RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_lin.h
1
/* The header file is generated by make_header.py from LIN.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_LIN
40
#define LIBBSP_ARM_TMS570_LIN
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t GCR0;
/*SCI Global Control Register 0*/
46
uint32_t GCR1;
/*SCI Global Control Register 1*/
47
uint32_t GCR2;
/*SCI Global Control Register 2*/
48
uint32_t SETINT;
/*SCI Set Interrupt Register*/
49
uint32_t CLEARINT;
/*SCI Clear Interrupt Register*/
50
uint32_t SETINTLVL;
/*SCI Set Interrupt Level Register*/
51
uint32_t CLEARINTLVL;
/*SCI Clear Interrupt Level Register*/
52
uint32_t FLR;
/*SCI Flags Register*/
53
uint32_t INTVECT0;
/*SCI Interrupt Vector Offset 0*/
54
uint32_t INTVECT1;
/*SCI Interrupt Vector Offset 1*/
55
uint32_t FORMAT;
/*SCI Format Control Register*/
56
uint32_t BRS;
/*Baud Rate Selection Register*/
57
uint32_t ED;
/*Receiver Emulation Data Buffer*/
58
uint32_t RD;
/*Receiver Data Buffer*/
59
uint32_t TD;
/*Transmit Data Buffer*/
60
uint32_t PIO0;
/*SCI Pin I/O Control Register 0*/
61
uint32_t PIO1;
/*SCI Pin I/O Control Register 1*/
62
uint32_t PIO2;
/*SCI Pin I/O Control Register 2*/
63
uint32_t PIO3;
/*SCI Pin I/O Control Register 3*/
64
uint32_t PIO4;
/*SCI Pin I/O Control Register 4*/
65
uint32_t PIO5;
/*SCI Pin I/O Control Register 5*/
66
uint32_t PIO6;
/*SCI Pin I/O Control Register 6*/
67
uint32_t PIO7;
/*SCI Pin I/O Control Register 7*/
68
uint32_t PIO8;
/*SCI Pin I/O Control Register 8*/
69
uint32_t COMP;
/*LIN Compare Register*/
70
uint32_t RD0;
/*LIN Receive Buffer 0 Register*/
71
uint32_t RD1;
/*LIN Receive Buffer 1 Register*/
72
uint32_t MASK;
/*LIN Mask Register*/
73
uint32_t ID;
/*LIN Identification Register*/
74
uint32_t TD0;
/*LIN Transmit Buffer 0*/
75
uint32_t TD1;
/*LIN Transmit Buffer 1*/
76
uint32_t MBRSR;
/*Maximum Baud Rate Selection Register*/
77
uint8_t reserved1 [16];
78
uint32_t IODFTCTRL;
/*Input/Output Error Enable Register*/
79
tms570_lin_t
80
81
82
/*----------------------TMS570_LIN_GCR0----------------------*/
83
/* field: Reserved - Read returns 0. Writes have no effect. */
84
#define TMS570_LIN_GCR0_Reserved(val) BSP_FLD32(val,1, 31)
85
#define TMS570_LIN_GCR0_Reserved_GET(reg) BSP_FLD32GET(reg,1, 31)
86
#define TMS570_LIN_GCR0_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,1, 31)
87
88
/* field: RESET - This bit resets the SCI module. */
89
#define TMS570_LIN_GCR0_RESET BSP_BIT32(0)
90
91
92
/*----------------------TMS570_LIN_GCR1----------------------*/
93
/* field: TXENA - Transmit enable. */
94
#define TMS570_LIN_GCR1_TXENA BSP_BIT32(25)
95
96
/* field: RXENA - Receive enable. RXENA allows or prevents the transfer of data from SCIRXSHF to SCIRD. */
97
#define TMS570_LIN_GCR1_RXENA BSP_BIT32(24)
98
99
/* field: CONT - Continue on suspend. */
100
#define TMS570_LIN_GCR1_CONT BSP_BIT32(17)
101
102
/* field: LOOP_BACK - Loopback bit. The self-checking option for the SCI can be selected with this bit. */
103
#define TMS570_LIN_GCR1_LOOP_BACK BSP_BIT32(16)
104
105
/* field: POWERDOWN - If the POWERDOWN bit is set while the receiver is actively receiving data and the wake-up */
106
#define TMS570_LIN_GCR1_POWERDOWN BSP_BIT32(9)
107
108
/* field: SLEEP - SCI sleep. In a multiprocessor configuration, this bit controls the receive sleep function. */
