RTEMS 6.1-rc1
rtl-rap.h
2
11/*
12 * COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_RAP_H_)
37#define _RTEMS_RTL_RAP_H_
38
39#include <rtems/rtl/rtl-fwd.h>
41#include <rtems/rtl/rtl-sym.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
53bool rtems_rtl_rap_file_check (rtems_rtl_obj* obj, int fd);
54
61bool rtems_rtl_rap_file_load (rtems_rtl_obj* obj, int fd);
62
69
76
77#ifdef __cplusplus
78}
79#endif /* __cplusplus */
80
81#endif
RTEMS Run-Time Linker ELF Headers.
bool rtems_rtl_rap_file_load(rtems_rtl_obj *obj, int fd)
Definition: rtl-rap.c:816
bool rtems_rtl_rap_file_check(rtems_rtl_obj *obj, int fd)
Definition: rtl-rap.c:788
rtems_rtl_loader_format * rtems_rtl_rap_file_sig(void)
Definition: rtl-rap.c:1035
bool rtems_rtl_rap_file_unload(rtems_rtl_obj *obj)
Definition: rtl-rap.c:1028
RTEMS Run-Time Linker Object File Symbol Table.
Definition: rtl-obj.h:58
Definition: rtl-obj.h:200
