RTEMS 6.1-rc1
Data Structures | Typedefs | Functions | Variables
timerimpl.h File Reference
This header file provides the implementation interfaces of the Timer Manager. More...
#include <rtems/rtems/timerdata.h>
struct  Timer_server_Control
typedef struct Timer_server_Control Timer_server_Control
rtems_status_code _Timer_Fire (rtems_id id, rtems_interval interval, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor)
rtems_status_code _Timer_Fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor)
rtems_status_code _Timer_Fire_when (rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor)
void _Timer_Cancel (Per_CPU_Control *cpu, Timer_Control *the_timer)
void _Timer_Routine_adaptor (Watchdog_Control *the_watchdog)
void _Timer_server_Routine_adaptor (Watchdog_Control *the_watchdog)
Timer_server_Control *volatile _Timer_server
 Pointer to default timer server control block. More...