109
#define TMS570_LIN_GCR1_SLEEP BSP_BIT32(8)
110
111
/* field: SWnRST - Software reset (active low). This bit is effective in LIN and SCI modes. */
112
#define TMS570_LIN_GCR1_SWnRST BSP_BIT32(7)
113
114
/* field: CLOCK - CLOCK */
115
#define TMS570_LIN_GCR1_CLOCK BSP_BIT32(5)
116
117
/* field: STOP - SCI number of stop bits per frame. */
118
#define TMS570_LIN_GCR1_STOP BSP_BIT32(4)
119
120
/* field: PARITY - SCI parity odd/even selection. If the PARITY ENA bit is set, PARITY designates odd or even parity. */
121
#define TMS570_LIN_GCR1_PARITY BSP_BIT32(3)
122
123
/* field: PARITY_ENA - Parity enable. This bit enables or disables the parity function. */
124
#define TMS570_LIN_GCR1_PARITY_ENA BSP_BIT32(2)
125
126
/* field: TIMING_MODE - SCI timing mode bit. */
127
#define TMS570_LIN_GCR1_TIMING_MODE BSP_BIT32(1)
128
129
/* field: COMM_MODE - SCI communication mode bit. */
130
#define TMS570_LIN_GCR1_COMM_MODE BSP_BIT32(0)
131
132
133
/*----------------------TMS570_LIN_GCR2----------------------*/
134
/* field: CC - Compare checksum. LIN mode only. */
135
#define TMS570_LIN_GCR2_CC BSP_BIT32(17)
136
137
/* field: SC - Send checksum byte. This bit is effective in LIN mode only. */
138
#define TMS570_LIN_GCR2_SC BSP_BIT32(16)
139
140
/* field: GEN_WU - Generate wakeup signal. This bit is effective in LIN mode only. */
141
#define TMS570_LIN_GCR2_GEN_WU BSP_BIT32(8)
142
143
/* field: POWERDOWN - Power down. This bit is effective in LIN or SCI mode. */
144
#define TMS570_LIN_GCR2_POWERDOWN BSP_BIT32(0)
145
146
147
/*---------------------TMS570_LIN_SETINT---------------------*/
148
/* field: SET_FE_INT - */
149
#define TMS570_LIN_SETINT_SET_FE_INT BSP_BIT32(26)
150
151
/* field: SET_OE_INT - SET OE INT */
152
#define TMS570_LIN_SETINT_SET_OE_INT BSP_BIT32(25)
153
154
/* field: SET_PE_INT - Set parity interrupt. */
155
#define TMS570_LIN_SETINT_SET_PE_INT BSP_BIT32(24)
156
157
/* field: SET_RX_DMA_ALL - SET RX DMA ALL */
158
#define TMS570_LIN_SETINT_SET_RX_DMA_ALL BSP_BIT32(18)
159
160
/* field: SET_RX_DMA - SET RX DMA */
161
#define TMS570_LIN_SETINT_SET_RX_DMA BSP_BIT32(17)
162
163
/* field: SET_TX_DMA - Set transmit DMA. To enable DMA requests for the transmitter, this bit must be set. */
164
#define TMS570_LIN_SETINT_SET_TX_DMA BSP_BIT32(16)
165
166
/* field: SET_RX_INT - SET RX INT */
167
#define TMS570_LIN_SETINT_SET_RX_INT BSP_BIT32(9)
168
169
/* field: SET_TX_INT - Set transmitter interrupt. */
170
#define TMS570_LIN_SETINT_SET_TX_INT BSP_BIT32(8)
171
172
/* field: SET_WAKEUP_INT - Set wakeup interrupt. */
173
#define TMS570_LIN_SETINT_SET_WAKEUP_INT BSP_BIT32(1)
174
175
/* field: SET_BRKDT_INT - Set breakdetect interrupt. */
176
#define TMS570_LIN_SETINT_SET_BRKDT_INT BSP_BIT32(0)
177
178
179
/*--------------------TMS570_LIN_CLEARINT--------------------*/
180
/* field: CLR_FE_INT - Clear framing-error interrupt. This bit disables the framing-error interrupt when set. */
181
#define TMS570_LIN_CLEARINT_CLR_FE_INT BSP_BIT32(26)
182
183
/* field: CLR_CE_INT - Clear overrun-error interrupt. This bit disables the SCI overrun error interrupt when set. */
184
#define TMS570_LIN_CLEARINT_CLR_CE_INT BSP_BIT32(25)
185
186
/* field: CLR_PE_INT - Clear parity interrupt. This bit disables the parity error interrupt when set. */
187
