RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_dmm.h
1
/* The header file is generated by make_header.py from DMM.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_DMM
40
#define LIBBSP_ARM_TMS570_DMM
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t GLBCTRL;
/*DMM Global Control Register*/
46
uint32_t INTSET;
/*DMM Interrupt Set Register*/
47
uint32_t INTCLR;
/*DMM Interrupt Clear Register*/
48
uint32_t INTLVL;
/*DMM Interrupt Level Register*/
49
uint32_t INTFLG;
/*DMM Interrupt Flag Register*/
50
uint32_t OFF1;
/*DMM Interrupt Offset 1 Register*/
51
uint32_t OFF2;
/*DMM Interrupt Offset 2 Register*/
52
uint32_t DDMDEST;
/*DMM Direct Data Mode Destination Register*/
53
uint32_t DDMBL;
/*DMM Direct Data Mode Blocksize Register*/
54
uint32_t DDMPT;
/*DMM Direct Data Mode Pointer Register*/
55
uint32_t INTPT;
/*DMM Direct Data Mode Interrupt Pointer Register*/
56
uint32_t DEST0REG1;
/*DMM Destination 0 Region 1*/
57
uint32_t DEST0BL1;
/*DMM Destination 0 Blocksize 1*/
58
uint32_t DEST0REG2;
/*DMM Destination 0 Region 2*/
59
uint32_t DEST0BL2;
/*DMM Destination 0 Blocksize 2*/
60
uint32_t DEST1REG1;
/*DMM Destination 1 Region 1*/
61
uint32_t DEST1BL1;
/*DMM Destination 1 Blocksize 1*/
62
uint32_t DEST1REG2;
/*DMM Destination 1 Region 2*/
63
uint32_t DEST1BL2;
/*DMM Destination 1 Blocksize 2*/
64
uint32_t DEST2REG1;
/*DMM Destination 2 Region 1*/
65
uint32_t DEST2BL1;
/*DMM Destination 2 Blocksize 1*/
66
uint32_t DEST2REG2;
/*DMM Destination 2 Region 2*/
67
uint32_t DEST2BL2;
/*DMM Destination 2 Blocksize 2*/
68
uint32_t DEST3REG1;
/*DMM Destination 3 Region 1*/
69
uint32_t DEST3BL1;
/*DMM Destination 3 Blocksize 1*/
70
uint32_t DEST3REG2;
/*DMM Destination 3 Region 2*/
71
uint32_t DEST3BL2;
/*DMM Destination 3 Blocksize 2*/
72
uint32_t PC0;
/*DMM Pin Control 0*/
73
uint32_t PC1;
/*DMM Pin Control 1*/
74
uint32_t PC2;
/*DMM Pin Control 2*/
75
uint32_t PC3;
/*DMM Pin Control 3*/
76
uint32_t PC4;
/*DMM Pin Control 4*/
77
uint32_t PC5;
/*DMM Pin Control 5*/
78
uint32_t PC6;
/*DMM Pin Control 6*/
79
uint32_t PC7;
/*DMM Pin Control 7*/
80
uint32_t PC8;
/*DMM Pin Control 8*/
81
tms570_dmm_t
82
83
84
/*---------------------TMS570_DMM_GLBCTRL---------------------*/
85
/* field: BUSY - Busy indicator. */
86
#define TMS570_DMM_GLBCTRL_BUSY BSP_BIT32(24)
87
88
/* field: CONTCLK - Continuous DMMCLK input. */
89
#define TMS570_DMM_GLBCTRL_CONTCLK BSP_BIT32(18)
90
91
/* field: COS - Continue on suspend. Influences behavior of module while in debug mode. */
92
#define TMS570_DMM_GLBCTRL_COS BSP_BIT32(17)
93
94
/* field: RESET - Reset. */
95
#define TMS570_DMM_GLBCTRL_RESET BSP_BIT32(16)
96
97
/* field: DDM_WIDTH - Packet Width in direct data mode. */
98
#define TMS570_DMM_GLBCTRL_DDM_WIDTH(val) BSP_FLD32(val,9, 10)
