RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_gio.h
1
/* The header file is generated by make_header.py from GIO.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_GIO
40
#define LIBBSP_ARM_TMS570_GIO
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t DIR;
/*GIO Data Direction Register*/
46
uint32_t DIN;
/*GIO Data Input Register*/
47
uint32_t DOUT;
/*GIO Data Output Register*/
48
uint32_t DSET;
/*GIO Data Set Register*/
49
uint32_t DCLR;
/*GIO Data Clear Register*/
50
uint32_t PDR;
/*GIO Open Drain Register*/
51
uint32_t PULDIS;
/*GIO Pull Disable Register*/
52
uint32_t PSL;
/*GIO Pull Select Register*/
53
tms570_gio_port_t
54
55
typedef
struct
56
uint32_t GCR0;
/*GIO Global Control Register*/
57
uint8_t reserved1 [4];
58
uint32_t INTDET;
/*GIO Interrupt Detect Register*/
59
uint32_t POL;
/*GIO Interrupt Polarity Register*/
60
uint32_t ENASET;
/*GIO Interrupt Enable Set Register*/
61
uint32_t ENACLR;
/*GIO Interrupt Enable Clear Register*/
62
uint32_t LVLSET;
/*GIO Interrupt Priority Set Register*/
63
uint32_t LVLCLR;
/*GIO Interrupt Priority Clear Register*/
64
uint32_t FLG;
/*GIO Interrupt Flag Register*/
65
uint32_t OFF1;
/*GIO Offset 1 Register*/
66
uint32_t OFF2;
/*GIO Offset 2 Register*/
67
uint32_t EMU1;
/*GIO Emulation 1 Register*/
68
uint32_t EMU2;
/*GIO Emulation 2 Register*/
69
tms570_gio_port_t
ports[8];
/*GIO ports*/
70
tms570_gio_t
71
72
73
/*-----------------------TMS570_GIO_DIR-----------------------*/
74
/* field: GIODIR - GIO data direction, pins [7:0] */
75
#define TMS570_GIO_DIR_GIODIR(val) BSP_FLD32(val,0, 7)
76
#define TMS570_GIO_DIR_GIODIR_GET(reg) BSP_FLD32GET(reg,0, 7)
77
#define TMS570_GIO_DIR_GIODIR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
78
79
80
/*-----------------------TMS570_GIO_DIN-----------------------*/
81
/* field: GIODIN - GIO data input, pins [7:0] */
82
#define TMS570_GIO_DIN_GIODIN(val) BSP_FLD32(val,0, 7)
83
#define TMS570_GIO_DIN_GIODIN_GET(reg) BSP_FLD32GET(reg,0, 7)
84
#define TMS570_GIO_DIN_GIODIN_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
85
86
87
/*----------------------TMS570_GIO_DOUT----------------------*/
88
/* field: GIODOUT - IO data output, pins[7:0]. */
89
#define TMS570_GIO_DOUT_GIODOUT(val) BSP_FLD32(val,0, 7)
90
#define TMS570_GIO_DOUT_GIODOUT_GET(reg) BSP_FLD32GET(reg,0, 7)
91
#define TMS570_GIO_DOUT_GIODOUT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
92
93
94
/*----------------------TMS570_GIO_DSET----------------------*/
95
/* field: GIODSET - GIO data set, pins[7:0]. This bit drives the output of GIO pin high. */
96
#define TMS570_GIO_DSET_GIODSET(val) BSP_FLD32(val,0, 7)
97
#define TMS570_GIO_DSET_GIODSET_GET(reg) BSP_FLD32GET(reg,0, 7)
98
#define TMS570_GIO_DSET_GIODSET_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
99
100
101
/*----------------------TMS570_GIO_DCLR----------------------*/
102
/* field: GIODCLR - GIO data clear, pins[7:0]. This bit drives the output of GIO pin low. */
103
#define TMS570_GIO_DCLR_GIODCLR(val) BSP_FLD32(val,0, 7)
104
#define TMS570_GIO_DCLR_GIODCLR_GET(reg) BSP_FLD32GET(reg,0, 7)
105
