). By default, after the HAL_CEC_Init() and when the state is HAL_CEC_STATE_RESET all callbacks are set to the corresponding weak functions : examples HAL_CEC_TxCpltCallback() , HAL_CEC_RxCpltCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak function in the HAL_CEC_Init()/ HAL_CEC_DeInit() only when these callbacks are null (not registered beforehand). if not, MspInit or MspDeInit are not null, the HAL_CEC_Init() / HAL_CEC_DeInit() keep and use the user MspInit/MspDeInit functions (registered beforehand) Callbacks can be registered/unregistered in HAL_CEC_STATE_READY state only. Exception done MspInit/MspDeInit callbacks that can be registered/unregistered in HAL_CEC_STATE_READY or HAL_CEC_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_CEC_RegisterCallback() before calling HAL_CEC_DeInit() or HAL_CEC_Init() function. When the compilation define USE_HAL_CEC_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