99
#define TMS570_DMM_GLBCTRL_DDM_WIDTH_GET(reg) BSP_FLD32GET(reg,9, 10)
100
#define TMS570_DMM_GLBCTRL_DDM_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,9, 10)
101
102
/* field: TM_DMM - Packet Format. */
103
#define TMS570_DMM_GLBCTRL_TM_DMM BSP_BIT32(8)
104
105
/* field: ON_OFF - Switch module on or off */
106
#define TMS570_DMM_GLBCTRL_ON_OFF(val) BSP_FLD32(val,0, 3)
107
#define TMS570_DMM_GLBCTRL_ON_OFF_GET(reg) BSP_FLD32GET(reg,0, 3)
108
#define TMS570_DMM_GLBCTRL_ON_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
109
110
111
/*---------------------TMS570_DMM_INTSET---------------------*/
112
/* field: PROG_BUFF - Programmable Buffer Interrupt Set. */
113
#define TMS570_DMM_INTSET_PROG_BUFF BSP_BIT32(17)
114
115
/* field: EO_BUFF - EO_BUFF */
116
#define TMS570_DMM_INTSET_EO_BUFF BSP_BIT32(16)
117
118
/* field: DEST3REG2 - Destination 3 Region 2 Interrupt Set. */
119
#define TMS570_DMM_INTSET_DEST3REG2 BSP_BIT32(15)
120
121
/* field: DEST3REG1 - Destination 3 Region 1 Interrupt Set. */
122
#define TMS570_DMM_INTSET_DEST3REG1 BSP_BIT32(14)
123
124
/* field: DEST2REG2 - Destination 2 Region 2 Interrupt Set. */
125
#define TMS570_DMM_INTSET_DEST2REG2 BSP_BIT32(13)
126
127
/* field: DEST2REG1 - Destination 2 Region 1 Interrupt Set. */
128
#define TMS570_DMM_INTSET_DEST2REG1 BSP_BIT32(12)
129
130
/* field: DEST1REG2 - Destination 1 Region 2 Interrupt Set. */
131
#define TMS570_DMM_INTSET_DEST1REG2 BSP_BIT32(11)
132
133
/* field: DEST1REG1 - DEST1REG1 */
134
#define TMS570_DMM_INTSET_DEST1REG1 BSP_BIT32(10)
135
136
/* field: DEST0REG2 - Destination 0 Region 2 Interrupt Set. */
137
#define TMS570_DMM_INTSET_DEST0REG2 BSP_BIT32(9)
138
139
/* field: DEST0REG1 - Destination 0 Region 1 Interrupt Set. */
140
#define TMS570_DMM_INTSET_DEST0REG1 BSP_BIT32(8)
141
142
/* field: BUSERROR - Bus Error Response for errors generated when doing internal bus transfers. */
143
#define TMS570_DMM_INTSET_BUSERROR BSP_BIT32(7)
144
145
/* field: BUFF_OVF - Buffer Overflow. */
146
#define TMS570_DMM_INTSET_BUFF_OVF BSP_BIT32(6)
147
148
/* field: SRC_OVF - Source Overflow. */
149
#define TMS570_DMM_INTSET_SRC_OVF BSP_BIT32(5)
150
151
/* field: DEST3_ERR - Destination 3 Error. */
152
#define TMS570_DMM_INTSET_DEST3_ERR BSP_BIT32(4)
153
154
/* field: DEST2_ERR - Destination 2 Error Interrupt Set. */
155
#define TMS570_DMM_INTSET_DEST2_ERR BSP_BIT32(3)
156
157
/* field: DEST1_ERR - Destination 1 Error Interrupt Set. */
158
#define TMS570_DMM_INTSET_DEST1_ERR BSP_BIT32(2)
159
160
/* field: DEST0_ERR - Destination 0 Error Interrupt Set. */
161
#define TMS570_DMM_INTSET_DEST0_ERR BSP_BIT32(1)
162
163
/* field: PACKET_ERR_INT - Packet Error. */
164
#define TMS570_DMM_INTSET_PACKET_ERR_INT BSP_BIT32(0)