#define TMS570_LIN_CLEARINT_CLR_PE_INT BSP_BIT32(24)
188
189
/* field: CLR_RX_DMA_ALL - Clear receive DMA all. This bit clears the receive DMA request for address frames when set. */
190
#define TMS570_LIN_CLEARINT_CLR_RX_DMA_ALL BSP_BIT32(18)
191
192
/* field: CLR_RX_DMA - Clear receive DMA request. This bit disables the receive DMA request when set. */
193
#define TMS570_LIN_CLEARINT_CLR_RX_DMA BSP_BIT32(17)
194
195
/* field: CLR_TX_DMA - CLR TX DMA */
196
#define TMS570_LIN_CLEARINT_CLR_TX_DMA BSP_BIT32(16)
197
198
/* field: CLR_RX_INT - Clear receiver interrupt. This bit disables the receiver interrupt when set. */
199
#define TMS570_LIN_CLEARINT_CLR_RX_INT BSP_BIT32(9)
200
201
/* field: CLR_TX_INT - Clear transmitter interrupt. This bit disables the transmitter interrupt when set. */
202
#define TMS570_LIN_CLEARINT_CLR_TX_INT BSP_BIT32(8)
203
204
/* field: CLR_WAKEUP_INT - Clear wakeup interrupt. This bit disables the wakeup interrupt when set. */
205
#define TMS570_LIN_CLEARINT_CLR_WAKEUP_INT BSP_BIT32(1)
206
207
/* field: CLR_BRKDT_INT - Clear breakdetect interrupt. This bit disables the break-detect interrupt when set. */
208
#define TMS570_LIN_CLEARINT_CLR_BRKDT_INT BSP_BIT32(0)
209
210
211
/*--------------------TMS570_LIN_SETINTLVL--------------------*/
212
/* field: SET_FE_INT_LVL - Set framing-error interrupt level. */
213
#define TMS570_LIN_SETINTLVL_SET_FE_INT_LVL BSP_BIT32(26)
214
215
/* field: SET_CE_INT_LVL - Set overrun-error interrupt level. */
216
#define TMS570_LIN_SETINTLVL_SET_CE_INT_LVL BSP_BIT32(25)
217
218
/* field: SET_PE_INT_LVL - Set parity error interrupt level. */
219
#define TMS570_LIN_SETINTLVL_SET_PE_INT_LVL BSP_BIT32(24)
220
221
/* field: SET_RX_DMA_ALL_LVL - Set receive DMA all interrupt levels. */
222
#define TMS570_LIN_SETINTLVL_SET_RX_DMA_ALL_LVL BSP_BIT32(18)
223
224
/* field: SET_RX_INT_LVL - Set receiver interrupt level. */
225
#define TMS570_LIN_SETINTLVL_SET_RX_INT_LVL BSP_BIT32(9)
226
227
/* field: SET_TX_INT_LVL - Set transmitter interrupt level. */
228
#define TMS570_LIN_SETINTLVL_SET_TX_INT_LVL BSP_BIT32(8)
229
230
/* field: SET_WAKEUP_INT_LVL - Set wakeup interrupt level. */
231
#define TMS570_LIN_SETINTLVL_SET_WAKEUP_INT_LVL BSP_BIT32(1)
232
233
/* field: SET_BRKDT_INT_LVL - SET BRKDT INT LVL */
234
#define TMS570_LIN_SETINTLVL_SET_BRKDT_INT_LVL BSP_BIT32(0)
235
236
237
/*-------------------TMS570_LIN_CLEARINTLVL-------------------*/
238
/* field: CLR_FE_INT_LVL - Clear framing-error interrupt. */
239
#define TMS570_LIN_CLEARINTLVL_CLR_FE_INT_LVL BSP_BIT32(26)
240
241
/* field: CLR_CE_INT_LVL - CLR CE INT LVL */
242
#define TMS570_LIN_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
243
244
245
246
247
/* field: CLR_PE_INT_LVL - */
248
#define TMS570_LIN_CLEARINTLVL_CLR_PE_INT_LVL BSP_BIT32(24)
249
250
/* field: CLR_RX_DMA_ALL_LVL - Clear receive DMA interrupt level. */
251
#define TMS570_LIN_CLEARINTLVL_CLR_RX_DMA_ALL_LVL BSP_BIT32(18)
252
253
/* field: CLR_RX_INT_LVL - Clear receiver interrupt. */
254
#define TMS570_LIN_CLEARINTLVL_CLR_RX_INT_LVL BSP_BIT32(9)
255
256
/* field: 8 - CLR TX INT LVL Clear transmitter interrupt. */
257
#define TMS570_LIN_CLEARINTLVL_8 BSP_BIT32(8)
258
259
/* field: CLR_WAKEUP_INT_LVL - Clear wakeup interrupt. */
260
#define TMS570_LIN_CLEARINTLVL_CLR_WAKEUP_INT_LVL BSP_BIT32(1)
261
262
