RTEMS 6.1-rc1
rtl-unwind.h
2
11/*
12 * COPYRIGHT (c) 2016, 2018 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_UNWIND_H_)
37#define _RTEMS_RTL_UNWIND_H_
38
39#include "rtl-elf.h"
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
56 const char* name,
57 uint32_t flags);
58
68
78
79#ifdef __cplusplus
80}
81#endif /* __cplusplus */
82
83#endif
RTEMS Run-Time Linker ELF Headers.
bool rtems_rtl_elf_unwind_parse(const rtems_rtl_obj *obj, const char *name, uint32_t flags)
Definition: rtl-mdreloc-aarch64.c:578
bool rtems_rtl_elf_unwind_register(rtems_rtl_obj *obj)
Definition: rtl-mdreloc-aarch64.c:585
bool rtems_rtl_elf_unwind_deregister(rtems_rtl_obj *obj)
Definition: rtl-mdreloc-aarch64.c:590
Definition: rtl-obj.h:200