165
166
167
/*---------------------TMS570_DMM_INTCLR---------------------*/
168
169
#define TMS570_DMM_INTCLR_PROG_BUFF BSP_BIT32(17)
170
171
/* field: EO_BUFF - End of Buffer Interrupt Set. */
172
#define TMS570_DMM_INTCLR_EO_BUFF BSP_BIT32(16)
173
174
/* field: DEST3REG2 - was accessed at the startaddress of Destination 3 Region 2. */
175
#define TMS570_DMM_INTCLR_DEST3REG2 BSP_BIT32(15)
176
177
178
#define TMS570_DMM_INTCLR_DEST3REG1 BSP_BIT32(14)
179
180
181
#define TMS570_DMM_INTCLR_DEST2REG2 BSP_BIT32(13)
182
183
184
#define TMS570_DMM_INTCLR_DEST2REG1 BSP_BIT32(12)
185
186
187
#define TMS570_DMM_INTCLR_DEST1REG2 BSP_BIT32(11)
188
189
/* field: DEST1REG1 - Destination 1 Region 1 Interrupt Set. */
190
#define TMS570_DMM_INTCLR_DEST1REG1 BSP_BIT32(10)
191
192
193
#define TMS570_DMM_INTCLR_DEST0REG2 BSP_BIT32(9)
194
195
196
#define TMS570_DMM_INTCLR_DEST0REG1 BSP_BIT32(8)
197
198
199
#define TMS570_DMM_INTCLR_BUSERROR BSP_BIT32(7)
200
201
202
#define TMS570_DMM_INTCLR_BUFF_OVF BSP_BIT32(6)
203
204
205
#define TMS570_DMM_INTCLR_SRC_OVF BSP_BIT32(5)
206
207
208
#define TMS570_DMM_INTCLR_DEST3_ERR BSP_BIT32(4)
209
210
211
#define TMS570_DMM_INTCLR_DEST2_ERR BSP_BIT32(3)
212
213
214
#define TMS570_DMM_INTCLR_DEST1_ERR BSP_BIT32(2)
215
216
217
#define TMS570_DMM_INTCLR_DEST0_ERR BSP_BIT32(1)
218
219
220
#define TMS570_DMM_INTCLR_PACKET_ERR_INT BSP_BIT32(0)
221
222
223
/*---------------------TMS570_DMM_INTLVL---------------------*/
224
/* field: PROG_BUFF - Programmable Buffer Interrupt Level */
225
#define TMS570_DMM_INTLVL_PROG_BUFF BSP_BIT32(17)
226
227
/* field: EO_BUFF - End of Buffer Interrupt Level */
228
#define TMS570_DMM_INTLVL_EO_BUFF BSP_BIT32(16)
229
230
/* field: DEST3REG2 - Destination 3 Region 2 Interrupt Level */
231
#define TMS570_DMM_INTLVL_DEST3REG2 BSP_BIT32(15)
232
233
/* field: DEST3REG1 - Destination 3 Region 1 Interrupt Level */
234
#define TMS570_DMM_INTLVL_DEST3REG1 BSP_BIT32(14)
235
236
/* field: DEST2REG2 - Destination 2 Region 2 Interrupt Level */
237
#define TMS570_DMM_INTLVL_DEST2REG2 BSP_BIT32(13)
238
239
/* field: DEST2REG1 - Destination 2 Region 1 Interrupt Level */
240
#define TMS570_DMM_INTLVL_DEST2REG1 BSP_BIT32(12)
241
242
/* field: DEST1REG2 - Destination 1 Region 2 Interrupt Level */
243
#define TMS570_DMM_INTLVL_DEST1REG2 BSP_BIT32(11)
244
245
/* field: DEST1REG1 - Destination 1 Region 1 Interrupt Level */
246
#define TMS570_DMM_INTLVL_DEST1REG1 BSP_BIT32(10)
247
248
/* field: DEST0REG2 - Destination 0 Region 2 Interrupt Level */
249
#define TMS570_DMM_INTLVL_DEST0REG2 BSP_BIT32(9)
250
251
/* field: DEST0REG1 - Destination 0 Region 1 Interrupt Level */
252
#define TMS570_DMM_INTLVL_DEST0REG1 BSP_BIT32(8)
253
254
