RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_dma.h
1
/* The header file is generated by make_header.py from DMA.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_DMA
40
#define LIBBSP_ARM_TMS570_DMA
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t STARTADD;
/*DMA Memory Protection Region start Address Register*/
46
uint32_t ENDADD;
/*DMA Memory Protection Region End Address Register*/
47
tms570_memory_prot_t
48
49
typedef
struct
50
uint32_t GCTRL;
/*Global Control Register*/
51
uint32_t PEND;
/*Channel Pending Register*/
52
uint8_t reserved1 [4];
53
uint32_t DMASTAT;
/*DMA Status Register*/
54
uint8_t reserved2 [4];
55
uint32_t HWCHENAS;
/*HW Channel Enable Set and Status Register*/
56
uint8_t reserved3 [4];
57
uint32_t HWCHENAR;
/*HW Channel Enable Reset and Status Register*/
58
uint8_t reserved4 [4];
59
uint32_t SWCHENAS;
/*SW Channel Enable Set and Status Register*/
60
uint8_t reserved5 [4];
61
uint32_t SWCHENAR;
/*SW Channel Enable Reset and Status Register*/
62
uint8_t reserved6 [4];
63
uint32_t CHPRIOS;
/*Channel Priority Set Register*/
64
uint8_t reserved7 [4];
65
uint32_t CHPRIOR;
/*Channel Priority Reset Register*/
66
uint8_t reserved8 [4];
67
uint32_t GCHIENAS;
/*Global Channel Interrupt Enable Set Register*/
68
uint8_t reserved9 [4];
69
uint32_t GCHIENAR;
/*Global Channel Interrupt Enable Reset Register*/
70
uint8_t reserved10 [4];
71
uint32_t DREQASI[4];
/*DMA Request Assignment Register 0*/
72
uint8_t reserved11 [48];
73
uint32_t PAR0;
/*Port Assignment Register 0*/
74
uint32_t PAR1;
/*Port Assignment Register 1*/
75
uint8_t reserved12 [24];
76
uint32_t FTCMAP;
/*FTC Interrupt Mapping Register*/
77
uint8_t reserved13 [4];
78
uint32_t LFSMAP;
/*LFS Interrupt Mapping Register*/
79
uint8_t reserved14 [4];
80
uint32_t HBCMAP;
/*HBC Interrupt Mapping Register*/
81
uint8_t reserved15 [4];
82
uint32_t BTCMAP;
/*BTC Interrupt Mapping Register*/
83
uint8_t reserved16 [4];
84
uint32_t BERMAP;
/*BER Interrupt Mapping Register*/
85
uint8_t reserved17 [4];
86
uint32_t FTCINTENAS;
/*FTC Interrupt Enable Set*/
87
uint8_t reserved18 [4];
88
uint32_t FTCINTENAR;
/*FTC Interrupt Enable Reset*/
89
uint8_t reserved19 [4];
90
uint32_t LFSINTENAS;
/*LFS Interrupt Enable Set*/
91
uint8_t reserved20 [4];
92
uint32_t LFSINTENAR;
/*LFS Interrupt Enable Reset*/
93
uint8_t reserved21 [4];
94
uint32_t HBCINTENAS;
/*HBC Interrupt Enable Set*/
95
uint8_t reserved22 [4];
96
uint32_t HBCINTENAR;
/*HBC Interrupt Enable Reset*/
97
uint8_t reserved23 [4];
98
uint32_t BTCINTENAS;
/*BTC Interrupt Enable Set*/
99
uint8_t reserved24 [4];
100
uint32_t BTCINTENAR;
/*BTC Interrupt Enable Reset*/
101
uint8_t reserved25 [4];
102
uint32_t GINTFLAG;
/*Global Interrupt Flag Register*/
103
uint8_t reserved26 [4];
104
uint32_t FTCFLAG;
/*FTC Interrupt Flag Register*/
105
uint8_t reserved27 [4];
106
uint32_t LFSFLAG;
/*LFS Interrupt Flag Register*/
107
uint8_t reserved28 [4];
108
uint32_t HBCFLAG;
/*HBC Interrupt Flag Register*/
109
uint8_t reserved29 [4];
110
uint32_t BTCFLAG;
/*BTC Interrupt Flag Register*/
111
uint8_t reserved30 [4];
112
uint32_t BERFLAG;
/*BER Interrupt Flag Register*/
