39#ifndef LIBBSP_ARM_TMS570_PLL
40#define LIBBSP_ARM_TMS570_PLL
46 uint8_t reserved1 [108];
48 uint8_t reserved2 [7600];
55 uint8_t reserved3 [24];
57 uint8_t reserved4 [24];
60 uint8_t reserved5 [16];
63 uint8_t reserved6 [16];
65 uint8_t reserved7 [72];
72#define TMS570_PLL_PLLCTL3_ODPLL2(val) BSP_FLD32(val,29, 31)
73#define TMS570_PLL_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg,29, 31)
74#define TMS570_PLL_PLLCTL3_ODPLL2_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
77#define TMS570_PLL_PLLCTL3_PLLDIV2(val) BSP_FLD32(val,24, 28)
78#define TMS570_PLL_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg,24, 28)
79#define TMS570_PLL_PLLCTL3_PLLDIV2_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
82#define TMS570_PLL_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val,16, 21)
83#define TMS570_PLL_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg,16, 21)
84#define TMS570_PLL_PLLCTL3_REFCLKDIV2_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
87#define TMS570_PLL_PLLCTL3_PLLMUL2(val) BSP_FLD32(val,0, 15)
88#define TMS570_PLL_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg,0, 15)
89#define TMS570_PLL_PLLCTL3_PLLMUL2_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
94#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT(val) BSP_FLD32(val,8, 13)
95#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT_GET(reg) BSP_FLD32GET(reg,8, 13)
96#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT_SET(reg,val) BSP_FLD32SET(reg, val,8, 13)
99#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY(val) BSP_FLD32(val,0, 3)
100#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
101#define TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
106#define TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX(val) BSP_FLD32(val,8, 15)
107#define TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX_GET(reg) BSP_FLD32GET(reg,8, 15)
108#define TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
111#define TMS570_PLL_SSWPLL1_COUNTER_READ_READY BSP_BIT32(6)
114#define TMS570_PLL_SSWPLL1_COUNTER_RESET BSP_BIT32(5)
117#define TMS570_PLL_SSWPLL1_COUNTER_EN BSP_BIT32(4)
120#define TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS(val) BSP_FLD32(val,1, 3)
121#define TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS_GET(reg) BSP_FLD32GET(reg,1, 3)
122#define TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS_SET(reg,val) BSP_FLD32SET(reg, val,1, 3)
125#define TMS570_PLL_SSWPLL1_EXT_COUNTER_EN BSP_BIT32(0)
138#define TMS570_PLL_CSDIS_CLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7)
139#define TMS570_PLL_CSDIS_CLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7)
140#define TMS570_PLL_CSDIS_CLKSR_7_3_OFF_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
143#define TMS570_PLL_CSDIS_CLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1)
144#define TMS570_PLL_CSDIS_CLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1)
145#define TMS570_PLL_CSDIS_CLKSR_1_0_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
150#define TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7)
151#define TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7)
152#define TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
155#define TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1)
156#define TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1)
157#define TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
162#define TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7)
163#define TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7)
164#define TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
167#define TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1)
168#define TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1)
169#define TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
174#define TMS570_PLL_CSVSTAT_CLKSR_7_3V(val) BSP_FLD32(val,3, 7)
175#define TMS570_PLL_CSVSTAT_CLKSR_7_3V_GET(reg) BSP_FLD32GET(reg,3, 7)
