RTEMS
6.1-rc1
include
objectimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (C) 2020 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_RTEMS_OBJECTIMPL_H
38
#define _RTEMS_RTEMS_OBJECTIMPL_H
39
40
rtems/score/objectimpl.h
41
rtems/rtems/status.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
72
rtems_status_code
_RTEMS_Name_to_id
73
uint32_t name,
74
uint32_t node,
75
Objects_Id
id
76
const
Objects_Information
*information
77
78
81
#ifdef __cplusplus
82
83
#endif
84
85
#endif
/* _RTEMS_RTEMS_OBJECTIMPL_H */
rtems_status_code
rtems_status_code
Definition:
status.h:85
_RTEMS_Name_to_id
rtems_status_code _RTEMS_Name_to_id(uint32_t name, uint32_t node, Objects_Id *id, const Objects_Information *information)
Calls _Objects_Name_to_id_u32() and converts the status.
Definition:
rtemsnametoid.c:44
Objects_Id
uint32_t Objects_Id
Definition:
object.h:101
status.h
This header file provides the status codes of Classic API directives and support functions.
objectimpl.h
This header file provides interfaces of the Object Handler which are only used by the implementation.
Objects_Information
The information structure used to manage each API class of objects.
Definition:
objectdata.h:198
