39#ifndef LIBBSP_ARM_TMS570_FLASH
40#define LIBBSP_ARM_TMS570_FLASH
46 uint8_t reserved1 [4];
70 uint8_t reserved2 [4];
77 uint8_t reserved3 [64];
79 uint8_t reserved4 [452];
81 uint8_t reserved5 [24];
83 uint8_t reserved6 [16];
84 uint32_t EEPROMCONFIG;
85 uint8_t reserved7 [76];
93 uint8_t reserved8 [220];
100#define TMS570_FLASH_FRDCNTL_RWAIT(val) BSP_FLD32(val,8, 11)
101#define TMS570_FLASH_FRDCNTL_RWAIT_GET(reg) BSP_FLD32GET(reg,8, 11)
102#define TMS570_FLASH_FRDCNTL_RWAIT_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
105#define TMS570_FLASH_FRDCNTL_ASWSTEN BSP_BIT32(4)
108#define TMS570_FLASH_FRDCNTL_ENPIPE BSP_BIT32(0)
113#define TMS570_FLASH_FEDACTRL1_SUSP_IGNR BSP_BIT32(24)
116#define TMS570_FLASH_FEDACTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
117#define TMS570_FLASH_FEDACTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
118#define TMS570_FLASH_FEDACTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
121#define TMS570_FLASH_FEDACTRL1_EOFEN BSP_BIT32(10)
124#define TMS570_FLASH_FEDACTRL1_EZFEN BSP_BIT32(9)
127#define TMS570_FLASH_FEDACTRL1_EPEN BSP_BIT32(8)
130#define TMS570_FLASH_FEDACTRL1_EDACEN(val) BSP_FLD32(val,0, 3)
131#define TMS570_FLASH_FEDACTRL1_EDACEN_GET(reg) BSP_FLD32GET(reg,0, 3)
132#define TMS570_FLASH_FEDACTRL1_EDACEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
137#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
138#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
139#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
144#define TMS570_FLASH_FCORERRCNT_FERRCNT(val) BSP_FLD32(val,0, 15)
145#define TMS570_FLASH_FCORERRCNT_FERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
146#define TMS570_FLASH_FCORERRCNT_FERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
151#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
152#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
153#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
156#define TMS570_FLASH_FCORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
157#define TMS570_FLASH_FCORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
158#define TMS570_FLASH_FCORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
163#define TMS570_FLASH_FCORERRPOS_BUS2 BSP_BIT32(9)
166#define TMS570_FLASH_FCORERRPOS_TYPE BSP_BIT32(8)
169#define TMS570_FLASH_FCORERRPOS_ERR_POS(val) BSP_FLD32(val,0, 7)
170#define TMS570_FLASH_FCORERRPOS_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
171#define TMS570_FLASH_FCORERRPOS_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
176#define TMS570_FLASH_FEDACSTATUS_Reserved(val) BSP_FLD32(val,26, 31)
177#define TMS570_FLASH_FEDACSTATUS_Reserved_GET(reg) BSP_FLD32GET(reg,26, 31)
178#define TMS570_FLASH_FEDACSTATUS_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,26, 31)
181#define TMS570_FLASH_FEDACSTATUS_FSM_DONE BSP_BIT32(24)
184#define TMS570_FLASH_FEDACSTATUS_COMB2_MAL_G BSP_BIT32(19)
187#define TMS570_FLASH_FEDACSTATUS_ECC_B2_MAL_ BSP_BIT32(18)
190#define TMS570_FLASH_FEDACSTATUS_B2_UNC_ERR BSP_BIT32(17)
193#define TMS570_FLASH_FEDACSTATUS_B2_COR_ERR BSP_BIT32(16)
196#define TMS570_FLASH_FEDACSTATUS_D_UNC_ERR BSP_BIT32(12)
199#define TMS570_FLASH_FEDACSTATUS_ADD_TAG_ERR BSP_BIT32(11)
202#define TMS570_FLASH_FEDACSTATUS_ADD_PAR_ERR BSP_BIT32(10)
205#define TMS570_FLASH_FEDACSTATUS_B1_UNC_ERR BSP_BIT32(8)
208#define TMS570_FLASH_FEDACSTATUS_D_CORR_ERR BSP_BIT32(3)
211#define TMS570_FLASH_FEDACSTATUS_ERR_ONE_FLG BSP_BIT32(2)
214#define TMS570_FLASH_FEDACSTATUS_ERR_ZERO__FLG BSP_BIT32(1)
217#define TMS570_FLASH_FEDACSTATUS_ERR_PRF_FLG BSP_BIT32(0)