176#define TMS570_PLL_CSVSTAT_CLKSR_7_3V_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
179#define TMS570_PLL_CSVSTAT_CLKSR_1_0V(val) BSP_FLD32(val,0, 1)
180#define TMS570_PLL_CSVSTAT_CLKSR_1_0V_GET(reg) BSP_FLD32GET(reg,0, 1)
181#define TMS570_PLL_CSVSTAT_CLKSR_1_0V_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
186#define TMS570_PLL_PLLCTL1_ROS BSP_BIT32(31)
189#define TMS570_PLL_PLLCTL1_MASK_SLIP(val) BSP_FLD32(val,29, 30)
190#define TMS570_PLL_PLLCTL1_MASK_SLIP_GET(reg) BSP_FLD32GET(reg,29, 30)
191#define TMS570_PLL_PLLCTL1_MASK_SLIP_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
194#define TMS570_PLL_PLLCTL1_PLLDIV(val) BSP_FLD32(val,24, 28)
195#define TMS570_PLL_PLLCTL1_PLLDIV_GET(reg) BSP_FLD32GET(reg,24, 28)
196#define TMS570_PLL_PLLCTL1_PLLDIV_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
199#define TMS570_PLL_PLLCTL1_ROF BSP_BIT32(23)
202#define TMS570_PLL_PLLCTL1_REFCLKDIV(val) BSP_FLD32(val,16, 21)
203#define TMS570_PLL_PLLCTL1_REFCLKDIV_GET(reg) BSP_FLD32GET(reg,16, 21)
204#define TMS570_PLL_PLLCTL1_REFCLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
207#define TMS570_PLL_PLLCTL1_PLLMUL(val) BSP_FLD32(val,0, 15)
208#define TMS570_PLL_PLLCTL1_PLLMUL_GET(reg) BSP_FLD32GET(reg,0, 15)
209#define TMS570_PLL_PLLCTL1_PLLMUL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
214#define TMS570_PLL_PLLCTL2_FMENA BSP_BIT32(31)
217#define TMS570_PLL_PLLCTL2_SPREADINGRATE(val) BSP_FLD32(val,22, 30)
218#define TMS570_PLL_PLLCTL2_SPREADINGRATE_GET(reg) BSP_FLD32GET(reg,22, 30)
219#define TMS570_PLL_PLLCTL2_SPREADINGRATE_SET(reg,val) BSP_FLD32SET(reg, val,22, 30)
222#define TMS570_PLL_PLLCTL2_MULMOD(val) BSP_FLD32(val,12, 20)
223#define TMS570_PLL_PLLCTL2_MULMOD_GET(reg) BSP_FLD32GET(reg,12, 20)
224#define TMS570_PLL_PLLCTL2_MULMOD_SET(reg,val) BSP_FLD32SET(reg, val,12, 20)
227#define TMS570_PLL_PLLCTL2_ODPLL(val) BSP_FLD32(val,9, 11)
228#define TMS570_PLL_PLLCTL2_ODPLL_GET(reg) BSP_FLD32GET(reg,9, 11)
229#define TMS570_PLL_PLLCTL2_ODPLL_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
232#define TMS570_PLL_PLLCTL2_SPR_AMOUNT(val) BSP_FLD32(val,0, 8)
233#define TMS570_PLL_PLLCTL2_SPR_AMOUNT_GET(reg) BSP_FLD32GET(reg,0, 8)
234#define TMS570_PLL_PLLCTL2_SPR_AMOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
239#define TMS570_PLL_LPOMONCTL_BIAS_ENABLE BSP_BIT32(24)
242#define TMS570_PLL_LPOMONCTL_OSCFRQCONFIGCNT BSP_BIT32(16)
245#define TMS570_PLL_LPOMONCTL_HFTRIM(val) BSP_FLD32(val,8, 12)
246#define TMS570_PLL_LPOMONCTL_HFTRIM_GET(reg) BSP_FLD32GET(reg,8, 12)
247#define TMS570_PLL_LPOMONCTL_HFTRIM_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
252#define TMS570_PLL_CLKTEST_ALTLIMPCLOCKENABLE BSP_BIT32(26)
255#define TMS570_PLL_CLKTEST_RANGEDETCTRL BSP_BIT32(25)
258#define TMS570_PLL_CLKTEST_RANGEDETENASSEL BSP_BIT32(24)
261#define TMS570_PLL_CLKTEST_CLK_TEST_EN(val) BSP_FLD32(val,16, 19)
262#define TMS570_PLL_CLKTEST_CLK_TEST_EN_GET(reg) BSP_FLD32GET(reg,16, 19)
263#define TMS570_PLL_CLKTEST_CLK_TEST_EN_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
268#define TMS570_PLL_GPREG1_EMIF_FUNC BSP_BIT32(31)
271#define TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT(val) BSP_FLD32(val,20, 25)
272#define TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT_GET(reg) BSP_FLD32GET(reg,20, 25)
273#define TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
276#define TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY(val) BSP_FLD32(val,16, 19)
277#define TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
278#define TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
281#define TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE(val) BSP_FLD32(val,0, 15)
282#define TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_GET(reg) BSP_FLD32GET(reg,0, 15)
283#define TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
288#define TMS570_PLL_GLBSTAT_FBSLIP BSP_BIT32(9)
291#define TMS570_PLL_GLBSTAT_RFSLIP BSP_BIT32(8)
294#define TMS570_PLL_GLBSTAT_OSCFAIL BSP_BIT32(0)
This header file provides utility macros for BSPs.