113
uint8_t reserved31 [4];
114
uint32_t FTCAOFFSET;
/*FTCA Interrupt Channel Offset Register*/
115
uint32_t LFSAOFFSET;
/*LFSA Interrupt Channel Offset Register*/
116
uint32_t HBCAOFFSET;
/*HBCA Interrupt Channel Offset Register*/
117
uint32_t BTCAOFFSET;
/*BTCA Interrupt Channel Offset Register*/
118
uint32_t BERAOFFSET;
/*BERA Interrupt Channel Offset Register*/
119
uint32_t FTCBOFFSET;
/*FTCB Interrupt Channel Offset Register*/
120
uint32_t LFSBOFFSET;
/*LFSB Interrupt Channel Offset Register*/
121
uint32_t HBCBOFFSET;
/*HBCB Interrupt Channel Offset Register*/
122
uint32_t BTCBOFFSET;
/*BTCB Interrupt Channel Offset Register*/
123
uint32_t BERBOFFSET;
/*BERB Interrupt Channel Offset Register*/
124
uint8_t reserved32 [4];
125
uint32_t PTCRL;
/*Port Control Register*/
126
uint32_t RTCTRL;
/*RAM Test Control Register*/
127
uint32_t DCTRL;
/*Debug Control*/
128
uint32_t WPR;
/*Watch Point Register*/
129
uint32_t WMR;
/*Watch Mask Register*/
130
uint8_t reserved33 [12];
131
uint32_t PBACSADDR;
/*Port B Active Channel Source Address Register*/
132
uint32_t PBACDADDR;
/*Port B Active Channel Destination Address Register*/
133
uint32_t PBACTC;
/*Port B Active Channel Transfer Count Register*/
134
uint8_t reserved34 [4];
135
uint32_t DMAPCR;
/*Parity Control Register*/
136
uint32_t DMAPAR;
/*DMA Parity Error Address Register*/
137
uint32_t DMAMPCTRL;
/*DMA Memory Protection Control Register*/
138
uint32_t DMAMPST;
/*DMA Memory Protection Status Register*/
139
DMAMPROS[4];
/*DMA Memory Protection Regions*/
140
tms570_dma_t
141
142
143
/*--------------------TMS570_DMA_STARTADD--------------------*/
144
/* field: STARTADDRESS - Start Address defines the address at which the region begins. */
145
/* Whole 32 bits */
146
147
/*---------------------TMS570_DMA_ENDADD---------------------*/
148
/* field: ENDADDRESS - End Address defines the address at which the region ends. */
149
/* Whole 32 bits */
150
151
/*----------------------TMS570_DMA_GCTRL----------------------*/
152
/* field: DMA_EN - DMA enable bit. */
153
#define TMS570_DMA_GCTRL_DMA_EN BSP_BIT32(16)
154
155
/* field: BUS_BUSY - This bit indicates status of DMA external AHB bus status. */
156
#define TMS570_DMA_GCTRL_BUS_BUSY BSP_BIT32(14)
157
158
/* field: DEBUG_MODE - Debug Mode. */
159
#define TMS570_DMA_GCTRL_DEBUG_MODE(val) BSP_FLD32(val,8, 9)
160
#define TMS570_DMA_GCTRL_DEBUG_MODE_GET(reg) BSP_FLD32GET(reg,8, 9)
161
#define TMS570_DMA_GCTRL_DEBUG_MODE_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
162
163
/* field: DMA_RES - DMA software reset */
164
#define TMS570_DMA_GCTRL_DMA_RES BSP_BIT32(0)
165
166
167
/*----------------------TMS570_DMA_PEND----------------------*/
168
/* field: PEND - Channel pending register. */
169
#define TMS570_DMA_PEND_PEND(val) BSP_FLD32(val,0, 15)
170
#define TMS570_DMA_PEND_PEND_GET(reg) BSP_FLD32GET(reg,0, 15)
171
#define TMS570_DMA_PEND_PEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
172
173
174
/*---------------------TMS570_DMA_DMASTAT---------------------*/
175
/* field: STCH - Status of DMA channels. */
176
#define TMS570_DMA_DMASTAT_STCH(val) BSP_FLD32(val,0, 15)
177