/* field: CLR_BRKDT_INT_LVL - Clear breakdetect interrupt. */
263
#define TMS570_LIN_CLEARINTLVL_CLR_BRKDT_INT_LVL BSP_BIT32(0)
264
265
266
/*-----------------------TMS570_LIN_FLR-----------------------*/
267
/* field: FE - Framing error flag. This bit is effective in LIN or SCI-compatible mode. */
268
#define TMS570_LIN_FLR_FE BSP_BIT32(26)
269
270
/* field: OE - Overrun error flag. */
271
#define TMS570_LIN_FLR_OE BSP_BIT32(25)
272
273
/* field: PE - Parity error flag. This bit is set when a parity error is detected in the received data. */
274
#define TMS570_LIN_FLR_PE BSP_BIT32(24)
275
276
/* field: RXWAKE - Receiver wakeup detect flag. */
277
#define TMS570_LIN_FLR_RXWAKE BSP_BIT32(12)
278
279
/* field: TX_EMPTY - Transmitter empty flag. */
280
#define TMS570_LIN_FLR_TX_EMPTY BSP_BIT32(11)
281
282
/* field: TXWAKE - Transmitter wakeup method select. */
283
#define TMS570_LIN_FLR_TXWAKE BSP_BIT32(10)
284
285
/* field: RXRDY - Receiver ready flag. */
286
#define TMS570_LIN_FLR_RXRDY BSP_BIT32(9)
287
288
/* field: TXRDY - Transmitter buffer register ready flag. */
289
#define TMS570_LIN_FLR_TXRDY BSP_BIT32(8)
290
291
/* field: BUSY - Bus busy flag. TThis bit indicates whether the receiver is in the process of receiving a frame. */
292
#define TMS570_LIN_FLR_BUSY BSP_BIT32(3)
293
294
/* field: IDLE - SCI receiver in idle state. */
295
#define TMS570_LIN_FLR_IDLE BSP_BIT32(2)
296
297
/* field: WAKEUP - Wakeup flag. */
298
#define TMS570_LIN_FLR_WAKEUP BSP_BIT32(1)
299
300
/* field: BRKDT - SCI break-detect flag. This bit is set when the SCI detects a break condition on the LINRX pin. */
301
#define TMS570_LIN_FLR_BRKDT BSP_BIT32(0)
302
303
304
/*--------------------TMS570_LIN_INTVECT0--------------------*/
305
/* field: INVECT0 - Interrupt vector offset for INT0. This register indicates the offset for interrupt line INT0. */
306
#define TMS570_LIN_INTVECT0_INVECT0(val) BSP_FLD32(val,0, 3)
307
#define TMS570_LIN_INTVECT0_INVECT0_GET(reg) BSP_FLD32GET(reg,0, 3)
308
#define TMS570_LIN_INTVECT0_INVECT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
309
310
311
/*--------------------TMS570_LIN_INTVECT1--------------------*/
312
/* field: INVECT1 - Interrupt vector offset for INT1. This register indicates the offset for interrupt line INT1. */
313
#define TMS570_LIN_INTVECT1_INVECT1(val) BSP_FLD32(val,0, 3)
314
#define TMS570_LIN_INTVECT1_INVECT1_GET(reg) BSP_FLD32GET(reg,0, 3)
315
#define TMS570_LIN_INTVECT1_INVECT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
316
317
318
/*---------------------TMS570_LIN_FORMAT---------------------*/
319
/* field: CHAR - Character length control bits. These bits set the SCI character length from 1 to 8 bits. */
320
#define TMS570_LIN_FORMAT_CHAR(val) BSP_FLD32(val,0, 2)
321
#define TMS570_LIN_FORMAT_CHAR_GET(reg) BSP_FLD32GET(reg,0, 2)
322
#define TMS570_LIN_FORMAT_CHAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
323
324
325
/*-----------------------TMS570_LIN_BRS-----------------------*/
326
/* field: BAUD - SCI 24-bit baud selection. */
327
#define TMS570_LIN_BRS_BAUD(val) BSP_FLD32(val,0, 23)
328
#define TMS570_LIN_BRS_BAUD_GET(reg) BSP_FLD32GET(reg,0, 23)
329
#define TMS570_LIN_BRS_BAUD_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
330
331
332
/*-----------------------TMS570_LIN_ED-----------------------*/