222#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
223#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
224#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
227#define TMS570_FLASH_FUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
228#define TMS570_FLASH_FUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
229#define TMS570_FLASH_FUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
234#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse(val) BSP_FLD32(val,29, 31)
235#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
236#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
239#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse(val) BSP_FLD32(val,24, 27)
240#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
241#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
244#define TMS570_FLASH_FEDACSDIS_BankID1(val) BSP_FLD32(val,21, 23)
245#define TMS570_FLASH_FEDACSDIS_BankID1_GET(reg) BSP_FLD32GET(reg,21, 23)
246#define TMS570_FLASH_FEDACSDIS_BankID1_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
249#define TMS570_FLASH_FEDACSDIS_SectorID1(val) BSP_FLD32(val,16, 19)
250#define TMS570_FLASH_FEDACSDIS_SectorID1_GET(reg) BSP_FLD32GET(reg,16, 19)
251#define TMS570_FLASH_FEDACSDIS_SectorID1_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
254#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse(val) BSP_FLD32(val,13, 15)
255#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
256#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
259#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse(val) BSP_FLD32(val,8, 11)
260#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
261#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
264#define TMS570_FLASH_FEDACSDIS_BankID0(val) BSP_FLD32(val,5, 7)
265#define TMS570_FLASH_FEDACSDIS_BankID0_GET(reg) BSP_FLD32GET(reg,5, 7)
266#define TMS570_FLASH_FEDACSDIS_BankID0_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
269#define TMS570_FLASH_FEDACSDIS_SectorID0(val) BSP_FLD32(val,0, 3)
270#define TMS570_FLASH_FEDACSDIS_SectorID0_GET(reg) BSP_FLD32GET(reg,0, 3)
271#define TMS570_FLASH_FEDACSDIS_SectorID0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
276#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG(val) BSP_FLD32(val,4, 31)
277#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
278#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
281#define TMS570_FLASH_FPRIMADDTAG_0(val) BSP_FLD32(val,0, 3)
282#define TMS570_FLASH_FPRIMADDTAG_0_GET(reg) BSP_FLD32GET(reg,0, 3)
283#define TMS570_FLASH_FPRIMADDTAG_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
288#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG(val) BSP_FLD32(val,4, 31)
289#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31)
290#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
295#define TMS570_FLASH_FBPROT_PROTL1DIS BSP_BIT32(0)
300#define TMS570_FLASH_FBSE_BSE(val) BSP_FLD32(val,0, 15)
301#define TMS570_FLASH_FBSE_BSE_GET(reg) BSP_FLD32GET(reg,0, 15)
302#define TMS570_FLASH_FBSE_BSE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
307#define TMS570_FLASH_FBBUSY_BUSY(val) BSP_FLD32(val,0, 7)
308#define TMS570_FLASH_FBBUSY_BUSY_GET(reg) BSP_FLD32GET(reg,0, 7)
309#define TMS570_FLASH_FBBUSY_BUSY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
314#define TMS570_FLASH_FBAC_OTPPROTDIS(val) BSP_FLD32(val,16, 23)
315#define TMS570_FLASH_FBAC_OTPPROTDIS_GET(reg) BSP_FLD32GET(reg,16, 23)
316#define TMS570_FLASH_FBAC_OTPPROTDIS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
319#define TMS570_FLASH_FBAC_15_8(val) BSP_FLD32(val,8, 15)
