RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_sci.h
1
/* The header file is generated by make_header.py from SCI.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_SCI
40
#define LIBBSP_ARM_TMS570_SCI
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t GCR0;
/*SCI Global Control Register 0*/
46
uint32_t GCR1;
/*SCI Global Control Register 1*/
47
uint32_t GCR2;
/*SCI Global Control Register 2*/
48
uint32_t SETINT;
/*SCI Set Interrupt Register*/
49
uint32_t CLEARINT;
/*SCI Clear Interrupt Register*/
50
uint32_t SETINTLVL;
/*SCI Set Interrupt Level Register*/
51
uint32_t CLEARINTLVL;
/*SCI Clear Interrupt Level Register*/
52
uint32_t FLR;
/*SCI Flags Register*/
53
uint32_t INTVECT0;
/*SCI Interrupt Vector Offset 0*/
54
uint32_t INTVECT1;
/*SCI Interrupt Vector Offset 1*/
55
uint32_t FORMAT;
/*SCI Format Control Register*/
56
uint32_t BRS;
/*Baud Rate Selection Register*/
57
uint32_t ED;
/*Receiver Emulation Data Buffer*/
58
uint32_t RD;
/*Receiver Data Buffer*/
59
uint32_t TD;
/*Transmit Data Buffer*/
60
uint32_t PIO0;
/*SCI Pin I/O Control Register 0*/
61
uint32_t PIO1;
/*SCI Pin I/O Control Register 1*/
62
uint32_t PIO2;
/*SCI Pin I/O Control Register 2*/
63
uint32_t PIO3;
/*SCI Pin I/O Control Register 3*/
64
uint32_t PIO4;
/*SCI Pin I/O Control Register 4*/
65
uint32_t PIO5;
/*SCI Pin I/O Control Register 5*/
66
uint32_t PIO6;
/*SCI Pin I/O Control Register 6*/
67
uint32_t PIO7;
/*SCI Pin I/O Control Register 7*/
68
uint32_t PIO8;
/*SCI Pin I/O Control Register 8*/
69
uint8_t reserved1 [48];
70
uint32_t IODFTCTRL;
/*Input/Output Error Enable Register*/
71
tms570_sci_t
72
73
74
/*----------------------TMS570_SCI_GCR0----------------------*/
75
/* field: Reserved - Read returns 0. Writes have no effect. */
76
#define TMS570_SCI_GCR0_Reserved(val) BSP_FLD32(val,1, 31)
77
#define TMS570_SCI_GCR0_Reserved_GET(reg) BSP_FLD32GET(reg,1, 31)
78
#define TMS570_SCI_GCR0_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,1, 31)
79
80
/* field: RESET - This bit resets the SCI module. */
81
#define TMS570_SCI_GCR0_RESET BSP_BIT32(0)
82
83
84
/*----------------------TMS570_SCI_GCR1----------------------*/
85
/* field: TXENA - Transmit enable. */
86
#define TMS570_SCI_GCR1_TXENA BSP_BIT32(25)
87
88
/* field: RXENA - Receive enable. RXENA allows or prevents the transfer of data from SCIRXSHF to SCIRD. */
89
#define TMS570_SCI_GCR1_RXENA BSP_BIT32(24)
90
91
/* field: CONT - Continue on suspend. */
92
#define TMS570_SCI_GCR1_CONT BSP_BIT32(17)
93
94
/* field: LOOP_BACK - Loopback bit. The self-checking option for the SCI can be selected with this bit. */
95
#define TMS570_SCI_GCR1_LOOP_BACK BSP_BIT32(16)
96
97
/* field: POWERDOWN - If the POWERDOWN bit is set while the receiver is actively receiving data and the wake-up */
98
#define TMS570_SCI_GCR1_POWERDOWN BSP_BIT32(9)
99
100
/* field: SLEEP - SCI sleep. In a multiprocessor configuration, this bit controls the receive sleep function. */
101
#define TMS570_SCI_GCR1_SLEEP BSP_BIT32(8)
102
103
/* field: SWnRST - Software reset (active low). This bit is effective in LIN and SCI modes. */
104