333
/* field: ED - Emulator data. Reading SCIED[7:0] does not clear the RXRDY flag, unlike reading SCIRD. */
334
#define TMS570_LIN_ED_ED(val) BSP_FLD32(val,0, 7)
335
#define TMS570_LIN_ED_ED_GET(reg) BSP_FLD32GET(reg,0, 7)
336
#define TMS570_LIN_ED_ED_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
337
338
339
/*-----------------------TMS570_LIN_RD-----------------------*/
340
/* field: RD - Receiver data. */
341
#define TMS570_LIN_RD_RD(val) BSP_FLD32(val,0, 7)
342
#define TMS570_LIN_RD_RD_GET(reg) BSP_FLD32GET(reg,0, 7)
343
#define TMS570_LIN_RD_RD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
344
345
346
/*-----------------------TMS570_LIN_TD-----------------------*/
347
/* field: TD - Transmit data. Data to be transmitted is written to the SCITD register. */
348
#define TMS570_LIN_TD_TD(val) BSP_FLD32(val,0, 7)
349
#define TMS570_LIN_TD_TD_GET(reg) BSP_FLD32GET(reg,0, 7)
350
#define TMS570_LIN_TD_TD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
351
352
353
/*----------------------TMS570_LIN_PIO0----------------------*/
354
/* field: TX_FUNC - Transfer function. This bit defines the function of pin SCITX. */
355
#define TMS570_LIN_PIO0_TX_FUNC BSP_BIT32(2)
356
357
/* field: RX_FUNC - Receive function.This bit defines the function of pin SCIRX. */
358
#define TMS570_LIN_PIO0_RX_FUNC BSP_BIT32(1)
359
360
361
/*----------------------TMS570_LIN_PIO1----------------------*/
362
/* field: TX_DIR - Transmit pin direction. */
363
#define TMS570_LIN_PIO1_TX_DIR BSP_BIT32(2)
364
365
/* field: RX_DIR - Receive pin direction. */
366
#define TMS570_LIN_PIO1_RX_DIR BSP_BIT32(1)
367
368
369
/*----------------------TMS570_LIN_PIO2----------------------*/
370
/* field: TX_IN - Transmit pin in. This bit contains the current value on the SCITX pin. */
371
#define TMS570_LIN_PIO2_TX_IN BSP_BIT32(2)
372
373
/* field: RX_IN - Receive pin in. This bit contains the current value on the SCIRX pin. */
374
#define TMS570_LIN_PIO2_RX_IN BSP_BIT32(1)
375
376
377
/*----------------------TMS570_LIN_PIO3----------------------*/
378
/* field: TX_OUT - Transmit pin out. */
379
#define TMS570_LIN_PIO3_TX_OUT BSP_BIT32(2)
380
381
/* field: RX_OUT - Receive pin out. */
382
#define TMS570_LIN_PIO3_RX_OUT BSP_BIT32(1)
383
384
385
/*----------------------TMS570_LIN_PIO4----------------------*/
386
/* field: TX_SET - Transmit pin set. */
387
#define TMS570_LIN_PIO4_TX_SET BSP_BIT32(2)
388
389
/* field: RX_SET - Receive pin set. */
390
#define TMS570_LIN_PIO4_RX_SET BSP_BIT32(1)
391
392
393
/*----------------------TMS570_LIN_PIO5----------------------*/
394
/* field: TX_CLR - Transmit pin clear. */
395
#define TMS570_LIN_PIO5_TX_CLR BSP_BIT32(2)
396
397
/* field: RX_CLR - Receive pin clear. */
398
#define TMS570_LIN_PIO5_RX_CLR BSP_BIT32(1)
399
400
401
/*----------------------TMS570_LIN_PIO6----------------------*/
402
/* field: TX_PDR - Transmit pin open drain enable. */
403
#define TMS570_LIN_PIO6_TX_PDR BSP_BIT32(2)
404
405
/* field: RX_PDR - Receive pin open drain enable. */
406
#define TMS570_LIN_PIO6_RX_PDR BSP_BIT32(1)
407
408
409
/*----------------------TMS570_LIN_PIO7----------------------*/
410
/* field: TX_PD - Transmit pin pull control disable. This bit disables pull control capability on the input pin SCITX. */
411
#define TMS570_LIN_PIO7_TX_PD BSP_BIT32(2)