320#define TMS570_FLASH_FBAC_15_8_GET(reg) BSP_FLD32GET(reg,8, 15)
321#define TMS570_FLASH_FBAC_15_8_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
324#define TMS570_FLASH_FBAC_VREADST(val) BSP_FLD32(val,0, 7)
325#define TMS570_FLASH_FBAC_VREADST_GET(reg) BSP_FLD32GET(reg,0, 7)
326#define TMS570_FLASH_FBAC_VREADST_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
331#define TMS570_FLASH_FBFALLBACK_BANKPWR7(val) BSP_FLD32(val,14, 15)
332#define TMS570_FLASH_FBFALLBACK_BANKPWR7_GET(reg) BSP_FLD32GET(reg,14, 15)
333#define TMS570_FLASH_FBFALLBACK_BANKPWR7_SET(reg,val) BSP_FLD32SET(reg, val,14, 15)
336#define TMS570_FLASH_FBFALLBACK_BANKPWR1(val) BSP_FLD32(val,2, 3)
337#define TMS570_FLASH_FBFALLBACK_BANKPWR1_GET(reg) BSP_FLD32GET(reg,2, 3)
338#define TMS570_FLASH_FBFALLBACK_BANKPWR1_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
341#define TMS570_FLASH_FBFALLBACK_BANKPWR0(val) BSP_FLD32(val,0, 1)
342#define TMS570_FLASH_FBFALLBACK_BANKPWR0_GET(reg) BSP_FLD32GET(reg,0, 1)
343#define TMS570_FLASH_FBFALLBACK_BANKPWR0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
348#define TMS570_FLASH_FBPRDY_BANKBUSY(val) BSP_FLD32(val,16, 23)
349#define TMS570_FLASH_FBPRDY_BANKBUSY_GET(reg) BSP_FLD32GET(reg,16, 23)
350#define TMS570_FLASH_FBPRDY_BANKBUSY_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
353#define TMS570_FLASH_FBPRDY_PUMPRDY BSP_BIT32(15)
356#define TMS570_FLASH_FBPRDY_BANKRDY(val) BSP_FLD32(val,0, 7)
357#define TMS570_FLASH_FBPRDY_BANKRDY_GET(reg) BSP_FLD32GET(reg,0, 7)
358#define TMS570_FLASH_FBPRDY_BANKRDY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
363#define TMS570_FLASH_FPAC1_PSLEEP(val) BSP_FLD32(val,16, 26)
364#define TMS570_FLASH_FPAC1_PSLEEP_GET(reg) BSP_FLD32GET(reg,16, 26)
365#define TMS570_FLASH_FPAC1_PSLEEP_SET(reg,val) BSP_FLD32SET(reg, val,16, 26)
368#define TMS570_FLASH_FPAC1_PUMPPWR BSP_BIT32(0)
373#define TMS570_FLASH_FPAC2_PAGP(val) BSP_FLD32(val,0, 15)
374#define TMS570_FLASH_FPAC2_PAGP_GET(reg) BSP_FLD32GET(reg,0, 15)
375#define TMS570_FLASH_FPAC2_PAGP_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
380#define TMS570_FLASH_FMAC_BANK(val) BSP_FLD32(val,0, 2)
381#define TMS570_FLASH_FMAC_BANK_GET(reg) BSP_FLD32GET(reg,0, 2)
382#define TMS570_FLASH_FMAC_BANK_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
387#define TMS570_FLASH_FMSTAT_ILA BSP_BIT32(14)
390#define TMS570_FLASH_FMSTAT_PGV BSP_BIT32(12)
393#define TMS570_FLASH_FMSTAT_EV BSP_BIT32(10)
396#define TMS570_FLASH_FMSTAT_BUSY BSP_BIT32(8)
399#define TMS570_FLASH_FMSTAT_ERS BSP_BIT32(7)
402#define TMS570_FLASH_FMSTAT_PGM BSP_BIT32(6)
405#define TMS570_FLASH_FMSTAT_INVDAT BSP_BIT32(5)
408#define TMS570_FLASH_FMSTAT_CSTAT BSP_BIT32(4)
411#define TMS570_FLASH_FMSTAT_VOLTSTAT BSP_BIT32(3)
414#define TMS570_FLASH_FMSTAT_ESUSP BSP_BIT32(2)
417#define TMS570_FLASH_FMSTAT_PSUSP BSP_BIT32(1)
420#define TMS570_FLASH_FMSTAT_SLOCK BSP_BIT32(0)
433#define TMS570_FLASH_FEMUECC_EMU_ECC(val) BSP_FLD32(val,0, 7)
434#define TMS570_FLASH_FEMUECC_EMU_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
435#define TMS570_FLASH_FEMUECC_EMU_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
440#define TMS570_FLASH_FEMUADDR_EMU_ADDR(val) BSP_FLD32(val,3, 21)
441#define TMS570_FLASH_FEMUADDR_EMU_ADDR_GET(reg) BSP_FLD32GET(reg,3, 21)
442#define TMS570_FLASH_FEMUADDR_EMU_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,3, 21)
447#define TMS570_FLASH_FDIAGCTRL_DIAG_TRIG BSP_BIT32(24)
450#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY(val) BSP_FLD32(val,16, 19)
451#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