#define TMS570_DMA_DMASTAT_STCH_GET(reg) BSP_FLD32GET(reg,0, 15)
178
#define TMS570_DMA_DMASTAT_STCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
179
180
181
/*--------------------TMS570_DMA_HWCHENAS--------------------*/
182
/* field: HWCHENA - Hardware channel enable bit. */
183
#define TMS570_DMA_HWCHENAS_HWCHENA(val) BSP_FLD32(val,0, 15)
184
#define TMS570_DMA_HWCHENAS_HWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15)
185
#define TMS570_DMA_HWCHENAS_HWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
186
187
188
/*--------------------TMS570_DMA_HWCHENAR--------------------*/
189
/* field: HWCHDIS - HW channel disable bit. */
190
#define TMS570_DMA_HWCHENAR_HWCHDIS(val) BSP_FLD32(val,0, 15)
191
#define TMS570_DMA_HWCHENAR_HWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
192
#define TMS570_DMA_HWCHENAR_HWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
193
194
195
/*--------------------TMS570_DMA_SWCHENAS--------------------*/
196
/* field: SWCHENA - SW channel enable bit. */
197
#define TMS570_DMA_SWCHENAS_SWCHENA(val) BSP_FLD32(val,0, 15)
198
#define TMS570_DMA_SWCHENAS_SWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15)
199
#define TMS570_DMA_SWCHENAS_SWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
200
201
202
/*--------------------TMS570_DMA_SWCHENAR--------------------*/
203
/* field: SWCHDIS - SW channel disable bit. */
204
#define TMS570_DMA_SWCHENAR_SWCHDIS(val) BSP_FLD32(val,0, 15)
205
#define TMS570_DMA_SWCHENAR_SWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
206
#define TMS570_DMA_SWCHENAR_SWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
207
208
209
/*---------------------TMS570_DMA_CHPRIOS---------------------*/
210
/* field: CPS - Channel priority set bit. */
211
#define TMS570_DMA_CHPRIOS_CPS(val) BSP_FLD32(val,0, 15)
212
#define TMS570_DMA_CHPRIOS_CPS_GET(reg) BSP_FLD32GET(reg,0, 15)
213
#define TMS570_DMA_CHPRIOS_CPS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
214
215
216
/*---------------------TMS570_DMA_CHPRIOR---------------------*/
217
/* field: CPR - Channel priority reset bit. */
218
#define TMS570_DMA_CHPRIOR_CPR(val) BSP_FLD32(val,0, 15)
219
#define TMS570_DMA_CHPRIOR_CPR_GET(reg) BSP_FLD32GET(reg,0, 15)
220
#define TMS570_DMA_CHPRIOR_CPR_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
221
222
223
/*--------------------TMS570_DMA_GCHIENAS--------------------*/
224
/* field: GCHIE - Global channel interrupt enable bit. */
225
#define TMS570_DMA_GCHIENAS_GCHIE(val) BSP_FLD32(val,0, 15)
226
#define TMS570_DMA_GCHIENAS_GCHIE_GET(reg) BSP_FLD32GET(reg,0, 15)
227
#define TMS570_DMA_GCHIENAS_GCHIE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
228
229
230
/*--------------------TMS570_DMA_GCHIENAR--------------------*/
231
/* field: GCHID - Global channel interrupt disable bit. */
232
#define TMS570_DMA_GCHIENAR_GCHID(val) BSP_FLD32(val,0, 15)
233
#define TMS570_DMA_GCHIENAR_GCHID_GET(reg) BSP_FLD32GET(reg,0, 15)
234
#define TMS570_DMA_GCHIENAR_GCHID_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
235
236
237
/*---------------------TMS570_DMA_DREQASI---------------------*/