412
413
/* field: RX_PD - Receive pin pull control disable. This bit disables pull control capability on the input pin SCIRX. */
414
#define TMS570_LIN_PIO7_RX_PD BSP_BIT32(1)
415
416
417
/*----------------------TMS570_LIN_PIO8----------------------*/
418
/* field: TX_PSL - TX pin pull select. This bit selects pull type in the input pin SCITX. */
419
#define TMS570_LIN_PIO8_TX_PSL BSP_BIT32(2)
420
421
/* field: RX_PSL - RX pin pull select. This bit selects pull type in the input pin SCIRX. */
422
#define TMS570_LIN_PIO8_RX_PSL BSP_BIT32(1)
423
424
425
/*----------------------TMS570_LIN_COMP----------------------*/
426
/* field: SDEL - 2-bit synch delimiter compare. These bits are effective in LIN mode only. */
427
#define TMS570_LIN_COMP_SDEL(val) BSP_FLD32(val,8, 9)
428
#define TMS570_LIN_COMP_SDEL_GET(reg) BSP_FLD32GET(reg,8, 9)
429
#define TMS570_LIN_COMP_SDEL_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
430
431
/* field: SBREAK - Synch break extend. These bits are effective in LIN mode only. */
432
#define TMS570_LIN_COMP_SBREAK(val) BSP_FLD32(val,0, 2)
433
#define TMS570_LIN_COMP_SBREAK_GET(reg) BSP_FLD32GET(reg,0, 2)
434
#define TMS570_LIN_COMP_SBREAK_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
435
436
437
/*-----------------------TMS570_LIN_RD0-----------------------*/
438
/* field: RD0 - Receive buffer 0. Byte 0 of the response data byte. */
439
#define TMS570_LIN_RD0_RD0(val) BSP_FLD32(val,24, 31)
440
#define TMS570_LIN_RD0_RD0_GET(reg) BSP_FLD32GET(reg,24, 31)
441
#define TMS570_LIN_RD0_RD0_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
442
443
/* field: RD1 - Receive buffer 1. Byte 1 of the response data byte. */
444
#define TMS570_LIN_RD0_RD1(val) BSP_FLD32(val,16, 23)
445
#define TMS570_LIN_RD0_RD1_GET(reg) BSP_FLD32GET(reg,16, 23)
446
#define TMS570_LIN_RD0_RD1_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
447
448
/* field: RD2 - Receive buffer 2. Byte 2 of the response data byte. */
449
#define TMS570_LIN_RD0_RD2(val) BSP_FLD32(val,8, 15)
450
#define TMS570_LIN_RD0_RD2_GET(reg) BSP_FLD32GET(reg,8, 15)
451
#define TMS570_LIN_RD0_RD2_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
452
453
/* field: RD3 - Receive buffer 3. Byte 3 of the response data byte. */
454
#define TMS570_LIN_RD0_RD3(val) BSP_FLD32(val,0, 7)
455
#define TMS570_LIN_RD0_RD3_GET(reg) BSP_FLD32GET(reg,0, 7)
456
#define TMS570_LIN_RD0_RD3_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
457
458
459
/*-----------------------TMS570_LIN_RD1-----------------------*/
460
/* field: RD4 - Receive buffer 4. Byte 4 of the response data byte. */
461
#define TMS570_LIN_RD1_RD4(val) BSP_FLD32(val,24, 31)
462
#define TMS570_LIN_RD1_RD4_GET(reg) BSP_FLD32GET(reg,24, 31)
463
#define TMS570_LIN_RD1_RD4_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
464
465
/* field: RD5 - Receive buffer 5. Byte 5 of the response data byte. */
466
#define TMS570_LIN_RD1_RD5(val) BSP_FLD32(val,16, 23)
467
#define TMS570_LIN_RD1_RD5_GET(reg) BSP_FLD32GET(reg,16, 23)
468
#define TMS570_LIN_RD1_RD5_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
469
470
/* field: RD6 - Receive buffer 6. Byte 6 of the response data byte. */
471
#define TMS570_LIN_RD1_RD6(val) BSP_FLD32(val,8, 15)
472
#define TMS570_LIN_RD1_RD6_GET(reg) BSP_FLD32GET(reg,8, 15)
473
