15#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H
16#define LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H
22#define STM32F4_TIMER_CR1_CKD_DIV 0x0300
23#define STM32F4_TIMER_CR1_CKD_DIV1 0x0000
24#define STM32F4_TIMER_CR1_CKD_DIV2 0x0100
25#define STM32F4_TIMER_CR1_CKD_DIV3 0x0200
26#define STM32F4_TIMER_CR1_ARPE BSP_BIT16(7)
27#define STM32F4_TIMER_CR1_CMS 0x0060
28#define STM32F4_TIMER_CR1_CMS_EDGE 0x0000
29#define STM32F4_TIMER_CR1_CMS_CENTER1 0x0020
30#define STM32F4_TIMER_CR1_CMS_CENTER2 0x0040
31#define STM32F4_TIMER_CR1_CMS_CENTER3 0x0060
32#define STM32F4_TIMER_CR1_DIR BSP_BIT16(4)
33#define STM32F4_TIMER_CR1_DIR_UP 0x0000
34#define STM32F4_TIMER_CR1_DIR_DOWN 0x0010
35#define STM32F4_TIMER_CR1_DIR_OPM 0x0008
36#define STM32F4_TIMER_CR1_DIR_OPM_CONT 0x0000
37#define STM32F4_TIMER_CR1_DIR_OPM_STOP 0x0008
38#define STM32F4_TIMER_CR1_DIR_URS 0x0004
39#define STM32F4_TIMER_CR1_DIR_UDIS 0x0002
40#define STM32F4_TIMER_CR1_DIR_UDIS_EN 0x0000
41#define STM32F4_TIMER_CR1_DIR_UDIS_DIS 0x0002
42#define STM32F4_TIMER_CR1_CEN 0x0001
49#define STM32F4_TIMER_DIER_TDE BSP_BIT16(14)
50#define STM32F4_TIMER_DIER_CC4DE BSP_BIT16(12)
51#define STM32F4_TIMER_DIER_CC3DE BSP_BIT16(11)
52#define STM32F4_TIMER_DIER_CC2DE BSP_BIT16(10)
53#define STM32F4_TIMER_DIER_CC1DE BSP_BIT16(9)
54#define STM32F4_TIMER_DIER_UDE BSP_BIT16(8)
55#define STM32F4_TIMER_DIER_TIE BSP_BIT16(6)
56#define STM32F4_TIMER_DIER_CC4IE BSP_BIT16(4)
57#define STM32F4_TIMER_DIER_CC3IE BSP_BIT16(3)
58#define STM32F4_TIMER_DIER_CC2IE BSP_BIT16(2)
59#define STM32F4_TIMER_DIER_CC1IE BSP_BIT16(1)
60#define STM32F4_TIMER_DIER_UIE BSP_BIT16(0)
64#define STM32F4_TIMER_SR_CC4OF BSP_BIT16(12)
65#define STM32F4_TIMER_SR_CC3OF BSP_BIT16(11)
66#define STM32F4_TIMER_SR_CC2OF BSP_BIT16(10)
67#define STM32F4_TIMER_SR_CC1OF BSP_BIT16(9)
68#define STM32F4_TIMER_SR_TIF BSP_BIT16(6)
69#define STM32F4_TIMER_SR_CC4IF BSP_BIT16(4)
70#define STM32F4_TIMER_SR_CC3IF BSP_BIT16(3)
71#define STM32F4_TIMER_SR_CC2IF BSP_BIT16(2)
72#define STM32F4_TIMER_SR_CC1IF BSP_BIT16(1)
73#define STM32F4_TIMER_SR_UIF BSP_BIT16(0)
76#define STM32F4_TIMER_EGR_TG BSP_BIT16(6)
77#define STM32F4_TIMER_EGR_CC4G BSP_BIT16(4)
78#define STM32F4_TIMER_EGR_CC3G BSP_BIT16(3)
79#define STM32F4_TIMER_EGR_CC2G BSP_BIT16(2)
80#define STM32F4_TIMER_EGR_CC1G BSP_BIT16(1)
