35#if !defined (_RTEMS_RTL_TRACE_H_)
36#define _RTEMS_RTL_TRACE_H_
50#define RTEMS_RTL_TRACE 1
60#define RTEMS_RTL_TRACE_DETAIL (1UL << 0)
61#define RTEMS_RTL_TRACE_WARNING (1UL << 1)
62#define RTEMS_RTL_TRACE_LOAD (1UL << 2)
63#define RTEMS_RTL_TRACE_UNLOAD (1UL << 3)
64#define RTEMS_RTL_TRACE_SECTION (1UL << 4)
65#define RTEMS_RTL_TRACE_SYMBOL (1UL << 5)
66#define RTEMS_RTL_TRACE_RELOC (1UL << 6)
67#define RTEMS_RTL_TRACE_GLOBAL_SYM (1UL << 7)
68#define RTEMS_RTL_TRACE_LOAD_SECT (1UL << 8)
69#define RTEMS_RTL_TRACE_ALLOCATOR (1UL << 9)
70#define RTEMS_RTL_TRACE_UNRESOLVED (1UL << 10)
71#define RTEMS_RTL_TRACE_CACHE (1UL << 11)
72#define RTEMS_RTL_TRACE_ARCHIVES (1UL << 12)
73#define RTEMS_RTL_TRACE_ARCHIVE_SYMS (1UL << 13)
74#define RTEMS_RTL_TRACE_DEPENDENCY (1UL << 14)
75#define RTEMS_RTL_TRACE_BIT_ALLOC (1UL << 15)
76#define RTEMS_RTL_TRACE_COMP (1UL << 16)
77#define RTEMS_RTL_TRACE_ALL (0xffffffffUL & ~(RTEMS_RTL_TRACE_CACHE | \
78 RTEMS_RTL_TRACE_COMP | \
79 RTEMS_RTL_TRACE_GLOBAL_SYM | \
80 RTEMS_RTL_TRACE_ARCHIVE_SYMS))
93#define rtems_rtl_trace(_m) (0)
105#define rtems_rtl_trace_set_mask(_m)
117#define rtems_rtl_trace_clear_mask(_m)
User print interface to the bspIO print plug in.
uint32_t rtems_rtl_trace_mask
Definition: rtl-trace.h:55
rtems_rtl_trace_mask rtems_rtl_trace_set_mask(rtems_rtl_trace_mask mask)
rtems_rtl_trace_mask rtems_rtl_trace_clear_mask(rtems_rtl_trace_mask mask)
bool rtems_rtl_trace(rtems_rtl_trace_mask mask)
int rtems_rtl_trace_shell_command(const rtems_printer *printer, int argc, char *argv[])
