RTEMS
6.1-rc1
bsps
powerpc
include
libcpu
spr.h
1
2
* spr.h -- Access to special purpose registers.
3
4
* Copyright (C) 1998 Gabriel Paubert, paubert@iram.es
5
6
* Modified to compile in RTEMS development environment
7
* by Eric Valette
8
9
* Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
10
11
* The license and distribution terms for this file may be
12
* found in the file LICENSE in this distribution or at
13
* http://www.rtems.org/license/LICENSE.
14
15
16
17
18
#ifndef _LIBCPU_SPR_H
19
#define _LIBCPU_SPR_H
20
21
rtems/powerpc/registers.h
22
23
#define __MFSPR(reg, val) \
24
__asm__ __volatile__("mfspr %0,"
#reg : "=r" (val))
25
26
#define __MTSPR(val, reg) \
27
__asm__ __volatile__("mtspr "
#reg",%0" : : "r" (val))
28
29
30
#define SPR_RW(reg) \
31
static inline unsigned long _read_##reg(void) \
32
33
unsigned long val;\
34
__MFSPR(reg, val);\
35
return val;\
36
37
static inline void _write_##reg(unsigned long val)\
38
39
__MTSPR(val,reg);\
40
return;\
41
42
43
#define SPR_RO(reg) \
44
45
46
unsigned long val;\
47
__MFSPR(reg,val);\
48
return val;\
49
50
51
static
inline
unsigned
long
_read_MSR(
void
52
53
unsigned
long
val;
54
__asm__
volatile
"mfmsr %0"
"=r"
(val));
55
return
val;
56
57
58
static
inline
void
_write_MSR(
unsigned
long
val)
59
60
__asm__
volatile
"mtmsr %0"
"r"
(val));
61
return
62
63
64
static
inline
unsigned
long
_read_SR(
void
* va)
65
66
unsigned
long
val;
67
__asm__
volatile
68
".machine \"push\"\n"
69
".machine \"any\"\n"
70
"mfsrin %0,%1\n"
71
".machine \"pop\""
72
"=r"
(val) :
73
"r"
(va)
74
75
return
val;
76
77
78
static
inline
void
_write_SR(
unsigned
long
val,
void
* va)
79
80
__asm__
volatile
81
82
83
"mtsrin %0,%1\n"
84
".machine \"pop\""
85
"r"
(val) ,
"r"
(va) :
86
"memory"
87
88
return
89
90
91
92
#endif
__asm__
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
registers.h