#define TMS570_SCI_GCR1_SWnRST BSP_BIT32(7)
105
106
/* field: CLOCK - CLOCK */
107
#define TMS570_SCI_GCR1_CLOCK BSP_BIT32(5)
108
109
/* field: STOP - SCI number of stop bits per frame. */
110
#define TMS570_SCI_GCR1_STOP BSP_BIT32(4)
111
112
/* field: PARITY - SCI parity odd/even selection. If the PARITY ENA bit is set, PARITY designates odd or even parity. */
113
#define TMS570_SCI_GCR1_PARITY BSP_BIT32(3)
114
115
/* field: PARITY_ENA - Parity enable. This bit enables or disables the parity function. */
116
#define TMS570_SCI_GCR1_PARITY_ENA BSP_BIT32(2)
117
118
/* field: TIMING_MODE - SCI timing mode bit. */
119
#define TMS570_SCI_GCR1_TIMING_MODE BSP_BIT32(1)
120
121
/* field: COMM_MODE - SCI communication mode bit. */
122
#define TMS570_SCI_GCR1_COMM_MODE BSP_BIT32(0)
123
124
125
/*----------------------TMS570_SCI_GCR2----------------------*/
126
/* field: CC - Compare checksum. LIN mode only. */
127
#define TMS570_SCI_GCR2_CC BSP_BIT32(17)
128
129
/* field: SC - Send checksum byte. This bit is effective in LIN mode only. */
130
#define TMS570_SCI_GCR2_SC BSP_BIT32(16)
131
132
/* field: GEN_WU - Generate wakeup signal. This bit is effective in LIN mode only. */
133
#define TMS570_SCI_GCR2_GEN_WU BSP_BIT32(8)
134
135
/* field: POWERDOWN - Power down. This bit is effective in LIN or SCI mode. */
136
#define TMS570_SCI_GCR2_POWERDOWN BSP_BIT32(0)
137
138
139
/*---------------------TMS570_SCI_SETINT---------------------*/
140
/* field: SET_FE_INT - */
141
#define TMS570_SCI_SETINT_SET_FE_INT BSP_BIT32(26)
142
143
/* field: SET_OE_INT - SET OE INT */
144
#define TMS570_SCI_SETINT_SET_OE_INT BSP_BIT32(25)
145
146
/* field: SET_PE_INT - Set parity interrupt. */
147
#define TMS570_SCI_SETINT_SET_PE_INT BSP_BIT32(24)
148
149
/* field: SET_RX_DMA_ALL - SET RX DMA ALL */
150
#define TMS570_SCI_SETINT_SET_RX_DMA_ALL BSP_BIT32(18)
151
152
/* field: SET_RX_DMA - SET RX DMA */
153
#define TMS570_SCI_SETINT_SET_RX_DMA BSP_BIT32(17)
154
155
/* field: SET_TX_DMA - Set transmit DMA. To enable DMA requests for the transmitter, this bit must be set. */
156
#define TMS570_SCI_SETINT_SET_TX_DMA BSP_BIT32(16)
157
158
/* field: SET_RX_INT - SET RX INT */
159
#define TMS570_SCI_SETINT_SET_RX_INT BSP_BIT32(9)
160
161
/* field: SET_TX_INT - Set transmitter interrupt. */
162
#define TMS570_SCI_SETINT_SET_TX_INT BSP_BIT32(8)
163
164
/* field: SET_WAKEUP_INT - Set wakeup interrupt. */
165
#define TMS570_SCI_SETINT_SET_WAKEUP_INT BSP_BIT32(1)
166
167
/* field: SET_BRKDT_INT - Set breakdetect interrupt. */
168
#define TMS570_SCI_SETINT_SET_BRKDT_INT BSP_BIT32(0)
169
170
171
/*--------------------TMS570_SCI_CLEARINT--------------------*/
172
/* field: CLR_FE_INT - Clear framing-error interrupt. This bit disables the framing-error interrupt when set. */
173
#define TMS570_SCI_CLEARINT_CLR_FE_INT BSP_BIT32(26)
174
175
/* field: CLR_CE_INT - Clear overrun-error interrupt. This bit disables the SCI overrun error interrupt when set. */
176
#define TMS570_SCI_CLEARINT_CLR_CE_INT BSP_BIT32(25)
177
178
/* field: CLR_PE_INT - Clear parity interrupt. This bit disables the parity error interrupt when set. */
