RTEMS 6.1-rc1
rtl-unwind-dw2.h
2
11/*
12 * COPYRIGHT (c) 2016, 2018 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_UNWIND_DW2_H_)
37#define _RTEMS_RTL_UNWIND_DW2_H_
38
39#include "rtl-elf.h"
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
45#if __SIZEOF_LONG__ >= __SIZEOF_POINTER__
46 typedef long rtems_rtl_elf_unwind_dw2_sleb128;
47 typedef unsigned long rtems_rtl_elf_unwind_dw2_uleb128;
48#elif __SIZEOF_LONG_LONG__ >= __SIZEOF_POINTER__
49 typedef long long rtems_rtl_elf_unwind_dw2_sleb128;
50 typedef unsigned long long rtems_rtl_elf_unwind_dw2_uleb128;
51#else
52 #error No DW2 type available.
53#endif
54
66 const char* name,
67 uint32_t flags);
68
78
88
92const uint8_t* rtems_rtl_elf_unwind_dw2_read_uleb128 (const uint8_t* data,
93 rtems_rtl_elf_unwind_dw2_uleb128* val);
94const uint8_t* rtems_rtl_elf_unwind_dw2_read_sleb128 (const uint8_t* data,
95 rtems_rtl_elf_unwind_dw2_sleb128* val);
96
97bool rtems_rtl_elf_unwind_dw2_relocate (const Elf_Addr* where, Elf_Word value, Elf_Word mask);
98
99#ifdef __cplusplus
100}
101#endif /* __cplusplus */
102
103#endif
RTEMS Run-Time Linker ELF Headers.
bool rtems_rtl_elf_unwind_dw2_parse(const rtems_rtl_obj *obj, const char *name, uint32_t flags)
Definition: rtl-unwind-dw2.c:58
const uint8_t * rtems_rtl_elf_unwind_dw2_read_uleb128(const uint8_t *data, rtems_rtl_elf_unwind_dw2_uleb128 *val)
bool rtems_rtl_elf_unwind_dw2_deregister(const rtems_rtl_obj *obj)
Definition: rtl-unwind-dw2.c:81
bool rtems_rtl_elf_unwind_dw2_register(const rtems_rtl_obj *obj)
Definition: rtl-unwind-dw2.c:69
Definition: rtl-obj.h:200
