RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_stc.h
1
/* The header file is generated by make_header.py from STC.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_STC
40
#define LIBBSP_ARM_TMS570_STC
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t STCGCR0;
/*STC Global Control Register 0*/
46
uint32_t STCGCR1;
/*STCGlobal Control Register 1*/
47
uint32_t STCTPR;
/*Self-Test Run Timeout Counter Preload Register*/
48
uint32_t STC_CADDR;
/*STC Current ROM Address Register*/
49
uint32_t STCCICR;
/*STC Current Interval Count Register*/
50
uint32_t STCGSTAT;
/*Self-Test Global Status Register*/
51
uint32_t STCFSTAT;
/*Self-Test Fail Status Register*/
52
uint32_t CPU1_CURMISR3;
/*CPU1 Current MISR Register 3*/
53
uint32_t CPU1_CURMISR2;
/*CPU1 Current MISR Register 2*/
54
uint32_t CPU1_CURMISR1;
/*CPU1 Current MISR Register 1*/
55
uint32_t CPU1_CURMISR0;
/*CPU1 Current MISR Register 0*/
56
uint32_t CPU2_CURMISR3;
/*CPU2 Current MISR Register 3*/
57
uint32_t CPU2_CURMISR2;
/*CPU2 Current MISR Register 2*/
58
uint32_t CPU2_CURMISR1;
/*CPU2 Current MISR Register 1*/
59
uint32_t CPU2_CURMISR0;
/*CPU2 Current MISR Register 0*/
60
uint32_t STCSCSCR;
/*Signature Compare Self-Check Register*/
61
tms570_stc_t
62
63
64
/*---------------------TMS570_STC_STCGCR0---------------------*/
65
/* field: INTCOUNT - Number of intervals of self-test run */
66
#define TMS570_STC_STCGCR0_INTCOUNT(val) BSP_FLD32(val,16, 31)
67
#define TMS570_STC_STCGCR0_INTCOUNT_GET(reg) BSP_FLD32GET(reg,16, 31)
68
#define TMS570_STC_STCGCR0_INTCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
69
70
/* field: RS_CNT - Restart or Continue */
71
#define TMS570_STC_STCGCR0_RS_CNT BSP_BIT32(0)
72
73
74
/*---------------------TMS570_STC_STCGCR1---------------------*/
75
/* field: STC_ENA - Self-test run enable key */
76
#define TMS570_STC_STCGCR1_STC_ENA(val) BSP_FLD32(val,0, 3)
77
#define TMS570_STC_STCGCR1_STC_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
78
#define TMS570_STC_STCGCR1_STC_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
79
80
81
/*---------------------TMS570_STC_STCTPR---------------------*/
82
/* field: RTOD - Self-test timeout count preload */
83
/* Whole 32 bits */
84
85
/*--------------------TMS570_STC_STC_CADDR--------------------*/
86
/* field: ADDR - Current ROM Address */
87
/* Whole 32 bits */
88
89
/*---------------------TMS570_STC_STCCICR---------------------*/
90
/* field: N - Interval Number */
91
#define TMS570_STC_STCCICR_N(val) BSP_FLD32(val,0, 15)
92
#define TMS570_STC_STCCICR_N_GET(reg) BSP_FLD32GET(reg,0, 15)
93
#define TMS570_STC_STCCICR_N_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
94
95
96
/*--------------------TMS570_STC_STCGSTAT--------------------*/
97
/* field: TEST_FAIL - Test Fail */
98
#define TMS570_STC_STCGSTAT_TEST_FAIL BSP_BIT32(1)
99
100
/* field: TEST_DONE - Test Done */
101
#define TMS570_STC_STCGSTAT_TEST_DONE BSP_BIT32(0)
102
103
104
/*--------------------TMS570_STC_STCFSTAT--------------------*/
105
/* field: TO_ERR - Timeout Error */
106
#define TMS570_STC_STCFSTAT_TO_ERR BSP_BIT32(2)
107
108
/* field: CPU2_FAIL - CPU2 failure info */
109
#define TMS570_STC_STCFSTAT_CPU2_FAIL BSP_BIT32(1)
110
111
/* field: CPU1_FAIL - CPU1 failure info */
112
#define TMS570_STC_STCFSTAT_CPU1_FAIL BSP_BIT32(0)
113
114
115
/*------------------TMS570_STC_CPU1_CURMISR3------------------*/
116
/* field: MISR - MISR data from CPU1 */
117
/* Whole 32 bits */
118
119
/*------------------TMS570_STC_CPU1_CURMISR2------------------*/
120
121
/* Whole 32 bits */
122
123
/*------------------TMS570_STC_CPU1_CURMISR1------------------*/
124
125
/* Whole 32 bits */
126
127
/*------------------TMS570_STC_CPU1_CURMISR0------------------*/
128
129
/* Whole 32 bits */
130
131
/*------------------TMS570_STC_CPU2_CURMISR3------------------*/
132
/* field: MISR - MISR data from CPU2 */
133
/* Whole 32 bits */
134
135
/*------------------TMS570_STC_CPU2_CURMISR2------------------*/
136
137
/* Whole 32 bits */
138
139
/*------------------TMS570_STC_CPU2_CURMISR1------------------*/
140
141
/* Whole 32 bits */
142
143
/*------------------TMS570_STC_CPU2_CURMISR0------------------*/
144
145
/* Whole 32 bits */
146
147
/*--------------------TMS570_STC_STCSCSCR--------------------*/
148
/* field: FAULT_INS - Enable / Disable fault insertion. */
149
#define TMS570_STC_STCSCSCR_FAULT_INS BSP_BIT32(4)
150
151
/* field: SELF_CHECK_KEY - Signature compare logic self-check enable key */
152
#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY(val) BSP_FLD32(val,0, 3)
153
#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
154
#define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
155
156
157
158
#endif
/* LIBBSP_ARM_TMS570_STC */
utility.h
This header file provides utility macros for BSPs.
tms570_stc_t
Definition:
reg_stc.h:44