81#define STM32F4_TIMER_EGR_UG BSP_BIT16(0)
84#define STM32F4_TIMER_CCMR1_OC2CE BSP_BIT16(15)
85#define STM32F4_TIMER_CCMR1_OC2M(val) BSP_FLD16(val, 12, 14)
86#define STM32F4_TIMER_CCMR1_OC2M_GET(reg) BSP_FLD16GET(reg, 12, 14)
87#define STM32F4_TIMER_CCMR1_OC2M_SET(reg, val) BSP_FLD16SET(reg, val, 12, 14)
88#define STM32F4_TIMER_CCMR1_OC2M_FROZEN STM32F4_TIMER_CCMR1_OC2M(0)
89#define STM32F4_TIMER_CCMR1_OC2M_ACTIVE STM32F4_TIMER_CCMR1_OC2M(1)
90#define STM32F4_TIMER_CCMR1_OC2M_INACTIVE STM32F4_TIMER_CCMR1_OC2M(2)
91#define STM32F4_TIMER_CCMR1_OC2M_TOGGLE STM32F4_TIMER_CCMR1_OC2M(3)
92#define STM32F4_TIMER_CCMR1_OC2M_FORCE_LOW STM32F4_TIMER_CCMR1_OC2M(4)
93#define STM32F4_TIMER_CCMR1_OC2M_FORCE_HIGH STM32F4_TIMER_CCMR1_OC2M(5)
94#define STM32F4_TIMER_CCMR1_OC2M_PWM1 STM32F4_TIMER_CCMR1_OC2M(6)
95#define STM32F4_TIMER_CCMR1_OC2M_PWM2 STM32F4_TIMER_CCMR1_OC2M(7)
96#define STM32F4_TIMER_CCMR1_OC2PE BSP_BIT16(11)
97#define STM32F4_TIMER_CCMR1_OC2FE BSP_BIT16(10)
98#define STM32F4_TIMER_CCMR1_CC2S(val) BSP_FLD16(val, 8, 9)
99#define STM32F4_TIMER_CCMR1_CC2S_GET(reg) BSP_FLD16GET(reg, 8, 9)
100#define STM32F4_TIMER_CCMR1_CC2S_SET(reg, val) BSP_FLD16SET(reg, val, 8, 9)
101#define STM32F4_TIMER_CCMR1_CC2S_OUTPUT STM32F4_TIMER_CCMR1_OC2S(0)
102#define STM32F4_TIMER_CCMR1_CC2S_TI2 STM32F4_TIMER_CCMR1_OC2S(1)
103#define STM32F4_TIMER_CCMR1_CC2S_TI1 STM32F4_TIMER_CCMR1_OC2S(2)
104#define STM32F4_TIMER_CCMR1_CC2S_TRC STM32F4_TIMER_CCMR1_OC2S(3)
105#define STM32F4_TIMER_CCMR1_OC1CE BSP_BIT16(7)
106#define STM32F4_TIMER_CCMR1_OC1M(val) BSP_FLD16(val, 4, 6)
107#define STM32F4_TIMER_CCMR1_OC1M_GET(reg) BSP_FLD16GET(reg, 4, 6)
108#define STM32F4_TIMER_CCMR1_OC1M_SET(reg, val) BSP_FLD16SET(reg, val, 4, 6)
109#define STM32F4_TIMER_CCMR1_OC1M_FROZEN STM32F4_TIMER_CCMR1_OC1M(0)
110#define STM32F4_TIMER_CCMR1_OC1M_ACTIVE STM32F4_TIMER_CCMR1_OC1M(1)
111#define STM32F4_TIMER_CCMR1_OC1M_INACTIVE STM32F4_TIMER_CCMR1_OC1M(2)
112#define STM32F4_TIMER_CCMR1_OC1M_TOGGLE STM32F4_TIMER_CCMR1_OC1M(3)
113#define STM32F4_TIMER_CCMR1_OC1M_FORCE_LOW STM32F4_TIMER_CCMR1_OC1M(4)
114#define STM32F4_TIMER_CCMR1_OC1M_FORCE_HIGH STM32F4_TIMER_CCMR1_OC1M(5)
115#define STM32F4_TIMER_CCMR1_OC1M_PWM1 STM32F4_TIMER_CCMR1_OC1M(6)
116#define STM32F4_TIMER_CCMR1_OC1M_PWM2 STM32F4_TIMER_CCMR1_OC1M(7)