179
#define TMS570_SCI_CLEARINT_CLR_PE_INT BSP_BIT32(24)
180
181
/* field: CLR_RX_DMA_ALL - Clear receive DMA all. This bit clears the receive DMA request for address frames when set. */
182
#define TMS570_SCI_CLEARINT_CLR_RX_DMA_ALL BSP_BIT32(18)
183
184
/* field: CLR_RX_DMA - Clear receive DMA request. This bit disables the receive DMA request when set. */
185
#define TMS570_SCI_CLEARINT_CLR_RX_DMA BSP_BIT32(17)
186
187
/* field: CLR_TX_DMA - CLR TX DMA */
188
#define TMS570_SCI_CLEARINT_CLR_TX_DMA BSP_BIT32(16)
189
190
/* field: CLR_RX_INT - Clear receiver interrupt. This bit disables the receiver interrupt when set. */
191
#define TMS570_SCI_CLEARINT_CLR_RX_INT BSP_BIT32(9)
192
193
/* field: CLR_TX_INT - Clear transmitter interrupt. This bit disables the transmitter interrupt when set. */
194
#define TMS570_SCI_CLEARINT_CLR_TX_INT BSP_BIT32(8)
195
196
/* field: CLR_WAKEUP_INT - Clear wakeup interrupt. This bit disables the wakeup interrupt when set. */
197
#define TMS570_SCI_CLEARINT_CLR_WAKEUP_INT BSP_BIT32(1)
198
199
/* field: CLR_BRKDT_INT - Clear breakdetect interrupt. This bit disables the break-detect interrupt when set. */
200
#define TMS570_SCI_CLEARINT_CLR_BRKDT_INT BSP_BIT32(0)
201
202
203
/*--------------------TMS570_SCI_SETINTLVL--------------------*/
204
/* field: SET_FE_INT_LVL - Set framing-error interrupt level. */
205
#define TMS570_SCI_SETINTLVL_SET_FE_INT_LVL BSP_BIT32(26)
206
207
/* field: SET_CE_INT_LVL - Set overrun-error interrupt level. */
208
#define TMS570_SCI_SETINTLVL_SET_CE_INT_LVL BSP_BIT32(25)
209
210
/* field: SET_PE_INT_LVL - Set parity error interrupt level. */
211
#define TMS570_SCI_SETINTLVL_SET_PE_INT_LVL BSP_BIT32(24)
212
213
/* field: SET_RX_DMA_ALL_LVL - Set receive DMA all interrupt levels. */
214
#define TMS570_SCI_SETINTLVL_SET_RX_DMA_ALL_LVL BSP_BIT32(18)
215
216
/* field: SET_RX_INT_LVL - Set receiver interrupt level. */
217
#define TMS570_SCI_SETINTLVL_SET_RX_INT_LVL BSP_BIT32(9)
218
219
/* field: SET_TX_INT_LVL - Set transmitter interrupt level. */
220
#define TMS570_SCI_SETINTLVL_SET_TX_INT_LVL BSP_BIT32(8)
221
222
/* field: SET_WAKEUP_INT_LVL - Set wakeup interrupt level. */
223
#define TMS570_SCI_SETINTLVL_SET_WAKEUP_INT_LVL BSP_BIT32(1)
224
225
/* field: SET_BRKDT_INT_LVL - SET BRKDT INT LVL */
226
#define TMS570_SCI_SETINTLVL_SET_BRKDT_INT_LVL BSP_BIT32(0)
227
228
229
/*-------------------TMS570_SCI_CLEARINTLVL-------------------*/
230
/* field: CLR_FE_INT_LVL - Clear framing-error interrupt. */
231
#define TMS570_SCI_CLEARINTLVL_CLR_FE_INT_LVL BSP_BIT32(26)
232
233
/* field: CLR_CE_INT_LVL - CLR CE INT LVL */
234
#define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
235
236
237
238
239
/* field: CLR_PE_INT_LVL - */
240
#define TMS570_SCI_CLEARINTLVL_CLR_PE_INT_LVL BSP_BIT32(24)
241
242
/* field: CLR_RX_DMA_ALL_LVL - Clear receive DMA interrupt level. */
243
#define TMS570_SCI_CLEARINTLVL_CLR_RX_DMA_ALL_LVL BSP_BIT32(18)
244
245
/* field: CLR_RX_INT_LVL - Clear receiver interrupt. */
246
#define TMS570_SCI_CLEARINTLVL_CLR_RX_INT_LVL BSP_BIT32(9)
247
248