#define TMS570_GIO_DCLR_GIODCLR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
106
107
108
/*-----------------------TMS570_GIO_PDR-----------------------*/
109
/* field: 7_0 - GIOPDRH GIO open drain, pins[7:0] */
110
#define TMS570_GIO_PDR_7_0(val) BSP_FLD32(val,0, 7)
111
#define TMS570_GIO_PDR_7_0_GET(reg) BSP_FLD32GET(reg,0, 7)
112
#define TMS570_GIO_PDR_7_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
113
114
115
/*---------------------TMS570_GIO_PULDIS---------------------*/
116
/* field: GIOPULDIS - GIO pull disable, pins[7:0]. */
117
#define TMS570_GIO_PULDIS_GIOPULDIS(val) BSP_FLD32(val,0, 7)
118
#define TMS570_GIO_PULDIS_GIOPULDIS_GET(reg) BSP_FLD32GET(reg,0, 7)
119
#define TMS570_GIO_PULDIS_GIOPULDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
120
121
122
/*-----------------------TMS570_GIO_PSL-----------------------*/
123
/* field: GIOPSL - GIO pull select, pins[7:0] */
124
#define TMS570_GIO_PSL_GIOPSL(val) BSP_FLD32(val,0, 7)
125
#define TMS570_GIO_PSL_GIOPSL_GET(reg) BSP_FLD32GET(reg,0, 7)
126
#define TMS570_GIO_PSL_GIOPSL_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
127
128
129
/*----------------------TMS570_GIO_GCR0----------------------*/
130
/* field: RESET - GIO reset. */
131
#define TMS570_GIO_GCR0_RESET BSP_BIT32(0)
132
133
134
/*---------------------TMS570_GIO_INTDET---------------------*/
135
/* field: GIOINTDET_3 - Interrupt detection select for pins GIOD[7:0] */
136
#define TMS570_GIO_INTDET_GIOINTDET_3(val) BSP_FLD32(val,24, 31)
137
#define TMS570_GIO_INTDET_GIOINTDET_3_GET(reg) BSP_FLD32GET(reg,24, 31)
138
#define TMS570_GIO_INTDET_GIOINTDET_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
139
140
/* field: GIOINTDET_2 - Interrupt detection select for pins GIOC[7:0] */
141
#define TMS570_GIO_INTDET_GIOINTDET_2(val) BSP_FLD32(val,16, 23)
142
#define TMS570_GIO_INTDET_GIOINTDET_2_GET(reg) BSP_FLD32GET(reg,16, 23)
143
#define TMS570_GIO_INTDET_GIOINTDET_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
144
145
/* field: GIOINTDET_1 - Interrupt detection select for pins GIOB[7:0] */
146
#define TMS570_GIO_INTDET_GIOINTDET_1(val) BSP_FLD32(val,8, 15)
147
#define TMS570_GIO_INTDET_GIOINTDET_1_GET(reg) BSP_FLD32GET(reg,8, 15)
148
#define TMS570_GIO_INTDET_GIOINTDET_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
149
150
/* field: GIOINTDET_0 - Interrupt detection select for pins GIOA[7:0] */
151
#define TMS570_GIO_INTDET_GIOINTDET_0(val) BSP_FLD32(val,0, 7)
152
#define TMS570_GIO_INTDET_GIOINTDET_0_GET(reg) BSP_FLD32GET(reg,0, 7)
153
#define TMS570_GIO_INTDET_GIOINTDET_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
154
155
156
/*-----------------------TMS570_GIO_POL-----------------------*/
157
/* field: GIOPOL_3 - Interrupt polarity select for pins GIOD[7:0] */
158
#define TMS570_GIO_POL_GIOPOL_3(val) BSP_FLD32(val,24, 31)
159
#define TMS570_GIO_POL_GIOPOL_3_GET(reg) BSP_FLD32GET(reg,24, 31)
160
#define TMS570_GIO_POL_GIOPOL_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
161
162
/* field: GIOPOL_2 - Interrupt polarity select for pins GIOC[7:0] */
163
#define TMS570_GIO_POL_GIOPOL_2(val) BSP_FLD32(val,16, 23)
164