238
/* field: CH0ASI - Channel 0 assignment. This bit field chooses the DMA request assignment for channel 0. */
239
#define TMS570_DMA_DREQASI_CH0ASI(val) BSP_FLD32(val,24, 29)
240
#define TMS570_DMA_DREQASI_CH0ASI_GET(reg) BSP_FLD32GET(reg,24, 29)
241
#define TMS570_DMA_DREQASI_CH0ASI_SET(reg,val) BSP_FLD32SET(reg, val,24, 29)
242
243
/* field: CH1ASI - Channel 1 assignment. This bit field chooses the DMA request assignment for channel 1. */
244
#define TMS570_DMA_DREQASI_CH1ASI(val) BSP_FLD32(val,16, 21)
245
#define TMS570_DMA_DREQASI_CH1ASI_GET(reg) BSP_FLD32GET(reg,16, 21)
246
#define TMS570_DMA_DREQASI_CH1ASI_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
247
248
/* field: CH2ASI - Channel 2 assignment. This bit field chooses the DMA request assignment for channel 2. */
249
#define TMS570_DMA_DREQASI_CH2ASI(val) BSP_FLD32(val,8, 13)
250
#define TMS570_DMA_DREQASI_CH2ASI_GET(reg) BSP_FLD32GET(reg,8, 13)
251
#define TMS570_DMA_DREQASI_CH2ASI_SET(reg,val) BSP_FLD32SET(reg, val,8, 13)
252
253
/* field: CH3ASI - Channel 3 assignment. This bit field chooses the DMA request assignment for channel 3. */
254
#define TMS570_DMA_DREQASI_CH3ASI(val) BSP_FLD32(val,0, 5)
255
#define TMS570_DMA_DREQASI_CH3ASI_GET(reg) BSP_FLD32GET(reg,0, 5)
256
#define TMS570_DMA_DREQASI_CH3ASI_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
257
258
259
/*----------------------TMS570_DMA_PAR0----------------------*/
260
/* field: CH0PA - These bit fields determine to which port channel 0 is assigned. */
261
#define TMS570_DMA_PAR0_CH0PA(val) BSP_FLD32(val,28, 30)
262
#define TMS570_DMA_PAR0_CH0PA_GET(reg) BSP_FLD32GET(reg,28, 30)
263
#define TMS570_DMA_PAR0_CH0PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30)
264
265
/* field: CH1PA - These bit fields determine to which port channel 1 is assigned. */
266
#define TMS570_DMA_PAR0_CH1PA(val) BSP_FLD32(val,24, 26)
267
#define TMS570_DMA_PAR0_CH1PA_GET(reg) BSP_FLD32GET(reg,24, 26)
268
#define TMS570_DMA_PAR0_CH1PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
269
270
/* field: CH2PA - These bit fields determine to which port channel 2 is assigned. */
271
#define TMS570_DMA_PAR0_CH2PA(val) BSP_FLD32(val,20, 22)
272
#define TMS570_DMA_PAR0_CH2PA_GET(reg) BSP_FLD32GET(reg,20, 22)
273
#define TMS570_DMA_PAR0_CH2PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
274
275
/* field: CH3PA - These bit fields determine to which port channel 3 is assigned. */
276
#define TMS570_DMA_PAR0_CH3PA(val) BSP_FLD32(val,16, 18)
277
#define TMS570_DMA_PAR0_CH3PA_GET(reg) BSP_FLD32GET(reg,16, 18)
278
#define TMS570_DMA_PAR0_CH3PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
279
280
/* field: CH4PA - These bit fields determine to which port channel 4 is assigned. */
281
#define TMS570_DMA_PAR0_CH4PA(val) BSP_FLD32(val,12, 14)
282
#define TMS570_DMA_PAR0_CH4PA_GET(reg) BSP_FLD32GET(reg,12, 14)
283
#define TMS570_DMA_PAR0_CH4PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
284
285
/* field: CH5PA - These bit fields determine to which port channel 5 is assigned. */
286
#define TMS570_DMA_PAR0_CH5PA(val) BSP_FLD32(val,8, 10)
287
