RTEMS 6.1-rc1
This header file defines the Region Manager API. More...
#include <stdint.h>
#include <rtems/rtems/attr.h>
#include <rtems/rtems/options.h>
#include <rtems/score/heapinfo.h>
rtems_status_code | rtems_region_get_segment_size (rtems_id id, void *segment, uintptr_t *size) |
Gets the size of the region segment. More... | |
rtems_status_code | rtems_region_create (rtems_name name, void *starting_address, uintptr_t length, uintptr_t page_size, rtems_attribute attribute_set, rtems_id *id) |
Creates a region. More... | |
rtems_status_code | rtems_region_ident (rtems_name name, rtems_id *id) |
Identifies a region by the object name. More... | |
rtems_status_code | rtems_region_delete (rtems_id id) |
Deletes the region. More... | |
rtems_status_code | rtems_region_extend (rtems_id id, void *starting_address, uintptr_t length) |
Extends the region. More... | |
rtems_status_code | rtems_region_get_segment (rtems_id id, uintptr_t size, rtems_option option_set, rtems_interval timeout, void **segment) |
Gets a segment from the region. More... | |
rtems_status_code | rtems_region_return_segment (rtems_id id, void *segment) |
Returns the segment to the region. More... | |
rtems_status_code | rtems_region_resize_segment (rtems_id id, void *segment, uintptr_t size, uintptr_t *old_size) |
Changes the size of the segment. More... | |
rtems_status_code | rtems_region_get_information (rtems_id id, Heap_Information_block *the_info) |
Gets the region information. More... | |
rtems_status_code | rtems_region_get_free_information (rtems_id id, Heap_Information_block *the_info) |
Gets the region free information. More... | |