/* field: BUSERROR - BMM Bus Error Response */
255
#define TMS570_DMM_INTLVL_BUSERROR BSP_BIT32(7)
256
257
/* field: BUFF_OVF - Write Buffer Overflow Interrupt Level */
258
#define TMS570_DMM_INTLVL_BUFF_OVF BSP_BIT32(6)
259
260
/* field: SRC_OVF - Source Overflow Interrupt Level */
261
#define TMS570_DMM_INTLVL_SRC_OVF BSP_BIT32(5)
262
263
/* field: DEST3_ERR - Destination 3 Error Interrupt Level */
264
#define TMS570_DMM_INTLVL_DEST3_ERR BSP_BIT32(4)
265
266
/* field: DEST2_ERR - Destination 2 Error Interrupt Level */
267
#define TMS570_DMM_INTLVL_DEST2_ERR BSP_BIT32(3)
268
269
/* field: DEST1_ERR - Destination 1 Error Interrupt Level */
270
#define TMS570_DMM_INTLVL_DEST1_ERR BSP_BIT32(2)
271
272
/* field: DEST0_ERR - Destination 0 Error Interrupt Level */
273
#define TMS570_DMM_INTLVL_DEST0_ERR BSP_BIT32(1)
274
275
/* field: PACKET_ERR_INT - Packet Error Interrupt Level */
276
#define TMS570_DMM_INTLVL_PACKET_ERR_INT BSP_BIT32(0)
277
278
279
/*---------------------TMS570_DMM_INTFLG---------------------*/
280
/* field: PROG_BUFF - Programmable Buffer Interrupt Flag */
281
#define TMS570_DMM_INTFLG_PROG_BUFF BSP_BIT32(17)
282
283
/* field: EO_BUFF - End of Buffer Interrupt Flag */
284
#define TMS570_DMM_INTFLG_EO_BUFF BSP_BIT32(16)
285
286
/* field: DEST3REG2 - Destination 3 Region 2 Interrupt Flag */
287
#define TMS570_DMM_INTFLG_DEST3REG2 BSP_BIT32(15)
288
289
/* field: DEST3REG1 - Destination 3 Region 1 Interrupt Flag */
290
#define TMS570_DMM_INTFLG_DEST3REG1 BSP_BIT32(14)
291
292
/* field: DEST2REG2 - Destination 2 Region 2 Interrupt Flag */
293
#define TMS570_DMM_INTFLG_DEST2REG2 BSP_BIT32(13)
294
295
/* field: DEST2REG1 - Destination 2 Region 1 Interrupt Flag */
296
#define TMS570_DMM_INTFLG_DEST2REG1 BSP_BIT32(12)
297
298
/* field: DEST1REG2 - Destination 1 Region 2 Interrupt Flag */
299
#define TMS570_DMM_INTFLG_DEST1REG2 BSP_BIT32(11)
300
301
/* field: DEST1REG1 - Destination 1 Region 1 Interrupt Flag */
302
#define TMS570_DMM_INTFLG_DEST1REG1 BSP_BIT32(10)
303
304
/* field: DEST0REG2 - Destination 0 Region 2 Interrupt Flag */
305
#define TMS570_DMM_INTFLG_DEST0REG2 BSP_BIT32(9)
306
307
/* field: DEST0REG1 - Destination 0 Region 1 Interrupt Flag */
308
#define TMS570_DMM_INTFLG_DEST0REG1 BSP_BIT32(8)
309
310
/* field: BUSERROR - BMM Bus Error Response. */
311
#define TMS570_DMM_INTFLG_BUSERROR BSP_BIT32(7)
312
313
/* field: BUFF_OVF - Write Buffer Overflow Interrupt Flag */
314
#define TMS570_DMM_INTFLG_BUFF_OVF BSP_BIT32(6)
315
316
/* field: SRC_OVF - Source Overflow Interrupt Flag */
317
#define TMS570_DMM_INTFLG_SRC_OVF BSP_BIT32(5)
318
319
/* field: DEST3_ERR - Destination 3 Error Interrupt Flag */
320
#define TMS570_DMM_INTFLG_DEST3_ERR BSP_BIT32(4)
321
322
