RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_pcr.h
1
/* The header file is generated by make_header.py from PCR.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_PCR
40
#define LIBBSP_ARM_TMS570_PCR
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t PMPROTSET0;
/*Peripheral Memory Protection Set Register 0*/
46
uint32_t PMPROTSET1;
/*Peripheral Memory Protection Set Register 1*/
47
uint8_t reserved1 [8];
48
uint32_t PMPROTCLR0;
/*Peripheral Memory Protection Clear Register 0*/
49
uint32_t PMPROTCLR1;
/*Peripheral Memory Protection Clear Register 1*/
50
uint8_t reserved2 [8];
51
uint32_t PPROTSET0;
/*Peripheral Protection Set Register 0*/
52
uint32_t PPROTSET1;
/*Peripheral Protection Set Register 1*/
53
uint32_t PPROTSET2;
/*Peripheral Protection Set Register 2*/
54
uint32_t PPROTSET3;
/*Peripheral Protection Set Register 3*/
55
uint8_t reserved3 [16];
56
uint32_t PPROTCLR0;
/*Peripheral Protection Clear Register 0*/
57
uint32_t PPROTCLR1;
/*Peripheral Protection Clear Register 1*/
58
uint32_t PPROTCLR2;
/*Peripheral Protection Clear Register 2*/
59
uint32_t PPROTCLR3;
/*Peripheral Protection Clear Register 3*/
60
uint8_t reserved4 [16];
61
uint32_t PCSPWRDWNSET0;
/*Peripheral Memory Power-Down Set Register 0*/
62
uint32_t PCSPWRDWNSET1;
/*Peripheral Memory Power-Down Set Register 1*/
63
uint8_t reserved5 [8];
64
uint32_t PCSPWRDWNCLR0;
/*Peripheral Memory Power-Down Clear Register 0*/
65
uint32_t PCSPWRDWNCLR1;
/*Peripheral Memory Power-Down Clear Register 1*/
66
uint8_t reserved6 [8];
67
uint32_t PSPWRDWNSET0;
/*Peripheral Power-Down Set Register 0*/
68
uint32_t PSPWRDWNSET1;
/*Peripheral Power-Down Set Register 1*/
69
uint32_t PSPWRDWNSET2;
/*Peripheral Power-Down Set Register 2*/
70
uint32_t PSPWRDWNSET3;
/*Peripheral Power-Down Set Register 3*/
71
uint8_t reserved7 [16];
72
uint32_t PSPWRDWNCLR0;
/*Peripheral Power-Down Clear Register 0*/
73
uint32_t PSPWRDWNCLR1;
/*Peripheral Power-Down Clear Register 1*/
74
uint32_t PSPWRDWNCLR2;
/*Peripheral Power-Down Clear Register 2*/
75
uint32_t PSPWRDWNCLR3;
/*Peripheral Power-Down Clear Register 3*/
76
tms570_pcr_t
77
78
79
/*-------------------TMS570_PCR_PMPROTSET0-------------------*/
80
/* field: PCSPROTSET - Peripheral memory frame protection set. */
81
/* Whole 32 bits */
82
83
/*-------------------TMS570_PCR_PMPROTSET1-------------------*/
84
85
/* Whole 32 bits */
86
87
/*-------------------TMS570_PCR_PMPROTCLR0-------------------*/
88
/* field: PCSPROTCLR - Peripheral memory frame protection clear. */
89
/* Whole 32 bits */
90
91
/*-------------------TMS570_PCR_PMPROTCLR1-------------------*/
92
93
/* Whole 32 bits */
94
95
/*--------------------TMS570_PCR_PPROTSETx--------------------*/
96
/* field: PROTSET - Peripheral select quadrant protection set. */
97
/* Whole 32 bits */
98
99
/*--------------------TMS570_PCR_PPROTCLRx--------------------*/
100
/* field: PROTCLR - Peripheral select quadrant protection clear. */
101
/* Whole 32 bits */
102
103
/*------------------TMS570_PCR_PCSPWRDWNSETx------------------*/
104
/* field: PWRDNSET - Peripheral memory clock power-down set. */
105
/* Whole 32 bits */
106
107
/*------------------TMS570_PCR_PCSPWRDWNCLRx------------------*/
108
/* field: PWRDNCLR - Peripheral memory clock power-down clear. */
109
/* Whole 32 bits */
110
111
/*------------------TMS570_PCR_PSPWRDWNSETx------------------*/
112
/* field: PWRDWNSET - Peripheral select quadrant clock power-down set. */
113
/* Whole 32 bits */
114
115
/*------------------TMS570_PCR_PSPWRDWNCLRx------------------*/
116
/* field: PWRDWNCLR - Peripheral select quadrant clock power-down clear. */
117
/* Whole 32 bits */
118
119
120
#endif
/* LIBBSP_ARM_TMS570_PCR */
utility.h
This header file provides utility macros for BSPs.
tms570_pcr_t
Definition:
reg_pcr.h:44