#define TMS570_LIN_RD1_RD6_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
474
475
/* field: RD7 - Receive buffer 7. Byte 7 of the response data byte. */
476
#define TMS570_LIN_RD1_RD7(val) BSP_FLD32(val,0, 7)
477
#define TMS570_LIN_RD1_RD7_GET(reg) BSP_FLD32GET(reg,0, 7)
478
#define TMS570_LIN_RD1_RD7_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
479
480
481
/*----------------------TMS570_LIN_MASK----------------------*/
482
/* field: RX_ID_MASK - Receive ID mask. These bits are effective in LIN mode only. */
483
#define TMS570_LIN_MASK_RX_ID_MASK(val) BSP_FLD32(val,16, 23)
484
#define TMS570_LIN_MASK_RX_ID_MASK_GET(reg) BSP_FLD32GET(reg,16, 23)
485
#define TMS570_LIN_MASK_RX_ID_MASK_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
486
487
/* field: TX_ID_MASK - Transmit ID mask. These bits are effective in LIN mode only. */
488
#define TMS570_LIN_MASK_TX_ID_MASK(val) BSP_FLD32(val,0, 7)
489
#define TMS570_LIN_MASK_TX_ID_MASK_GET(reg) BSP_FLD32GET(reg,0, 7)
490
#define TMS570_LIN_MASK_TX_ID_MASK_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
491
492
493
/*-----------------------TMS570_LIN_ID-----------------------*/
494
/* field: RECEIVED_ID - Received identification. These bits are effective in LIN mode only. */
495
#define TMS570_LIN_ID_RECEIVED_ID(val) BSP_FLD32(val,16, 23)
496
#define TMS570_LIN_ID_RECEIVED_ID_GET(reg) BSP_FLD32GET(reg,16, 23)
497
#define TMS570_LIN_ID_RECEIVED_ID_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
498
499
/* field: ID_SLAVETASK_BYTE - ID-SlaveTask Byte. These bits are effective in LIN mode only. */
500
#define TMS570_LIN_ID_ID_SLAVETASK_BYTE(val) BSP_FLD32(val,8, 15)
501
#define TMS570_LIN_ID_ID_SLAVETASK_BYTE_GET(reg) BSP_FLD32GET(reg,8, 15)
502
#define TMS570_LIN_ID_ID_SLAVETASK_BYTE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
503
504
/* field: ID_BYTE - ID byte. This field is effective in LIN mode only. This byte is the LIN mode message ID. */
505
#define TMS570_LIN_ID_ID_BYTE(val) BSP_FLD32(val,0, 7)
506
#define TMS570_LIN_ID_ID_BYTE_GET(reg) BSP_FLD32GET(reg,0, 7)
507
#define TMS570_LIN_ID_ID_BYTE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
508
509
510
/*-----------------------TMS570_LIN_TD0-----------------------*/
511
/* field: TD0 - 8-Bit transmit buffer 0. */
512
#define TMS570_LIN_TD0_TD0(val) BSP_FLD32(val,24, 31)
513
#define TMS570_LIN_TD0_TD0_GET(reg) BSP_FLD32GET(reg,24, 31)
514
#define TMS570_LIN_TD0_TD0_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
515
516
/* field: TD1 - 8-Bit transmit buffer 1. */
517
#define TMS570_LIN_TD0_TD1(val) BSP_FLD32(val,16, 23)
518
#define TMS570_LIN_TD0_TD1_GET(reg) BSP_FLD32GET(reg,16, 23)
519
#define TMS570_LIN_TD0_TD1_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
520
521
/* field: TD2 - 8-Bit transmit buffer 2. */
522
#define TMS570_LIN_TD0_TD2(val) BSP_FLD32(val,8, 15)
523
#define TMS570_LIN_TD0_TD2_GET(reg) BSP_FLD32GET(reg,8, 15)
524
#define TMS570_LIN_TD0_TD2_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
525
526
/* field: TD3 - 8-Bit transmit buffer 3. */
527
#define TMS570_LIN_TD0_TD3(val) BSP_FLD32(val,0, 7)
528
#define TMS570_LIN_TD0_TD3_GET(reg) BSP_FLD32GET(reg,0, 7)
529
#define TMS570_LIN_TD0_TD3_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
530
531
532