117#define STM32F4_TIMER_CCMR1_OC1PE BSP_BIT16(3)
118#define STM32F4_TIMER_CCMR1_OC1FE BSP_BIT16(2)
119#define STM32F4_TIMER_CCMR1_CC1S(val) BSP_FLD16(val, 0, 1)
120#define STM32F4_TIMER_CCMR1_CC1S_GET(reg) BSP_FLD16GET(reg, 0, 1)
121#define STM32F4_TIMER_CCMR1_CC1S_SET(reg, val) BSP_FLD16SET(reg, val, 0, 1)
122#define STM32F4_TIMER_CCMR1_CC1S_OUTPUT STM32F4_TIMER_CCMR1_OC1S(0)
123#define STM32F4_TIMER_CCMR1_CC1S_TI2 STM32F4_TIMER_CCMR1_OC1S(1)
124#define STM32F4_TIMER_CCMR1_CC1S_TI1 STM32F4_TIMER_CCMR1_OC1S(2)
125#define STM32F4_TIMER_CCMR1_CC1S_TRC STM32F4_TIMER_CCMR1_OC1S(3)
126 uint16_t reserved_1a;
128#define STM32F4_TIMER_CCMR2_OC4CE BSP_BIT16(15)
129#define STM32F4_TIMER_CCMR2_OC4M(val) BSP_FLD16(val, 12, 14)
130#define STM32F4_TIMER_CCMR2_OC4M_GET(reg) BSP_FLD16GET(reg, 12, 14)
131#define STM32F4_TIMER_CCMR2_OC4M_SET(reg, val) BSP_FLD16SET(reg, val, 12, 14)
132#define STM32F4_TIMER_CCMR2_OC4M_FROZEN STM32F4_TIMER_CCMR2_OC4M(0)
133#define STM32F4_TIMER_CCMR2_OC4M_ACTIVE STM32F4_TIMER_CCMR2_OC4M(1)
134#define STM32F4_TIMER_CCMR2_OC4M_INACTIVE STM32F4_TIMER_CCMR2_OC4M(2)
135#define STM32F4_TIMER_CCMR2_OC4M_TOGGLE STM32F4_TIMER_CCMR2_OC4M(3)
136#define STM32F4_TIMER_CCMR2_OC4M_FORCE_LOW STM32F4_TIMER_CCMR2_OC4M(4)
137#define STM32F4_TIMER_CCMR2_OC4M_FORCE_HIGH STM32F4_TIMER_CCMR2_OC4M(5)
138#define STM32F4_TIMER_CCMR2_OC4M_PWM1 STM32F4_TIMER_CCMR2_OC4M(6)
139#define STM32F4_TIMER_CCMR2_OC4M_PWM2 STM32F4_TIMER_CCMR2_OC4M(7)
140#define STM32F4_TIMER_CCMR2_OC4PE BSP_BIT16(11)
141#define STM32F4_TIMER_CCMR2_OC4FE BSP_BIT16(10)
142#define STM32F4_TIMER_CCMR2_CC4S(val) BSP_FLD16(val, 8, 9)
143#define STM32F4_TIMER_CCMR2_CC4S_GET(reg) BSP_FLD16GET(reg, 8, 9)
144#define STM32F4_TIMER_CCMR2_CC4S_SET(reg, val) BSP_FLD16SET(reg, val, 8, 9)
145#define STM32F4_TIMER_CCMR2_CC4S_OUTPUT STM32F4_TIMER_CCMR2_OC4S(0)
146#define STM32F4_TIMER_CCMR2_CC4S_TI2 STM32F4_TIMER_CCMR2_OC4S(1)
147#define STM32F4_TIMER_CCMR2_CC4S_TI1 STM32F4_TIMER_CCMR2_OC4S(2)
148#define STM32F4_TIMER_CCMR2_CC4S_TRC STM32F4_TIMER_CCMR2_OC4S(3)
149#define STM32F4_TIMER_CCMR2_OC3CE BSP_BIT16(7)
150#define STM32F4_TIMER_CCMR2_OC3M(val) BSP_FLD16(val, 4, 6)
151#define STM32F4_TIMER_CCMR2_OC3M_GET(reg) BSP_FLD16GET(reg, 4, 6)
152#define STM32F4_TIMER_CCMR2_OC3M_SET(reg, val) BSP_FLD16SET(reg, val, 4, 6)