/* field: 8 - CLR TX INT LVL Clear transmitter interrupt. */
249
#define TMS570_SCI_CLEARINTLVL_8 BSP_BIT32(8)
250
251
/* field: CLR_WAKEUP_INT_LVL - Clear wakeup interrupt. */
252
#define TMS570_SCI_CLEARINTLVL_CLR_WAKEUP_INT_LVL BSP_BIT32(1)
253
254
/* field: CLR_BRKDT_INT_LVL - Clear breakdetect interrupt. */
255
#define TMS570_SCI_CLEARINTLVL_CLR_BRKDT_INT_LVL BSP_BIT32(0)
256
257
258
/*-----------------------TMS570_SCI_FLR-----------------------*/
259
/* field: FE - Framing error flag. This bit is effective in LIN or SCI-compatible mode. */
260
#define TMS570_SCI_FLR_FE BSP_BIT32(26)
261
262
/* field: OE - Overrun error flag. */
263
#define TMS570_SCI_FLR_OE BSP_BIT32(25)
264
265
/* field: PE - Parity error flag. This bit is set when a parity error is detected in the received data. */
266
#define TMS570_SCI_FLR_PE BSP_BIT32(24)
267
268
/* field: RXWAKE - Receiver wakeup detect flag. */
269
#define TMS570_SCI_FLR_RXWAKE BSP_BIT32(12)
270
271
/* field: TX_EMPTY - Transmitter empty flag. */
272
#define TMS570_SCI_FLR_TX_EMPTY BSP_BIT32(11)
273
274
/* field: TXWAKE - Transmitter wakeup method select. */
275
#define TMS570_SCI_FLR_TXWAKE BSP_BIT32(10)
276
277
/* field: RXRDY - Receiver ready flag. */
278
#define TMS570_SCI_FLR_RXRDY BSP_BIT32(9)
279
280
/* field: TXRDY - Transmitter buffer register ready flag. */
281
#define TMS570_SCI_FLR_TXRDY BSP_BIT32(8)
282
283
/* field: BUSY - Bus busy flag. TThis bit indicates whether the receiver is in the process of receiving a frame. */
284
#define TMS570_SCI_FLR_BUSY BSP_BIT32(3)
285
286
/* field: IDLE - SCI receiver in idle state. */
287
#define TMS570_SCI_FLR_IDLE BSP_BIT32(2)
288
289
/* field: WAKEUP - Wakeup flag. */
290
#define TMS570_SCI_FLR_WAKEUP BSP_BIT32(1)
291
292
/* field: BRKDT - SCI break-detect flag. This bit is set when the SCI detects a break condition on the LINRX pin. */
293
#define TMS570_SCI_FLR_BRKDT BSP_BIT32(0)
294
295
296
/*--------------------TMS570_SCI_INTVECT0--------------------*/
297
/* field: INVECT0 - Interrupt vector offset for INT0. This register indicates the offset for interrupt line INT0. */
298
#define TMS570_SCI_INTVECT0_INVECT0(val) BSP_FLD32(val,0, 3)
299
#define TMS570_SCI_INTVECT0_INVECT0_GET(reg) BSP_FLD32GET(reg,0, 3)
300
#define TMS570_SCI_INTVECT0_INVECT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
301
302
303
/*--------------------TMS570_SCI_INTVECT1--------------------*/
304
/* field: INVECT1 - Interrupt vector offset for INT1. This register indicates the offset for interrupt line INT1. */
305
#define TMS570_SCI_INTVECT1_INVECT1(val) BSP_FLD32(val,0, 3)
306
#define TMS570_SCI_INTVECT1_INVECT1_GET(reg) BSP_FLD32GET(reg,0, 3)
307
#define TMS570_SCI_INTVECT1_INVECT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
308
309
310
/*---------------------TMS570_SCI_FORMAT---------------------*/
311
/* field: CHAR - Character length control bits. These bits set the SCI character length from 1 to 8 bits. */
312
#define TMS570_SCI_FORMAT_CHAR(val) BSP_FLD32(val,0, 2)
313
#define TMS570_SCI_FORMAT_CHAR_GET(reg) BSP_FLD32GET(reg,0, 2)
314
#define TMS570_SCI_FORMAT_CHAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