452#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
455#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL(val) BSP_FLD32(val,12, 14)
456#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET(reg) BSP_FLD32GET(reg,12, 14)
457#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
470#define TMS570_FLASH_FRAWECC_PIPE_BUF BSP_BIT32(8)
473#define TMS570_FLASH_FRAWECC_RAW_ECC(val) BSP_FLD32(val,0, 7)
474#define TMS570_FLASH_FRAWECC_RAW_ECC_GET(reg) BSP_FLD32GET(reg,0, 7)
475#define TMS570_FLASH_FRAWECC_RAW_ECC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
480#define TMS570_FLASH_FPAROVR_BNK_INV_PAR BSP_BIT32(16)
483#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS(val) BSP_FLD32(val,12, 15)
484#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET(reg) BSP_FLD32GET(reg,12, 15)
485#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
488#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY(val) BSP_FLD32(val,9, 11)
489#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET(reg) BSP_FLD32GET(reg,9, 11)
490#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
493#define TMS570_FLASH_FPAROVR_ADD_INV_PAR BSP_BIT32(8)
496#define TMS570_FLASH_FPAROVR_DAT_INV_PAR(val) BSP_FLD32(val,0, 7)
497#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET(reg) BSP_FLD32GET(reg,0, 7)
498#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
503#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse(val) BSP_FLD32(val,29, 31)
504#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31)
505#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,29, 31)
508#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse(val) BSP_FLD32(val,24, 27)
509#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET(reg) BSP_FLD32GET(reg,24, 27)
510#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
513#define TMS570_FLASH_FEDACSDIS2_BankID3(val) BSP_FLD32(val,21, 23)
514#define TMS570_FLASH_FEDACSDIS2_BankID3_GET(reg) BSP_FLD32GET(reg,21, 23)
515#define TMS570_FLASH_FEDACSDIS2_BankID3_SET(reg,val) BSP_FLD32SET(reg, val,21, 23)
518#define TMS570_FLASH_FEDACSDIS2_SectorID3(val) BSP_FLD32(val,16, 19)
519#define TMS570_FLASH_FEDACSDIS2_SectorID3_GET(reg) BSP_FLD32GET(reg,16, 19)
520#define TMS570_FLASH_FEDACSDIS2_SectorID3_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
523#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse(val) BSP_FLD32(val,13, 15)
524#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15)
525#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET(reg,val) BSP_FLD32SET(reg, val,13, 15)
528#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse(val) BSP_FLD32(val,8, 11)
529#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET(reg) BSP_FLD32GET(reg,8, 11)
530#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
533#define TMS570_FLASH_FEDACSDIS2_BankID2(val) BSP_FLD32(val,5, 7)
534#define TMS570_FLASH_FEDACSDIS2_BankID2_GET(reg) BSP_FLD32GET(reg,5, 7)
535#define TMS570_FLASH_FEDACSDIS2_BankID2_SET(reg,val) BSP_FLD32SET(reg, val,5, 7)
538#define TMS570_FLASH_FEDACSDIS2_SectorID2(val) BSP_FLD32(val,0, 3)
539#define TMS570_FLASH_FEDACSDIS2_SectorID2_GET(reg) BSP_FLD32GET(reg,0, 3)
540#define TMS570_FLASH_FEDACSDIS2_SectorID2_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
545#define TMS570_FLASH_FSMWRENA_WR_ENA(val) BSP_FLD32(val,0, 2)
546#define TMS570_FLASH_FSMWRENA_WR_ENA_GET(reg) BSP_FLD32GET(reg,0, 2)
547#define TMS570_FLASH_FSMWRENA_WR_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
552#define TMS570_FLASH_FSMSECTOR_SECT_ERASED(val) BSP_FLD32(val,16, 31)
