31#ifndef _RTEMS_DEBUGGER_THREADS_h
32#define _RTEMS_DEBUGGER_THREADS_h
34#include <rtems/debugger/rtems-debugger-server.h>
38#include "rtems-debugger-block.h"
47#define RTEMS_DEBUGGER_THREAD_NAME_SIZE (5)
52#define RTEMS_DEBUGGER_THREAD_BLOCK_SIZE (32)
57#define RTEMS_DEBUGGER_THREAD_FLAG_EXCEPTION (1 << 0)
58#define RTEMS_DEBUGGER_THREAD_FLAG_REG_VALID (1 << 1)
59#define RTEMS_DEBUGGER_THREAD_FLAG_REG_DIRTY (1 << 2)
60#define RTEMS_DEBUGGER_THREAD_FLAG_CONTINUE (1 << 3)
61#define RTEMS_DEBUGGER_THREAD_FLAG_STEP (1 << 4)
62#define RTEMS_DEBUGGER_THREAD_FLAG_STEPPING (1 << 5)
63#define RTEMS_DEBUGGER_THREAD_FLAG_INTS_DISABLED (1 << 6)
65#define RTEMS_DEBUGGER_THREAD_FLAG_TARGET_BASE (24)
66#define RTEMS_DEBUGGER_THREAD_FLAG_TARGET_MASK (0xff << RTEMS_DEBUGGER_THREAD_FLAG_TARGET_BASE)
71#define RTEMS_DEBUGGER_THREAD_FLAG_RESUME \
72 (RTEMS_DEBUGGER_THREAD_FLAG_CONTINUE | \
73 RTEMS_DEBUGGER_THREAD_FLAG_STEP | \
74 RTEMS_DEBUGGER_THREAD_FLAG_STEPPING)
79#define RTEMS_DEBUGGER_THREAD_FLAG_STEP_INSTR \
80 (RTEMS_DEBUGGER_THREAD_FLAG_STEP | \
81 RTEMS_DEBUGGER_THREAD_FLAG_STEPPING)
89 const char name[RTEMS_DEBUGGER_THREAD_NAME_SIZE];
127extern int rtems_debugger_thread_create(
void);
132extern int rtems_debugger_thread_destroy(
void);
137extern int rtems_debugger_thread_find_index(
rtems_id id);
142extern int rtems_debugger_thread_system_suspend(
void);
147extern int rtems_debugger_thread_system_resume(
bool detaching);
152extern int rtems_debugger_thread_continue_all(
void);
176rtems_debugger_thread_is_stepping(
rtems_id id, uintptr_t
pc);
222 return (thread->flags & mask) != 0;
237static inline uint8_t*
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
#define pc
pc, used on mips16 */
Definition: regs.h:67
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
Definition: rtems-debugger-block.h:46
void * block
Definition: rtems-debugger-block.h:47
Definition: rtems-debugger-threads.h:103
Definition: rtems-debugger-threads.h:87
Definition: rtems-debugger-threads.h:113
rtems_debugger_block stopped
Definition: rtems-debugger-threads.h:117
int selector_cont
Definition: rtems-debugger-threads.h:121
size_t next
Definition: rtems-debugger-threads.h:119
rtems_debugger_block registers
Definition: rtems-debugger-threads.h:115
rtems_debugger_block steppers
Definition: rtems-debugger-threads.h:118
rtems_debugger_block excludes
Definition: rtems-debugger-threads.h:116
rtems_debugger_block current
Definition: rtems-debugger-threads.h:114
int selector_gen
Definition: rtems-debugger-threads.h:120
unsigned size
Definition: tte.h:1