153#define STM32F4_TIMER_CCMR2_OC3M_FROZEN STM32F4_TIMER_CCMR2_OC3M(0)
154#define STM32F4_TIMER_CCMR2_OC3M_ACTIVE STM32F4_TIMER_CCMR2_OC3M(1)
155#define STM32F4_TIMER_CCMR2_OC3M_INACTIVE STM32F4_TIMER_CCMR2_OC3M(2)
156#define STM32F4_TIMER_CCMR2_OC3M_TOGGLE STM32F4_TIMER_CCMR2_OC3M(3)
157#define STM32F4_TIMER_CCMR2_OC3M_FORCE_LOW STM32F4_TIMER_CCMR2_OC3M(4)
158#define STM32F4_TIMER_CCMR2_OC3M_FORCE_HIGH STM32F4_TIMER_CCMR2_OC3M(5)
159#define STM32F4_TIMER_CCMR2_OC3M_PWM1 STM32F4_TIMER_CCMR2_OC3M(6)
160#define STM32F4_TIMER_CCMR2_OC3M_PWM2 STM32F4_TIMER_CCMR2_OC3M(7)
161#define STM32F4_TIMER_CCMR2_OC3PE BSP_BIT16(3)
162#define STM32F4_TIMER_CCMR2_OC3FE BSP_BIT16(2)
163#define STM32F4_TIMER_CCMR2_CC3S(val) BSP_FLD16(val, 0, 1)
164#define STM32F4_TIMER_CCMR2_CC3S_GET(reg) BSP_FLD16GET(reg, 0, 1)
165#define STM32F4_TIMER_CCMR2_CC3S_SET(reg, val) BSP_FLD16SET(reg, val, 0, 1)
166#define STM32F4_TIMER_CCMR2_CC3S_OUTPUT STM32F4_TIMER_CCMR2_OC3S(0)
167#define STM32F4_TIMER_CCMR2_CC3S_TI2 STM32F4_TIMER_CCMR2_OC3S(1)
168#define STM32F4_TIMER_CCMR2_CC3S_TI1 STM32F4_TIMER_CCMR2_OC3S(2)
169#define STM32F4_TIMER_CCMR2_CC3S_TRC STM32F4_TIMER_CCMR2_OC3S(3)
170 uint16_t reserved_1e;
172#define STM32F4_TIMER_CCER_CC4NP BSP_BIT16(15)
173#define STM32F4_TIMER_CCER_CC4P BSP_BIT16(13)
174#define STM32F4_TIMER_CCER_CC4E BSP_BIT16(12)
175#define STM32F4_TIMER_CCER_CC3NP BSP_BIT16(11)
176#define STM32F4_TIMER_CCER_CC3P BSP_BIT16(9)
177#define STM32F4_TIMER_CCER_CC3E BSP_BIT16(8)
178#define STM32F4_TIMER_CCER_CC2NP BSP_BIT16(7)
179#define STM32F4_TIMER_CCER_CC2P BSP_BIT16(5)
180#define STM32F4_TIMER_CCER_CC2E BSP_BIT16(4)
181#define STM32F4_TIMER_CCER_CC1NP BSP_BIT16(3)
182#define STM32F4_TIMER_CCER_CC1P BSP_BIT16(1)
183#define STM32F4_TIMER_CCER_CC1E BSP_BIT16(0)
184 uint16_t reserved_22;
186#define STM32F4_TIMER_DR(val) BSP_FLD32(val, 0, 31)
187#define STM32F4_TIMER_DR_GET(reg) BSP_FLD32GET(reg, 0, 31)
188#define STM32F4_TIMER_DR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
190 uint16_t reserved_2a;
196 uint16_t reserved_46;
198 uint16_t reserved_4a;
200 uint16_t reserved_4e;
202 uint16_t reserved_52;
unsigned short int uint16 __attribute__((__may_alias__))
Perform a 32-bit endian conversion.
Definition: mcf5282.h:37
This header file provides utility macros for BSPs.
Definition: stm32f4xxxx_tim.h:20
