RTEMS 6.1-rc1
rtems-rfs-mutex.h
2
16/*
17 * COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
18 *
19 * Redistribution and use in source and binary forms, with or without
20 * modification, are permitted provided that the following conditions
21 * are met:
22 * 1. Redistributions of source code must retain the above copyright
23 * notice, this list of conditions and the following disclaimer.
24 * 2. Redistributions in binary form must reproduce the above copyright
25 * notice, this list of conditions and the following disclaimer in the
26 * documentation and/or other materials provided with the distribution.
27 *
28 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38 * POSSIBILITY OF SUCH DAMAGE.
39 */
40
41#if !defined (_RTEMS_RFS_MUTEX_H_)
42#define _RTEMS_RFS_MUTEX_H_
43
44#include <errno.h>
45
47
48#if __rtems__
49#include <rtems.h>
50#include <rtems/error.h>
51#include <rtems/thread.h>
52#endif
53
57#if __rtems__
58typedef rtems_recursive_mutex rtems_rfs_mutex;
59#else
60typedef uint32_t rtems_rfs_mutex; /* place holder */
61#endif
62
73
83
92static inline int
93rtems_rfs_mutex_lock (rtems_rfs_mutex* mutex)
94{
95#if __rtems__
96 rtems_recursive_mutex_lock(mutex);
97#endif
98 return 0;
99}
100
109static inline int
110rtems_rfs_mutex_unlock (rtems_rfs_mutex* mutex)
111{
112#if __rtems__
113 rtems_recursive_mutex_unlock(mutex);
114#endif
115 return 0;
116}
117
118#endif
RTEMS Error Reporting.
int rtems_rfs_mutex_create(rtems_rfs_mutex *mutex)
Create the mutex.
Definition: rtems-rfs-mutex.c:42
Definition: rtems-rfs-mutex.h:60
int rtems_rfs_mutex_destroy(rtems_rfs_mutex *mutex)
Destroy the mutex.
Definition: rtems-rfs-mutex.c:51
Manages the Trace and Debugging Features of the RTEMS RFS File System.
Definition: mutex.h:6
This header file provides the API of Self-Contained Objects.