315
316
317
/*-----------------------TMS570_SCI_BRS-----------------------*/
318
/* field: BAUD - SCI 24-bit baud selection. */
319
#define TMS570_SCI_BRS_BAUD(val) BSP_FLD32(val,0, 23)
320
#define TMS570_SCI_BRS_BAUD_GET(reg) BSP_FLD32GET(reg,0, 23)
321
#define TMS570_SCI_BRS_BAUD_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
322
323
324
/*-----------------------TMS570_SCI_ED-----------------------*/
325
/* field: ED - Emulator data. Reading SCIED[7:0] does not clear the RXRDY flag, unlike reading SCIRD. */
326
#define TMS570_SCI_ED_ED(val) BSP_FLD32(val,0, 7)
327
#define TMS570_SCI_ED_ED_GET(reg) BSP_FLD32GET(reg,0, 7)
328
#define TMS570_SCI_ED_ED_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
329
330
331
/*-----------------------TMS570_SCI_RD-----------------------*/
332
/* field: RD - Receiver data. */
333
#define TMS570_SCI_RD_RD(val) BSP_FLD32(val,0, 7)
334
#define TMS570_SCI_RD_RD_GET(reg) BSP_FLD32GET(reg,0, 7)
335
#define TMS570_SCI_RD_RD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
336
337
338
/*-----------------------TMS570_SCI_TD-----------------------*/
339
/* field: TD - Transmit data. Data to be transmitted is written to the SCITD register. */
340
#define TMS570_SCI_TD_TD(val) BSP_FLD32(val,0, 7)
341
#define TMS570_SCI_TD_TD_GET(reg) BSP_FLD32GET(reg,0, 7)
342
#define TMS570_SCI_TD_TD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
343
344
345
/*----------------------TMS570_SCI_PIO0----------------------*/
346
/* field: TX_FUNC - Transfer function. This bit defines the function of pin SCITX. */
347
#define TMS570_SCI_PIO0_TX_FUNC BSP_BIT32(2)
348
349
/* field: RX_FUNC - Receive function.This bit defines the function of pin SCIRX. */
350
#define TMS570_SCI_PIO0_RX_FUNC BSP_BIT32(1)
351
352
353
/*----------------------TMS570_SCI_PIO1----------------------*/
354
/* field: TX_DIR - Transmit pin direction. */
355
#define TMS570_SCI_PIO1_TX_DIR BSP_BIT32(2)
356
357
/* field: RX_DIR - Receive pin direction. */
358
#define TMS570_SCI_PIO1_RX_DIR BSP_BIT32(1)
359
360
361
/*----------------------TMS570_SCI_PIO2----------------------*/
362
/* field: TX_IN - Transmit pin in. This bit contains the current value on the SCITX pin. */
363
#define TMS570_SCI_PIO2_TX_IN BSP_BIT32(2)
364
365
/* field: RX_IN - Receive pin in. This bit contains the current value on the SCIRX pin. */
366
#define TMS570_SCI_PIO2_RX_IN BSP_BIT32(1)
367
368
369
/*----------------------TMS570_SCI_PIO3----------------------*/
370
/* field: TX_OUT - Transmit pin out. */
371
#define TMS570_SCI_PIO3_TX_OUT BSP_BIT32(2)
372
373
/* field: RX_OUT - Receive pin out. */
374
#define TMS570_SCI_PIO3_RX_OUT BSP_BIT32(1)
375
376
377
/*----------------------TMS570_SCI_PIO4----------------------*/
378
/* field: TX_SET - Transmit pin set. */
379
#define TMS570_SCI_PIO4_TX_SET BSP_BIT32(2)
380
381
/* field: RX_SET - Receive pin set. */
382
#define TMS570_SCI_PIO4_RX_SET BSP_BIT32(1)
383
384
385
/*----------------------TMS570_SCI_PIO5----------------------*/
386
/* field: TX_CLR - Transmit pin clear. */
387
#define TMS570_SCI_PIO5_TX_CLR BSP_BIT32(2)