/* field: DEST2_ERR - Destination 2 Error Interrupt Flag */
323
#define TMS570_DMM_INTFLG_DEST2_ERR BSP_BIT32(3)
324
325
/* field: DEST1_ERR - Destination 1 Error Interrupt Flag */
326
#define TMS570_DMM_INTFLG_DEST1_ERR BSP_BIT32(2)
327
328
/* field: DEST0_ERR - Destination 0 Error Interrupt Flag */
329
#define TMS570_DMM_INTFLG_DEST0_ERR BSP_BIT32(1)
330
331
/* field: PACKET_ERR_INT - Packet Error Interrupt Flag */
332
#define TMS570_DMM_INTFLG_PACKET_ERR_INT BSP_BIT32(0)
333
334
335
/*----------------------TMS570_DMM_OFF1----------------------*/
336
/* field: OFFSET - User and privilege mode (read): */
337
#define TMS570_DMM_OFF1_OFFSET(val) BSP_FLD32(val,0, 4)
338
#define TMS570_DMM_OFF1_OFFSET_GET(reg) BSP_FLD32GET(reg,0, 4)
339
#define TMS570_DMM_OFF1_OFFSET_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
340
341
342
/*----------------------TMS570_DMM_OFF2----------------------*/
343
344
#define TMS570_DMM_OFF2_OFFSET(val) BSP_FLD32(val,0, 4)
345
#define TMS570_DMM_OFF2_OFFSET_GET(reg) BSP_FLD32GET(reg,0, 4)
346
#define TMS570_DMM_OFF2_OFFSET_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
347
348
349
/*---------------------TMS570_DMM_DDMDEST---------------------*/
350
/* field: STARTADDR - These bits define the starting address of the buffer. */
351
/* Whole 32 bits */
352
353
/*----------------------TMS570_DMM_DDMBL----------------------*/
354
/* field: BLOCKSIZE - These bits define the size of the buffer region */
355
#define TMS570_DMM_DDMBL_BLOCKSIZE(val) BSP_FLD32(val,0, 3)
356
#define TMS570_DMM_DDMBL_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,0, 3)
357
#define TMS570_DMM_DDMBL_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
358
359
360
/*----------------------TMS570_DMM_DDMPT----------------------*/
361
/* field: POINTER - These bits hold the pointer to the next entry to be written in the buffer. */
362
#define TMS570_DMM_DDMPT_POINTER(val) BSP_FLD32(val,0, 14)
363
#define TMS570_DMM_DDMPT_POINTER_GET(reg) BSP_FLD32GET(reg,0, 14)
364
#define TMS570_DMM_DDMPT_POINTER_SET(reg,val) BSP_FLD32SET(reg, val,0, 14)
365
366
367
/*----------------------TMS570_DMM_INTPT----------------------*/
368
/* field: INTPT - Interrupt Pointer. When the buffer pointer (Section 30.3. */
369
#define TMS570_DMM_INTPT_INTPT(val) BSP_FLD32(val,0, 14)
370
#define TMS570_DMM_INTPT_INTPT_GET(reg) BSP_FLD32GET(reg,0, 14)
371
#define TMS570_DMM_INTPT_INTPT_SET(reg,val) BSP_FLD32SET(reg, val,0, 14)
372
373
374
/*--------------------TMS570_DMM_DESTxREG1--------------------*/
375
/* field: BASEADDR - These bits define the base address of the 256kB region where the buffer is located. */
376
#define TMS570_DMM_DESTxREG1_BASEADDR(val) BSP_FLD32(val,18, 31)
377
#define TMS570_DMM_DESTxREG1_BASEADDR_GET(reg) BSP_FLD32GET(reg,18, 31)