#define TMS570_GIO_POL_GIOPOL_2_GET(reg) BSP_FLD32GET(reg,16, 23)
165
#define TMS570_GIO_POL_GIOPOL_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
166
167
/* field: GIOPOL_1 - Interrupt polarity select for pins GIOB[7:0] */
168
#define TMS570_GIO_POL_GIOPOL_1(val) BSP_FLD32(val,8, 15)
169
#define TMS570_GIO_POL_GIOPOL_1_GET(reg) BSP_FLD32GET(reg,8, 15)
170
#define TMS570_GIO_POL_GIOPOL_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
171
172
/* field: GIOPOL_0 - Interrupt polarity select for pins GIOA[7:0] */
173
#define TMS570_GIO_POL_GIOPOL_0(val) BSP_FLD32(val,0, 7)
174
#define TMS570_GIO_POL_GIOPOL_0_GET(reg) BSP_FLD32GET(reg,0, 7)
175
#define TMS570_GIO_POL_GIOPOL_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
176
177
178
/*---------------------TMS570_GIO_ENASET---------------------*/
179
/* field: GIOENASET_3 - nterrupt enable for pins GIOD[7:0] */
180
#define TMS570_GIO_ENASET_GIOENASET_3(val) BSP_FLD32(val,24, 31)
181
#define TMS570_GIO_ENASET_GIOENASET_3_GET(reg) BSP_FLD32GET(reg,24, 31)
182
#define TMS570_GIO_ENASET_GIOENASET_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
183
184
/* field: GIOENASET_2 - Interrupt enable for pins GIOC[7:0] */
185
#define TMS570_GIO_ENASET_GIOENASET_2(val) BSP_FLD32(val,16, 23)
186
#define TMS570_GIO_ENASET_GIOENASET_2_GET(reg) BSP_FLD32GET(reg,16, 23)
187
#define TMS570_GIO_ENASET_GIOENASET_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
188
189
/* field: GIOENASET_1 - Interrupt enable for pins GIOB[7:0] */
190
#define TMS570_GIO_ENASET_GIOENASET_1(val) BSP_FLD32(val,8, 15)
191
#define TMS570_GIO_ENASET_GIOENASET_1_GET(reg) BSP_FLD32GET(reg,8, 15)
192
#define TMS570_GIO_ENASET_GIOENASET_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
193
194
/* field: GIOENASET_0 - Interrupt enable for pins GIOA[7:0] */
195
#define TMS570_GIO_ENASET_GIOENASET_0(val) BSP_FLD32(val,0, 7)
196
#define TMS570_GIO_ENASET_GIOENASET_0_GET(reg) BSP_FLD32GET(reg,0, 7)
197
#define TMS570_GIO_ENASET_GIOENASET_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
198
199
200
/*---------------------TMS570_GIO_ENACLR---------------------*/
201
/* field: GIOENACLR_3 - Interrupt enable for pins GIOD[7:0] */
202
#define TMS570_GIO_ENACLR_GIOENACLR_3(val) BSP_FLD32(val,24, 31)
203
#define TMS570_GIO_ENACLR_GIOENACLR_3_GET(reg) BSP_FLD32GET(reg,24, 31)
204
#define TMS570_GIO_ENACLR_GIOENACLR_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
205
206
/* field: GIOENACLR_2 - Interrupt enable for pins GIOC[7:0] */
207
#define TMS570_GIO_ENACLR_GIOENACLR_2(val) BSP_FLD32(val,16, 23)
208
#define TMS570_GIO_ENACLR_GIOENACLR_2_GET(reg) BSP_FLD32GET(reg,16, 23)
209
#define TMS570_GIO_ENACLR_GIOENACLR_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
210
211
/* field: GIOENACLR_1 - Interrupt enable for pins GIOB[7:0] */
212
#define TMS570_GIO_ENACLR_GIOENACLR_1(val) BSP_FLD32(val,8, 15)
213
#define TMS570_GIO_ENACLR_GIOENACLR_1_GET(reg) BSP_FLD32GET(reg,8, 15)
214
#define TMS570_GIO_ENACLR_GIOENACLR_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
215
216
/* field: GIOENACLR_0 - Interrupt enable for pins GIOA[7:0] */
217