388
389
/* field: RX_CLR - Receive pin clear. */
390
#define TMS570_SCI_PIO5_RX_CLR BSP_BIT32(1)
391
392
393
/*----------------------TMS570_SCI_PIO6----------------------*/
394
/* field: TX_PDR - Transmit pin open drain enable. */
395
#define TMS570_SCI_PIO6_TX_PDR BSP_BIT32(2)
396
397
/* field: RX_PDR - Receive pin open drain enable. */
398
#define TMS570_SCI_PIO6_RX_PDR BSP_BIT32(1)
399
400
401
/*----------------------TMS570_SCI_PIO7----------------------*/
402
/* field: TX_PD - Transmit pin pull control disable. This bit disables pull control capability on the input pin SCITX. */
403
#define TMS570_SCI_PIO7_TX_PD BSP_BIT32(2)
404
405
/* field: RX_PD - Receive pin pull control disable. This bit disables pull control capability on the input pin SCIRX. */
406
#define TMS570_SCI_PIO7_RX_PD BSP_BIT32(1)
407
408
409
/*----------------------TMS570_SCI_PIO8----------------------*/
410
/* field: TX_PSL - TX pin pull select. This bit selects pull type in the input pin SCITX. */
411
#define TMS570_SCI_PIO8_TX_PSL BSP_BIT32(2)
412
413
/* field: RX_PSL - RX pin pull select. This bit selects pull type in the input pin SCIRX. */
414
#define TMS570_SCI_PIO8_RX_PSL BSP_BIT32(1)
415
416
417
/*--------------------TMS570_SCI_IODFTCTRL--------------------*/
418
/* field: FEN - Frame error enable. This bit is used to create a frame error. */
419
#define TMS570_SCI_IODFTCTRL_FEN BSP_BIT32(26)
420
421
/* field: PEN - Parity error enable. This bit is used to create a parity error. */
422
#define TMS570_SCI_IODFTCTRL_PEN BSP_BIT32(25)
423
424
/* field: BRKD_TENA - Break detect error enable. This bit is used to create a BRKDT error. */
425
#define TMS570_SCI_IODFTCTRL_BRKD_TENA BSP_BIT32(24)
426
427
/* field: PIN_SAMPLE_MASK - Pin sample mask. */
428
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK(val) BSP_FLD32(val,19, 20)
429
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_GET(reg) BSP_FLD32GET(reg,19, 20)
430
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_SET(reg,val) BSP_FLD32SET(reg, val,19, 20)
431
432
/* field: TX_SHIFT - Transmit shift. */
433
#define TMS570_SCI_IODFTCTRL_TX_SHIFT(val) BSP_FLD32(val,16, 18)
434
#define TMS570_SCI_IODFTCTRL_TX_SHIFT_GET(reg) BSP_FLD32GET(reg,16, 18)
435
#define TMS570_SCI_IODFTCTRL_TX_SHIFT_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
436
437
/* field: IODFTENA - IODFT enable key. Write access permitted in Privilege mode only. */
438
#define TMS570_SCI_IODFTCTRL_IODFTENA(val) BSP_FLD32(val,8, 11)
439
#define TMS570_SCI_IODFTCTRL_IODFTENA_GET(reg) BSP_FLD32GET(reg,8, 11)
440
#define TMS570_SCI_IODFTCTRL_IODFTENA_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
441
442
/* field: LPBENA - Module loopback enable. Write access permitted in Privilege mode only. */
443
#define TMS570_SCI_IODFTCTRL_LPBENA BSP_BIT32(1)
444
445
/* field: RXPENA - Module analog loopback through receive pin enable. */
446
#define TMS570_SCI_IODFTCTRL_RXPENA BSP_BIT32(0)
447
448
449
450
#endif
/* LIBBSP_ARM_TMS570_SCI */
utility.h
This header file provides utility macros for BSPs.
tms570_sci_t
Definition:
reg_sci.h:44