378
#define TMS570_DMM_DESTxREG1_BASEADDR_SET(reg,val) BSP_FLD32SET(reg, val,18, 31)
379
380
/* field: BLOCKADDR - These bits define the starting address of the buffer in the 256kB page. */
381
#define TMS570_DMM_DESTxREG1_BLOCKADDR(val) BSP_FLD32(val,0, 17)
382
#define TMS570_DMM_DESTxREG1_BLOCKADDR_GET(reg) BSP_FLD32GET(reg,0, 17)
383
#define TMS570_DMM_DESTxREG1_BLOCKADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 17)
384
385
386
/*--------------------TMS570_DMM_DESTxBL1--------------------*/
387
/* field: BLOCKSIZE - These bits define the length of the buffer region. */
388
#define TMS570_DMM_DESTxBL1_BLOCKSIZE(val) BSP_FLD32(val,0, 3)
389
#define TMS570_DMM_DESTxBL1_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,0, 3)
390
#define TMS570_DMM_DESTxBL1_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
391
392
393
/*--------------------TMS570_DMM_DESTxREG2--------------------*/
394
395
#define TMS570_DMM_DESTxREG2_BASEADDR(val) BSP_FLD32(val,18, 31)
396
#define TMS570_DMM_DESTxREG2_BASEADDR_GET(reg) BSP_FLD32GET(reg,18, 31)
397
#define TMS570_DMM_DESTxREG2_BASEADDR_SET(reg,val) BSP_FLD32SET(reg, val,18, 31)
398
399
400
#define TMS570_DMM_DESTxREG2_BLOCKADDR(val) BSP_FLD32(val,0, 17)
401
#define TMS570_DMM_DESTxREG2_BLOCKADDR_GET(reg) BSP_FLD32GET(reg,0, 17)
402
#define TMS570_DMM_DESTxREG2_BLOCKADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 17)
403
404
405
/*--------------------TMS570_DMM_DESTxBL2--------------------*/
406
407
#define TMS570_DMM_DESTxBL2_BLOCKSIZE(val) BSP_FLD32(val,0, 3)
408
#define TMS570_DMM_DESTxBL2_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,0, 3)
409
#define TMS570_DMM_DESTxBL2_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
410
411
412
/*-----------------------TMS570_DMM_PC0-----------------------*/
413
/* field: ENAFUNC - Functional mode of DMMENA pin. */
414
#define TMS570_DMM_PC0_ENAFUNC BSP_BIT32(18)
415
416
/* field: DATAxFUNC - Functional mode of DMMDATA[x] pin. */
417
#define TMS570_DMM_PC0_DATAxFUNC(val) BSP_FLD32(val,2, 17)
418
#define TMS570_DMM_PC0_DATAxFUNC_GET(reg) BSP_FLD32GET(reg,2, 17)
419
#define TMS570_DMM_PC0_DATAxFUNC_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
420
421
/* field: CLKFUNC - Functional mode of DMMCLK pin. */
422
#define TMS570_DMM_PC0_CLKFUNC BSP_BIT32(1)
423
424
/* field: SYNCFUNC - Functional mode of DMMSYNC pin. */
425
#define TMS570_DMM_PC0_SYNCFUNC BSP_BIT32(0)
426
427
428
/*-----------------------TMS570_DMM_PC1-----------------------*/
429
/* field: ENADIR - Direction of DMMENA pin. */
430
#define TMS570_DMM_PC1_ENADIR BSP_BIT32(18)
431
432
/* field: DATAxDIR - Direction of DMMDATA[x] pin. */
433
#define TMS570_DMM_PC1_DATAxDIR(val) BSP_FLD32(val,2, 17)