/*-----------------------TMS570_LIN_TD1-----------------------*/
533
/* field: TD4 - 8-Bit transmit buffer 4. */
534
#define TMS570_LIN_TD1_TD4(val) BSP_FLD32(val,24, 31)
535
#define TMS570_LIN_TD1_TD4_GET(reg) BSP_FLD32GET(reg,24, 31)
536
#define TMS570_LIN_TD1_TD4_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
537
538
/* field: TD5 - 8-Bit transmit buffer 5. */
539
#define TMS570_LIN_TD1_TD5(val) BSP_FLD32(val,16, 23)
540
#define TMS570_LIN_TD1_TD5_GET(reg) BSP_FLD32GET(reg,16, 23)
541
#define TMS570_LIN_TD1_TD5_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
542
543
/* field: TD6 - 8-Bit transmit buffer 6. */
544
#define TMS570_LIN_TD1_TD6(val) BSP_FLD32(val,8, 15)
545
#define TMS570_LIN_TD1_TD6_GET(reg) BSP_FLD32GET(reg,8, 15)
546
#define TMS570_LIN_TD1_TD6_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
547
548
/* field: TD7 - 8-Bit transmit buffer 7. */
549
#define TMS570_LIN_TD1_TD7(val) BSP_FLD32(val,0, 7)
550
#define TMS570_LIN_TD1_TD7_GET(reg) BSP_FLD32GET(reg,0, 7)
551
#define TMS570_LIN_TD1_TD7_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
552
553
554
/*----------------------TMS570_LIN_MBRSR----------------------*/
555
/* field: MBR - Maximum baud rate prescaler. This bit is effective in LIN mode only. */
556
#define TMS570_LIN_MBRSR_MBR(val) BSP_FLD32(val,0, 12)
557
#define TMS570_LIN_MBRSR_MBR_GET(reg) BSP_FLD32GET(reg,0, 12)
558
#define TMS570_LIN_MBRSR_MBR_SET(reg,val) BSP_FLD32SET(reg, val,0, 12)
559
560
561
/*--------------------TMS570_LIN_IODFTCTRL--------------------*/
562
/* field: FEN - Frame error enable. This bit is used to create a frame error. */
563
#define TMS570_LIN_IODFTCTRL_FEN BSP_BIT32(26)
564
565
/* field: PEN - Parity error enable. This bit is used to create a parity error. */
566
#define TMS570_LIN_IODFTCTRL_PEN BSP_BIT32(25)
567
568
/* field: BRKD_TENA - Break detect error enable. This bit is used to create a BRKDT error. */
569
#define TMS570_LIN_IODFTCTRL_BRKD_TENA BSP_BIT32(24)
570
571
/* field: PIN_SAMPLE_MASK - Pin sample mask. */
572
#define TMS570_LIN_IODFTCTRL_PIN_SAMPLE_MASK(val) BSP_FLD32(val,19, 20)
573
#define TMS570_LIN_IODFTCTRL_PIN_SAMPLE_MASK_GET(reg) BSP_FLD32GET(reg,19, 20)
574
#define TMS570_LIN_IODFTCTRL_PIN_SAMPLE_MASK_SET(reg,val) BSP_FLD32SET(reg, val,19, 20)
575
576
/* field: TX_SHIFT - Transmit shift. */
577
#define TMS570_LIN_IODFTCTRL_TX_SHIFT(val) BSP_FLD32(val,16, 18)
578
#define TMS570_LIN_IODFTCTRL_TX_SHIFT_GET(reg) BSP_FLD32GET(reg,16, 18)
579
#define TMS570_LIN_IODFTCTRL_TX_SHIFT_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
580
581
/* field: IODFTENA - IODFT enable key. Write access permitted in Privilege mode only. */
582
#define TMS570_LIN_IODFTCTRL_IODFTENA(val) BSP_FLD32(val,8, 11)
583
#define TMS570_LIN_IODFTCTRL_IODFTENA_GET(reg) BSP_FLD32GET(reg,8, 11)
584
#define TMS570_LIN_IODFTCTRL_IODFTENA_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
585
586
/* field: LPBENA - Module loopback enable. Write access permitted in Privilege mode only. */
587
#define TMS570_LIN_IODFTCTRL_LPBENA BSP_BIT32(1)
588
589
/* field: RXPENA - Module analog loopback through receive pin enable. */
590
#define TMS570_LIN_IODFTCTRL_RXPENA BSP_BIT32(0)
591
592
593
594
#endif
/* LIBBSP_ARM_TMS570_LIN */
utility.h
This header file provides utility macros for BSPs.
tms570_lin_t
Definition:
reg_lin.h:44
