RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_esm.h
1
/* The header file is generated by make_header.py from ESM.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_ESM
40
#define LIBBSP_ARM_TMS570_ESM
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t EEPAPR1;
/*ESM Enable ERROR Pin Action/Response Register 1*/
46
uint32_t DEPAPR1;
/*ESM Disable ERROR Pin Action/Response Register 1*/
47
uint32_t IESR1;
/*ESM Interrupt Enable Set/Status Register 1*/
48
uint32_t IECR1;
/*ESM Interrupt Enable Clear/Status Register 1*/
49
uint32_t ILSR1;
/*Interrupt Level Set/Status Register 1*/
50
uint32_t ILCR1;
/*Interrupt Level Clear/Status Register 1*/
51
uint32_t SR[3];
/*ESM Status Register*/
52
uint32_t EPSR;
/*ESM ERROR Pin Status Register*/
53
uint32_t IOFFHR;
/*ESM Interrupt Offset High Register*/
54
uint32_t IOFFLR;
/*ESM Interrupt Offset Low Register*/
55
uint32_t LTCR;
/*ESM Low-Time Counter Register*/
56
uint32_t LTCPR;
/*ESM Low-Time Counter Preload Register*/
57
uint32_t EKR;
/*ESM Error Key Register*/
58
uint32_t SSR2;
/*ESM Status Shadow Register 2*/
59
uint32_t IEPSR4;
/*ESM Influence ERROR Pin Set/Status Register 4*/
60
uint32_t IEPCR4;
/*ESM Influence ERROR Pin Clear/Status Register 4*/
61
uint32_t IESR4;
/*ESM Interrupt Enable Set/Status Register 4*/
62
uint32_t IECR4;
/*ESM Interrupt Enable Clear/Status Register 4*/
63
uint32_t ILSR4;
/*Interrupt Level Set/Status Register 4*/
64
uint32_t ILCR4;
/*Interrupt Level Clear/Status Register 4*/
65
uint32_t SR4;
/*ESM Status Register 4*/
66
tms570_esm_t
67
68
69
/*---------------------TMS570_ESM_EEPAPR1---------------------*/
70
/* field: IEPSET - Enable ERROR Pin Action/Response on Group 1. */
71
/* Whole 32 bits */
72
73
/*---------------------TMS570_ESM_DEPAPR1---------------------*/
74
/* field: IEPCLR - Disable ERROR Pin Action/Response on Group 1. */
75
/* Whole 32 bits */
76
77
/*----------------------TMS570_ESM_IESR1----------------------*/
78
/* field: INTENSET - Set interrupt Enable */
79
/* Whole 32 bits */
80
81
/*----------------------TMS570_ESM_IECR1----------------------*/
82
/* field: INTENCLR - Clear Interrupt Enable */
83
/* Whole 32 bits */
84
85
/*----------------------TMS570_ESM_ILSR1----------------------*/
86
/* field: INTLVLSET - Set Interrupt Priority */
87
/* Whole 32 bits */
88
89
/*----------------------TMS570_ESM_ILCR1----------------------*/
90
/* field: INTLVLCLR - Clear Interrupt Priority. */
91
/* Whole 32 bits */
92
93
/*-----------------------TMS570_ESM_SR-----------------------*/
94
/* field: ESF - Error Status Flag. Provides status information on a pending error. */
95
/* Whole 32 bits */
96
97
/*----------------------TMS570_ESM_EPSR----------------------*/
98
/* field: EPSF - ERROR Pin Status Flag. Provides status information for the ERROR Pin. */
99
#define TMS570_ESM_EPSR_EPSF BSP_BIT32(0)
100
101
102
/*---------------------TMS570_ESM_IOFFHR---------------------*/
103
/* field: INTOFFH - Offset High Level Interrupt. */
104
#define TMS570_ESM_IOFFHR_INTOFFH(val) BSP_FLD32(val,0, 6)
105
#define TMS570_ESM_IOFFHR_INTOFFH_GET(reg) BSP_FLD32GET(reg,0, 6)
106
#define TMS570_ESM_IOFFHR_INTOFFH_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
107
108
109
/*---------------------TMS570_ESM_IOFFLR---------------------*/
110
/* field: INTOFFL - Offset Low Level Interrupt. */
111
#define TMS570_ESM_IOFFLR_INTOFFL(val) BSP_FLD32(val,0, 6)
112
#define TMS570_ESM_IOFFLR_INTOFFL_GET(reg) BSP_FLD32GET(reg,0, 6)
113
#define TMS570_ESM_IOFFLR_INTOFFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
114
115
116
/*----------------------TMS570_ESM_LTCR----------------------*/
117
/* field: LTC - ERROR Pin Low-Time Counter */
118
#define TMS570_ESM_LTCR_LTC(val) BSP_FLD32(val,0, 15)
119
#define TMS570_ESM_LTCR_LTC_GET(reg) BSP_FLD32GET(reg,0, 15)
120
#define TMS570_ESM_LTCR_LTC_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
121
122
123
/*----------------------TMS570_ESM_LTCPR----------------------*/
124
/* field: LTCP - ERROR Pin Low-Time Counter Pre-load Value */
125
#define TMS570_ESM_LTCPR_LTCP(val) BSP_FLD32(val,0, 15)
126
#define TMS570_ESM_LTCPR_LTCP_GET(reg) BSP_FLD32GET(reg,0, 15)
127
#define TMS570_ESM_LTCPR_LTCP_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
128
129
130
/*-----------------------TMS570_ESM_EKR-----------------------*/
131
/* field: EKEY - Error Key. The key to reset the ERROR pin or to force an error on the ERROR pin. */
132
#define TMS570_ESM_EKR_EKEY(val) BSP_FLD32(val,0, 3)
133
#define TMS570_ESM_EKR_EKEY_GET(reg) BSP_FLD32GET(reg,0, 3)
134
#define TMS570_ESM_EKR_EKEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
135
136
137
/*----------------------TMS570_ESM_SSR2----------------------*/
138
/* field: ESF - Error Status Flag. Shadow register for status information on pending error. */
139
/* Whole 32 bits */
140
141
/*---------------------TMS570_ESM_IEPSR4---------------------*/
142
/* field: IEPSET - Set Influence on ERROR Pin */
143
/* Whole 32 bits */
144
145
/*---------------------TMS570_ESM_IEPCR4---------------------*/
146
/* field: IEPCLR - Clear Influence on ERROR Pin */
147
/* Whole 32 bits */
148
149
/*----------------------TMS570_ESM_IESR4----------------------*/
150
/* field: INTENSET - Set Interrupt Enable */
151
/* Whole 32 bits */
152
153
/*----------------------TMS570_ESM_IECR4----------------------*/
154
155
/* Whole 32 bits */
156
157
/*----------------------TMS570_ESM_ILSR4----------------------*/
158
/* field: INTLVLSET - Set Interrupt Level */
159
/* Whole 32 bits */
160
161
/*----------------------TMS570_ESM_ILCR4----------------------*/
162
/* field: INTLVLCLR - Clear Interrupt Level */
163
/* Whole 32 bits */
164
165
/*-----------------------TMS570_ESM_SR4-----------------------*/
166
167
/* Whole 32 bits */
168
169
170
#endif
/* LIBBSP_ARM_TMS570_ESM */
utility.h
This header file provides utility macros for BSPs.
tms570_esm_t
Definition:
reg_esm.h:44