#define TMS570_DMA_PAR0_CH5PA_GET(reg) BSP_FLD32GET(reg,8, 10)
288
#define TMS570_DMA_PAR0_CH5PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
289
290
/* field: CH6PA - These bit fields determine to which port channel 6 is assigned. */
291
#define TMS570_DMA_PAR0_CH6PA(val) BSP_FLD32(val,4, 6)
292
#define TMS570_DMA_PAR0_CH6PA_GET(reg) BSP_FLD32GET(reg,4, 6)
293
#define TMS570_DMA_PAR0_CH6PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
294
295
/* field: CH7PA - These bit fields determine to which port channel 7 is assigned. */
296
#define TMS570_DMA_PAR0_CH7PA(val) BSP_FLD32(val,0, 2)
297
#define TMS570_DMA_PAR0_CH7PA_GET(reg) BSP_FLD32GET(reg,0, 2)
298
#define TMS570_DMA_PAR0_CH7PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
299
300
301
/*----------------------TMS570_DMA_PAR1----------------------*/
302
/* field: CH8PA - These bit fields determine to which port channel 8 is assigned. */
303
#define TMS570_DMA_PAR1_CH8PA(val) BSP_FLD32(val,28, 30)
304
#define TMS570_DMA_PAR1_CH8PA_GET(reg) BSP_FLD32GET(reg,28, 30)
305
#define TMS570_DMA_PAR1_CH8PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30)
306
307
/* field: CH9PA - These bit fields determine to which port channel 9 is assigned. */
308
#define TMS570_DMA_PAR1_CH9PA(val) BSP_FLD32(val,24, 26)
309
#define TMS570_DMA_PAR1_CH9PA_GET(reg) BSP_FLD32GET(reg,24, 26)
310
#define TMS570_DMA_PAR1_CH9PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
311
312
/* field: CH10PA - These bit fields determine to which port channel 10 is assigned. */
313
#define TMS570_DMA_PAR1_CH10PA(val) BSP_FLD32(val,20, 22)
314
#define TMS570_DMA_PAR1_CH10PA_GET(reg) BSP_FLD32GET(reg,20, 22)
315
#define TMS570_DMA_PAR1_CH10PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
316
317
/* field: CH11PA - These bit fields determine to which port channel 11 is assigned. */
318
#define TMS570_DMA_PAR1_CH11PA(val) BSP_FLD32(val,16, 18)
319
#define TMS570_DMA_PAR1_CH11PA_GET(reg) BSP_FLD32GET(reg,16, 18)
320
#define TMS570_DMA_PAR1_CH11PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
321
322
/* field: CH12PA - These bit fields determine to which port channel 12 is assigned. */
323
#define TMS570_DMA_PAR1_CH12PA(val) BSP_FLD32(val,12, 14)
324
#define TMS570_DMA_PAR1_CH12PA_GET(reg) BSP_FLD32GET(reg,12, 14)
325
#define TMS570_DMA_PAR1_CH12PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
326
327
/* field: CH13PA - These bit fields determine to which port channel 13 is assigned. */
328
#define TMS570_DMA_PAR1_CH13PA(val) BSP_FLD32(val,8, 10)
329
#define TMS570_DMA_PAR1_CH13PA_GET(reg) BSP_FLD32GET(reg,8, 10)
330
#define TMS570_DMA_PAR1_CH13PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
331
332
/* field: CH14PA - These bit fields determine to which port channel 14 is assigned. */
333
#define TMS570_DMA_PAR1_CH14PA(val) BSP_FLD32(val,4, 6)
334
#define TMS570_DMA_PAR1_CH14PA_GET(reg) BSP_FLD32GET(reg,4, 6)
335
#define TMS570_DMA_PAR1_CH14PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
336
337
/* field: CH15PA - These bit fields determine to which port channel 15 is assigned. */
338