553#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET(reg) BSP_FLD32GET(reg,16, 31)
554#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
559#define TMS570_FLASH_EEPROMCONFIG_EWAIT(val) BSP_FLD32(val,16, 19)
560#define TMS570_FLASH_EEPROMCONFIG_EWAIT_GET(reg) BSP_FLD32GET(reg,16, 19)
561#define TMS570_FLASH_EEPROMCONFIG_EWAIT_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
564#define TMS570_FLASH_EEPROMCONFIG_AUTOSUSP_EN BSP_BIT32(8)
567#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE(val) BSP_FLD32(val,0, 7)
568#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET(reg) BSP_FLD32GET(reg,0, 7)
569#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
574#define TMS570_FLASH_EECTRL1_EDACMODE(val) BSP_FLD32(val,16, 19)
575#define TMS570_FLASH_EECTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19)
576#define TMS570_FLASH_EECTRL1_EDACMODE_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
579#define TMS570_FLASH_EECTRL1_EE_EOFEN BSP_BIT32(10)
582#define TMS570_FLASH_EECTRL1_EE_EZFEN BSP_BIT32(9)
585#define TMS570_FLASH_EECTRL1_EE_EPEN BSP_BIT32(8)
590#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15)
591#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15)
592#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
597#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT(val) BSP_FLD32(val,0, 15)
598#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15)
599#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
604#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31)
605#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
606#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
609#define TMS570_FLASH_EECORERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
610#define TMS570_FLASH_EECORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
611#define TMS570_FLASH_EECORERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
616#define TMS570_FLASH_EECORERRPOS_TYPE BSP_BIT32(8)
619#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS(val) BSP_FLD32(val,0, 7)
620#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7)
621#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
626#define TMS570_FLASH_EESTATUS_EE_D_UNC_ERR BSP_BIT32(12)
629#define TMS570_FLASH_EESTATUS_EE_UNC_ERR BSP_BIT32(8)
632#define TMS570_FLASH_EESTATUS_EE_CMG BSP_BIT32(6)
635#define TMS570_FLASH_EESTATUS_EE_CME BSP_BIT32(4)
638#define TMS570_FLASH_EESTATUS_EE_D_COR_ERR BSP_BIT32(3)
641#define TMS570_FLASH_EESTATUS_EE_ERR_ONE_FLG BSP_BIT32(2)
644#define TMS570_FLASH_EESTATUS_EE_ERR_ZERO_FLG BSP_BIT32(1)
647#define TMS570_FLASH_EESTATUS_EE_ERR_PRF_FLG BSP_BIT32(0)
652#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31)
653#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31)
654#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET(reg,val) BSP_FLD32SET(reg, val,3, 31)
657#define TMS570_FLASH_EEUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2)
658#define TMS570_FLASH_EEUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2)
659#define TMS570_FLASH_EEUNCERRADD_B_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
664#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH(val) BSP_FLD32(val,20, 31)
665#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,20, 31)
666#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,20, 31)
669#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH(val) BSP_FLD32(val,4, 15)
670#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,4, 15)
671#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,4, 15)
This header file provides utility macros for BSPs.
Definition: reg_flash.h:44