434
#define TMS570_DMM_PC1_DATAxDIR_GET(reg) BSP_FLD32GET(reg,2, 17)
435
#define TMS570_DMM_PC1_DATAxDIR_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
436
437
/* field: CLKDIR - Direction of DMMCLK pin. */
438
#define TMS570_DMM_PC1_CLKDIR BSP_BIT32(1)
439
440
/* field: SYNCDIR - Direction of DMMSYNC pin. */
441
#define TMS570_DMM_PC1_SYNCDIR BSP_BIT32(0)
442
443
444
/*-----------------------TMS570_DMM_PC2-----------------------*/
445
/* field: ENAIN - DMMENA input. This bit reflects the state of the pin in all modes. */
446
#define TMS570_DMM_PC2_ENAIN BSP_BIT32(18)
447
448
/* field: DATAxIN - DMMDATA[x] input. This bit reflects the state of the pin in all modes. */
449
#define TMS570_DMM_PC2_DATAxIN(val) BSP_FLD32(val,2, 17)
450
#define TMS570_DMM_PC2_DATAxIN_GET(reg) BSP_FLD32GET(reg,2, 17)
451
#define TMS570_DMM_PC2_DATAxIN_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
452
453
/* field: CLKIN - DMMCLK input. This bit reflects the state of the pin in all modes. */
454
#define TMS570_DMM_PC2_CLKIN BSP_BIT32(1)
455
456
/* field: SYNCIN - DMMSYNC input. */
457
#define TMS570_DMM_PC2_SYNCIN BSP_BIT32(0)
458
459
460
/*-----------------------TMS570_DMM_PC3-----------------------*/
461
/* field: ENAOUT - Output state of DMMENA pin. */
462
#define TMS570_DMM_PC3_ENAOUT BSP_BIT32(18)
463
464
/* field: DATAxOUT - Output state of DMMDATA[x] pin. This bit sets the pin to logic low or high level. */
465
#define TMS570_DMM_PC3_DATAxOUT(val) BSP_FLD32(val,2, 17)
466
#define TMS570_DMM_PC3_DATAxOUT_GET(reg) BSP_FLD32GET(reg,2, 17)
467
#define TMS570_DMM_PC3_DATAxOUT_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
468
469
/* field: CLKOUT - Output state of DMMCLK pin. */
470
#define TMS570_DMM_PC3_CLKOUT BSP_BIT32(1)
471
472
/* field: SYNCOUT - Output state of DMMSYNC pin. This bit sets the pin to logic low or high level. */
473
#define TMS570_DMM_PC3_SYNCOUT BSP_BIT32(0)
474
475
476
/*-----------------------TMS570_DMM_PC4-----------------------*/
477
/* field: ENASET - control register bit to 1 regardless of the current value in the ENAOUT bit. */
478
#define TMS570_DMM_PC4_ENASET BSP_BIT32(18)
479
480
/* field: DATAxSET - Sets output state of DMMDATA[x] pin to logic high. */
481
#define TMS570_DMM_PC4_DATAxSET(val) BSP_FLD32(val,2, 17)
482
#define TMS570_DMM_PC4_DATAxSET_GET(reg) BSP_FLD32GET(reg,2, 17)
483
#define TMS570_DMM_PC4_DATAxSET_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
484
485
/* field: CLKSET - Sets output state of DMMCLK pin to logic high. */
486
#define TMS570_DMM_PC4_CLKSET BSP_BIT32(1)
487
488
/* field: SYNCSET - Sets output state of DMMSYNC pin logic high. */
489
#define TMS570_DMM_PC4_SYNCSET BSP_BIT32(0)
490
491
492