#define TMS570_GIO_ENACLR_GIOENACLR_0(val) BSP_FLD32(val,0, 7)
218
#define TMS570_GIO_ENACLR_GIOENACLR_0_GET(reg) BSP_FLD32GET(reg,0, 7)
219
#define TMS570_GIO_ENACLR_GIOENACLR_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
220
221
222
/*---------------------TMS570_GIO_LVLSET---------------------*/
223
/* field: GIOLVLSET_3 - GIO high priority interrupt for pins GIOD[7:0]. */
224
#define TMS570_GIO_LVLSET_GIOLVLSET_3(val) BSP_FLD32(val,24, 31)
225
#define TMS570_GIO_LVLSET_GIOLVLSET_3_GET(reg) BSP_FLD32GET(reg,24, 31)
226
#define TMS570_GIO_LVLSET_GIOLVLSET_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
227
228
/* field: GIOLVLSET_2 - GIO high priority interrupt for pins GIOC[7:0]. */
229
#define TMS570_GIO_LVLSET_GIOLVLSET_2(val) BSP_FLD32(val,16, 23)
230
#define TMS570_GIO_LVLSET_GIOLVLSET_2_GET(reg) BSP_FLD32GET(reg,16, 23)
231
#define TMS570_GIO_LVLSET_GIOLVLSET_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
232
233
/* field: GIOLVLSET_1 - GIO high priority interrupt for pins GIOB[7:0]. */
234
#define TMS570_GIO_LVLSET_GIOLVLSET_1(val) BSP_FLD32(val,8, 15)
235
#define TMS570_GIO_LVLSET_GIOLVLSET_1_GET(reg) BSP_FLD32GET(reg,8, 15)
236
#define TMS570_GIO_LVLSET_GIOLVLSET_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
237
238
/* field: GIOLVLSET_0 - GIO high priority interrupt for pins GIOA[7:0]. */
239
#define TMS570_GIO_LVLSET_GIOLVLSET_0(val) BSP_FLD32(val,0, 7)
240
#define TMS570_GIO_LVLSET_GIOLVLSET_0_GET(reg) BSP_FLD32GET(reg,0, 7)
241
#define TMS570_GIO_LVLSET_GIOLVLSET_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
242
243
244
/*---------------------TMS570_GIO_LVLCLR---------------------*/
245
/* field: GIOLVLCLR_3 - GIO low priority interrupt for pins GIOD[7:0] */
246
#define TMS570_GIO_LVLCLR_GIOLVLCLR_3(val) BSP_FLD32(val,24, 31)
247
#define TMS570_GIO_LVLCLR_GIOLVLCLR_3_GET(reg) BSP_FLD32GET(reg,24, 31)
248
#define TMS570_GIO_LVLCLR_GIOLVLCLR_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
249
250
/* field: GIOLVLCLR_2 - GIO low priority interrupt for pins GIOC[7:0] */
251
#define TMS570_GIO_LVLCLR_GIOLVLCLR_2(val) BSP_FLD32(val,16, 23)
252
#define TMS570_GIO_LVLCLR_GIOLVLCLR_2_GET(reg) BSP_FLD32GET(reg,16, 23)
253
#define TMS570_GIO_LVLCLR_GIOLVLCLR_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
254
255
/* field: GIOLVLCLR_1 - GIO low priority interrupt for pins GIOB[7:0] */
256
#define TMS570_GIO_LVLCLR_GIOLVLCLR_1(val) BSP_FLD32(val,8, 15)
257
#define TMS570_GIO_LVLCLR_GIOLVLCLR_1_GET(reg) BSP_FLD32GET(reg,8, 15)
258
#define TMS570_GIO_LVLCLR_GIOLVLCLR_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
259
260
/* field: GIOLVLCLR_0 - GIO low priority interrupt for pins GIOA[7:0] */
261
#define TMS570_GIO_LVLCLR_GIOLVLCLR_0(val) BSP_FLD32(val,0, 7)
262
#define TMS570_GIO_LVLCLR_GIOLVLCLR_0_GET(reg) BSP_FLD32GET(reg,0, 7)
263
#define TMS570_GIO_LVLCLR_GIOLVLCLR_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
264
265
266
/*-----------------------TMS570_GIO_FLG-----------------------*/
267
/* field: GIOFLG_3 - GIO flag for pins GIOD[7:0]. */
268
#define TMS570_GIO_FLG_GIOFLG_3(val) BSP_FLD32(val,24, 31)
