RTEMS 6.1-rc1
spictrl.h
2
3/*
4 * SPICTRL SPI Driver interface.
5 *
6 * COPYRIGHT (c) 2009.
7 * Cobham Gaisler AB.
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 *
18 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28 * POSSIBILITY OF SUCH DAMAGE.
29 */
30
31#ifndef __SPICTRL_H__
32#define __SPICTRL_H__
33
34#ifdef __cplusplus
35extern "C" {
36#endif
37
38extern void spictrl_register_drv (void);
39
40/*** REGISTER LAYOUT ***/
42 volatile unsigned int capability; /* 0x00 */
43 volatile unsigned int resv[7]; /* 0x04 */
44 volatile unsigned int mode; /* 0x20 */
45 volatile unsigned int event; /* 0x24 */
46 volatile unsigned int mask; /* 0x28 */
47 volatile unsigned int command; /* 0x2c */
48 volatile unsigned int tx; /* 0x30 */
49 volatile unsigned int rx; /* 0x34 */
50 volatile unsigned int slvsel; /* 0x38 */
51 volatile unsigned int am_slvsel; /* 0x3c */
52 volatile unsigned int am_cfg; /* 0x40 */
53 volatile unsigned int am_period; /* 0x44 */
54 int reserved0[2];
55 volatile unsigned int am_mask[4]; /* 0x50-0x5C */
56 int reserved1[(0x200-0x60)/4];
57 volatile unsigned int am_tx[128]; /* 0x200-0x3FC */
58 volatile unsigned int am_rx[128]; /* 0x400-0x5FC */
59};
60
61/* -- About automated periodic transfer mode --
62 *
63 * Core must support this feature.
64 *
65 * The SPI core must be configured in periodic mode before
66 * writing the data into the transfer FIFO which will be used
67 * mutiple times in different transfers, it will also make
68 * the receive FIFO to be updated.
69 *
70 * In periodic mode the following sequence is performed,
71 * 1. start()
72 * 2. ioctl(CONFIG, &config) - Enable periodic mode
73 * 3. set_address()
74 * 4. write() - Fills TX FIFO, this has some constraints
75 * 5. ioctl(START) - Starts the periodic transmission of the TX FIFO
76 * 6. read() - Read one response of the tranistted data. It will
77 * hang until data is available. If hanging is not an
78 * options use ioctl(STATUS)
79 * 7. go back to 6.
80 *
81 * 8. ioctl(STOP) - Stop to set up a new periodic or normal transfer
82 * 9. stop()
83 *
84 * Note that the the read length must equal the total write length.
85 */
86
87/* Custom SPICTRL driver ioctl commands */
88#define SPICTRL_IOCTL_PERIOD_START 5000 /* Start automated periodic transfer mode */
89#define SPICTRL_IOCTL_PERIOD_STOP 5001 /* Stop to SPI core from doing periodic transfers */
90#define SPICTRL_IOCTL_CONFIG 5002 /* Configure Periodic transfer mode (before calling write() and START) */
91#define SPICTRL_IOCTL_STATUS 5003 /* Get status */
92
93#define SPICTRL_IOCTL_PERIOD_READ 5005 /* Write transmit registers and mask register
94 * (only in automatic periodic mode)
95 * Note that it is probably prefferred to read
96 * the received words using the read() using
97 * operations instead.
98 */
99#define SPICTRL_IOCTL_PERIOD_WRITE 5006 /* Read receive registers and mask register
100 * (only in automatic periodic mode) */
101#define SPICTRL_IOCTL_REGS 5007 /* Get SPICTRL Register */
102
103/* SPICTRL_IOCTL_CONFIG argument */
105 int clock_gap; /* Clock GAP between */
106 unsigned int flags; /* Normal mode flags */
107 int periodic_mode; /* 1=Enables Automated periodic transfers if supported by hardware */
108 unsigned int period; /* Number of clocks between automated transfers are started */
109 unsigned int period_flags; /* Options */
110 unsigned int period_slvsel; /* Slave Select when transfer is not active, default is 0xffffffff */
111};
112#define SPICTRL_FLAGS_TAC 0x10
113
114#define SPICTRL_PERIOD_FLAGS_ERPT 0x80 /* Trigger start-period from external signal */
115#define SPICTRL_PERIOD_FLAGS_SEQ 0x40
116#define SPICTRL_PERIOD_FLAGS_STRICT 0x20
117#define SPICTRL_PERIOD_FLAGS_OVTB 0x10
118#define SPICTRL_PERIOD_FLAGS_OVDB 0x08
119#define SPICTRL_PERIOD_FLAGS_ASEL 0x04
120#define SPICTRL_PERIOD_FLAGS_EACT 0x01
122/* SPICTRL_IOCTL_PERIOD_READ and SPICTRL_IOCTL_PERIOD_WRITE Argument data structure
123 *
124 * Note that the order of reading the mask registers are different for read/write
125 * operation. See options notes.
126 */
127struct spictrl_period_io {
128 int options; /* READ: bit0=Read Mask Registers into masks[].
129 * bit1=Read Receive registers according to masks[]
130 * (after reading masks).
131 *
132 * WRITE: bit0=Update Mask accoring to masks[].
133 * bit1=Update Transmit registers according to masks[].
134 * (before reading masks)
135 */
136 unsigned int masks[4];
137
138 void *data; /* Data read sequentially according to masks[] bit. */
139};
140
141#ifdef __cplusplus
142}
143#endif
144
145#endif
Definition: spictrl.h:98
Definition: spictrl.h:121
Definition: spictrl.h:41