/*-----------------------TMS570_DMM_PC5-----------------------*/
493
/* field: ENACLR - Sets output state of DMMENA pin to logic low. */
494
#define TMS570_DMM_PC5_ENACLR BSP_BIT32(18)
495
496
/* field: DATAxCLR - Sets output state of DMMDATA[x] pin to logic low. */
497
#define TMS570_DMM_PC5_DATAxCLR(val) BSP_FLD32(val,2, 17)
498
#define TMS570_DMM_PC5_DATAxCLR_GET(reg) BSP_FLD32GET(reg,2, 17)
499
#define TMS570_DMM_PC5_DATAxCLR_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
500
501
/* field: CLKCLR - Sets output state of DMMCLK pin to logic low. */
502
#define TMS570_DMM_PC5_CLKCLR BSP_BIT32(1)
503
504
/* field: SYNCCLR - Sets output state of DMMSYNC pin to logic low. */
505
#define TMS570_DMM_PC5_SYNCCLR BSP_BIT32(0)
506
507
508
/*-----------------------TMS570_DMM_PC6-----------------------*/
509
/* field: ENAPDR - Open Drain enable. */
510
#define TMS570_DMM_PC6_ENAPDR BSP_BIT32(18)
511
512
/* field: DATAxPDR - Open Drain enable. */
513
#define TMS570_DMM_PC6_DATAxPDR(val) BSP_FLD32(val,2, 17)
514
#define TMS570_DMM_PC6_DATAxPDR_GET(reg) BSP_FLD32GET(reg,2, 17)
515
#define TMS570_DMM_PC6_DATAxPDR_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
516
517
/* field: CLKPDR - Open Drain enable. */
518
#define TMS570_DMM_PC6_CLKPDR BSP_BIT32(1)
519
520
/* field: SYNCPDR - Open Drain enable. */
521
#define TMS570_DMM_PC6_SYNCPDR BSP_BIT32(0)
522
523
524
/*-----------------------TMS570_DMM_PC7-----------------------*/
525
/* field: ENAPDIS - Pull disable. */
526
#define TMS570_DMM_PC7_ENAPDIS BSP_BIT32(18)
527
528
/* field: DATAxPDIS - Pull disable. */
529
#define TMS570_DMM_PC7_DATAxPDIS(val) BSP_FLD32(val,2, 17)
530
#define TMS570_DMM_PC7_DATAxPDIS_GET(reg) BSP_FLD32GET(reg,2, 17)
531
#define TMS570_DMM_PC7_DATAxPDIS_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
532
533
/* field: CLKPDIS - Pull disable. */
534
#define TMS570_DMM_PC7_CLKPDIS BSP_BIT32(1)
535
536
/* field: SYNCPDIS - Pull disable. */
537
#define TMS570_DMM_PC7_SYNCPDIS BSP_BIT32(0)
538
539
540
/*-----------------------TMS570_DMM_PC8-----------------------*/
541
/* field: ENAPSEL - Pull disable. */
542
#define TMS570_DMM_PC8_ENAPSEL BSP_BIT32(18)
543
544
/* field: DATAxPSEL - Pull disable. */
545
#define TMS570_DMM_PC8_DATAxPSEL(val) BSP_FLD32(val,2, 17)
546
#define TMS570_DMM_PC8_DATAxPSEL_GET(reg) BSP_FLD32GET(reg,2, 17)
547
#define TMS570_DMM_PC8_DATAxPSEL_SET(reg,val) BSP_FLD32SET(reg, val,2, 17)
548
549
/* field: CLKPSEL - Pull disable. */
550
#define TMS570_DMM_PC8_CLKPSEL BSP_BIT32(1)
551
552
/* field: SYNCPSEL - Pull disable. */
553
#define TMS570_DMM_PC8_SYNCPSEL BSP_BIT32(0)
554
555
556
557
#endif
/* LIBBSP_ARM_TMS570_DMM */
utility.h
This header file provides utility macros for BSPs.
tms570_dmm_t
Definition:
reg_dmm.h:44