269
#define TMS570_GIO_FLG_GIOFLG_3_GET(reg) BSP_FLD32GET(reg,24, 31)
270
#define TMS570_GIO_FLG_GIOFLG_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
271
272
/* field: GIOFLG_2 - GIO flag for pins GIOC[7:0]. */
273
#define TMS570_GIO_FLG_GIOFLG_2(val) BSP_FLD32(val,16, 23)
274
#define TMS570_GIO_FLG_GIOFLG_2_GET(reg) BSP_FLD32GET(reg,16, 23)
275
#define TMS570_GIO_FLG_GIOFLG_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
276
277
/* field: GIOFLG_1 - GIO flag for pins GIOB[7:0]. */
278
#define TMS570_GIO_FLG_GIOFLG_1(val) BSP_FLD32(val,8, 15)
279
#define TMS570_GIO_FLG_GIOFLG_1_GET(reg) BSP_FLD32GET(reg,8, 15)
280
#define TMS570_GIO_FLG_GIOFLG_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
281
282
/* field: GIOFLG_0 - GIO flag for pins GIOA[7:0]. */
283
#define TMS570_GIO_FLG_GIOFLG_0(val) BSP_FLD32(val,0, 7)
284
#define TMS570_GIO_FLG_GIOFLG_0_GET(reg) BSP_FLD32GET(reg,0, 7)
285
#define TMS570_GIO_FLG_GIOFLG_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
286
287
288
/*----------------------TMS570_GIO_OFF1----------------------*/
289
/* field: GIOOFF1 - GIO offset 1. These bits index the currently pending high-priority interrupt. */
290
#define TMS570_GIO_OFF1_GIOOFF1(val) BSP_FLD32(val,0, 5)
291
#define TMS570_GIO_OFF1_GIOOFF1_GET(reg) BSP_FLD32GET(reg,0, 5)
292
#define TMS570_GIO_OFF1_GIOOFF1_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
293
294
295
/*----------------------TMS570_GIO_OFF2----------------------*/
296
/* field: GIOOFF2 - GIO offset 2. These bits index the currently pending low-priority interrupt. */
297
#define TMS570_GIO_OFF2_GIOOFF2(val) BSP_FLD32(val,0, 5)
298
#define TMS570_GIO_OFF2_GIOOFF2_GET(reg) BSP_FLD32GET(reg,0, 5)
299
#define TMS570_GIO_OFF2_GIOOFF2_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
300
301
302
/*----------------------TMS570_GIO_EMU1----------------------*/
303
/* field: GIOEMU1 - GIO offset emulation 1. These bits index the currently pending high-priority interrupt. */
304
#define TMS570_GIO_EMU1_GIOEMU1(val) BSP_FLD32(val,0, 5)
305
#define TMS570_GIO_EMU1_GIOEMU1_GET(reg) BSP_FLD32GET(reg,0, 5)
306
#define TMS570_GIO_EMU1_GIOEMU1_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
307
308
309
/*----------------------TMS570_GIO_EMU2----------------------*/
310
/* field: GIOEMU2 - GIO offset emulation 2. These bits index the currently pending low-priority interrupt. */
311
#define TMS570_GIO_EMU2_GIOEMU2(val) BSP_FLD32(val,0, 5)
312
#define TMS570_GIO_EMU2_GIOEMU2_GET(reg) BSP_FLD32GET(reg,0, 5)
313
#define TMS570_GIO_EMU2_GIOEMU2_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
314
315
316
/*----------------------TMS570_GIO_ports----------------------*/
317
318
#define TMS570_GIO_ports_GIOEMU2(val) BSP_FLD32(val,0, 5)
319
#define TMS570_GIO_ports_GIOEMU2_GET(reg) BSP_FLD32GET(reg,0, 5)
320
#define TMS570_GIO_ports_GIOEMU2_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
321
322
323
324
#endif
/* LIBBSP_ARM_TMS570_GIO */
utility.h
This header file provides utility macros for BSPs.
tms570_gio_port_t
Definition:
reg_gio.h:44
tms570_gio_t
Definition:
reg_gio.h:55
