39#ifndef LIBBSP_ARM_TMS570_IOMM
40#define LIBBSP_ARM_TMS570_IOMM
79 uint32_t REVISION_REG;
80 uint8_t reserved1 [28];
82 uint8_t reserved2 [20];
85 uint8_t reserved3 [160];
86 uint32_t ERR_RAW_STATUS_REG;
87 uint32_t ERR_ENABLED_STATUS_REG;
88 uint32_t ERR_ENABLE_REG;
89 uint32_t ERR_ENABLE_CLR_REG;
90 uint8_t reserved4 [4];
91 uint32_t FAULT_ADDRESS_REG;
92 uint32_t FAULT_STATUS_REG;
93 uint32_t FAULT_CLEAR_REG;
94 uint8_t reserved5 [16];
101#define TMS570_IOMM_PINMMRx_PINMMRx24To31(val) BSP_FLD32(val,24, 31)
102#define TMS570_IOMM_PINMMRx_PINMMRx24To31_GET(reg) BSP_FLD32GET(reg,24, 31)
103#define TMS570_IOMM_PINMMRx_PINMMRx24To31_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
106#define TMS570_IOMM_PINMMRx_PINMMRx16To23(val) BSP_FLD32(val,16, 23)
107#define TMS570_IOMM_PINMMRx_PINMMRx16To23_GET(reg) BSP_FLD32GET(reg,16, 23)
108#define TMS570_IOMM_PINMMRx_PINMMRx16To23_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
111#define TMS570_IOMM_PINMMRx_PINMMRx8To16(val) BSP_FLD32(val,8, 15)
112#define TMS570_IOMM_PINMMRx_PINMMRx8To16_GET(reg) BSP_FLD32GET(reg,8, 15)
113#define TMS570_IOMM_PINMMRx_PINMMRx8To16_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
116#define TMS570_IOMM_PINMMRx_PINMMRx0To7(val) BSP_FLD32(val,0, 7)
117#define TMS570_IOMM_PINMMRx_PINMMRx0To7_GET(reg) BSP_FLD32GET(reg,0, 7)
118#define TMS570_IOMM_PINMMRx_PINMMRx0To7_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
123#define TMS570_IOMM_REVISION_REG_REV_SCHEME(val) BSP_FLD32(val,30, 31)
124#define TMS570_IOMM_REVISION_REG_REV_SCHEME_GET(reg) BSP_FLD32GET(reg,30, 31)
125#define TMS570_IOMM_REVISION_REG_REV_SCHEME_SET(reg,val) BSP_FLD32SET(reg, val,30, 31)
128#define TMS570_IOMM_REVISION_REG_REV_MODULE(val) BSP_FLD32(val,16, 27)
129#define TMS570_IOMM_REVISION_REG_REV_MODULE_GET(reg) BSP_FLD32GET(reg,16, 27)
130#define TMS570_IOMM_REVISION_REG_REV_MODULE_SET(reg,val) BSP_FLD32SET(reg, val,16, 27)
133#define TMS570_IOMM_REVISION_REG_REV_RTL(val) BSP_FLD32(val,11, 15)
134#define TMS570_IOMM_REVISION_REG_REV_RTL_GET(reg) BSP_FLD32GET(reg,11, 15)
135#define TMS570_IOMM_REVISION_REG_REV_RTL_SET(reg,val) BSP_FLD32SET(reg, val,11, 15)
138#define TMS570_IOMM_REVISION_REG_REV_MAJOR(val) BSP_FLD32(val,8, 10)
139#define TMS570_IOMM_REVISION_REG_REV_MAJOR_GET(reg) BSP_FLD32GET(reg,8, 10)
140#define TMS570_IOMM_REVISION_REG_REV_MAJOR_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
143#define TMS570_IOMM_REVISION_REG_REV_CUSTOM(val) BSP_FLD32(val,6, 7)
144#define TMS570_IOMM_REVISION_REG_REV_CUSTOM_GET(reg) BSP_FLD32GET(reg,6, 7)
145#define TMS570_IOMM_REVISION_REG_REV_CUSTOM_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
148#define TMS570_IOMM_REVISION_REG_REV_MINOR(val) BSP_FLD32(val,0, 5)
149#define TMS570_IOMM_REVISION_REG_REV_MINOR_GET(reg) BSP_FLD32GET(reg,0, 5)
150#define TMS570_IOMM_REVISION_REG_REV_MINOR_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
155#define TMS570_IOMM_ENDIAN_REG_ENDIAN BSP_BIT32(0)
168#define TMS570_IOMM_ERR_RAW_STATUS_REG_ADDR_ERR BSP_BIT32(1)
171#define TMS570_IOMM_ERR_RAW_STATUS_REG_PROT_ERR BSP_BIT32(0)
176#define TMS570_IOMM_ERR_ENABLED_STATUS_REG_ENABLED_ADDR_ERR BSP_BIT32(1)
179#define TMS570_IOMM_ERR_ENABLED_STATUS_REG_ENABLED_PROT_ERR BSP_BIT32(0)
184#define TMS570_IOMM_ERR_ENABLE_REG_ADDR_ERR_EN BSP_BIT32(1)
187#define TMS570_IOMM_ERR_ENABLE_REG_PROT_ERR_EN BSP_BIT32(0)
192#define TMS570_IOMM_ERR_ENABLE_CLR_REG_ADDR_ERR_EN_CLR BSP_BIT32(1)
195#define TMS570_IOMM_ERR_ENABLE_CLR_REG_PROT_ERR_EN_CLR BSP_BIT32(0)
204#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID(val) BSP_FLD32(val,24, 27)
205#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID_GET(reg) BSP_FLD32GET(reg,24, 27)
206#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_ID_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
209#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID(val) BSP_FLD32(val,16, 23)
210#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID_GET(reg) BSP_FLD32GET(reg,16, 23)
211#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_MSTID_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
214#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID(val) BSP_FLD32(val,9, 12)
215#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID_GET(reg) BSP_FLD32GET(reg,9, 12)
216#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_PRIVID_SET(reg,val) BSP_FLD32SET(reg, val,9, 12)
219#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE(val) BSP_FLD32(val,0, 5)
220#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE_GET(reg) BSP_FLD32GET(reg,0, 5)
221#define TMS570_IOMM_FAULT_STATUS_REG_FAULT_TYPE_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
226#define TMS570_IOMM_FAULT_CLEAR_REG_FAULT_CLEAR BSP_BIT32(0)
231#define TMS570_IOMM_PINMUX_FAULT_CLEAR BSP_BIT32(0)
This header file provides utility macros for BSPs.
Definition: reg_iomm.h:78
Definition: reg_iomm.h:44