#define TMS570_DMA_PAR1_CH15PA(val) BSP_FLD32(val,0, 2)
339
#define TMS570_DMA_PAR1_CH15PA_GET(reg) BSP_FLD32GET(reg,0, 2)
340
#define TMS570_DMA_PAR1_CH15PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
341
342
343
/*---------------------TMS570_DMA_FTCMAP---------------------*/
344
/* field: FTCAB - Frame transfer complete (FTC) interrupt to Group A or Group B. */
345
#define TMS570_DMA_FTCMAP_FTCAB(val) BSP_FLD32(val,0, 15)
346
#define TMS570_DMA_FTCMAP_FTCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
347
#define TMS570_DMA_FTCMAP_FTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
348
349
350
/*---------------------TMS570_DMA_LFSMAP---------------------*/
351
/* field: LFSAB - Last frame started (LFS) interrupt to Group A or Group B. */
352
#define TMS570_DMA_LFSMAP_LFSAB(val) BSP_FLD32(val,0, 15)
353
#define TMS570_DMA_LFSMAP_LFSAB_GET(reg) BSP_FLD32GET(reg,0, 15)
354
#define TMS570_DMA_LFSMAP_LFSAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
355
356
357
/*---------------------TMS570_DMA_HBCMAP---------------------*/
358
/* field: HBCAB - Half block complete (HBC) interrupt to Group A or Group B. */
359
#define TMS570_DMA_HBCMAP_HBCAB(val) BSP_FLD32(val,0, 15)
360
#define TMS570_DMA_HBCMAP_HBCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
361
#define TMS570_DMA_HBCMAP_HBCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
362
363
364
/*---------------------TMS570_DMA_BTCMAP---------------------*/
365
/* field: BTCAB - Block transfer complete (BTC) interrupt to Group A or Group B */
366
#define TMS570_DMA_BTCMAP_BTCAB(val) BSP_FLD32(val,0, 15)
367
#define TMS570_DMA_BTCMAP_BTCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
368
#define TMS570_DMA_BTCMAP_BTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
369
370
371
/*---------------------TMS570_DMA_BERMAP---------------------*/
372
/* field: BERAB - Bus error (BER) interrupt to Group A or Group B. */
373
#define TMS570_DMA_BERMAP_BERAB(val) BSP_FLD32(val,0, 15)
374
#define TMS570_DMA_BERMAP_BERAB_GET(reg) BSP_FLD32GET(reg,0, 15)
375
#define TMS570_DMA_BERMAP_BERAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
376
377
378
/*-------------------TMS570_DMA_FTCINTENAS-------------------*/
379
/* field: FTCINTENA - Frame transfer complete (FTC) interrupt enable. */
380
#define TMS570_DMA_FTCINTENAS_FTCINTENA(val) BSP_FLD32(val,0, 15)
381
#define TMS570_DMA_FTCINTENAS_FTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
382
#define TMS570_DMA_FTCINTENAS_FTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
383
384
385
/*-------------------TMS570_DMA_FTCINTENAR-------------------*/
386
/* field: FTCINTDIS - Frame transfer complete (FTC) interrupt disable. */
387
#define TMS570_DMA_FTCINTENAR_FTCINTDIS(val) BSP_FLD32(val,0, 15)
388
#define TMS570_DMA_FTCINTENAR_FTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
389
#define TMS570_DMA_FTCINTENAR_FTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
390
391
392
/*-------------------TMS570_DMA_LFSINTENAS-------------------*/
393
/* field: LFSINTENA - Last frame started (LFS) interrupt enable. */
394
#define TMS570_DMA_LFSINTENAS_LFSINTENA(val) BSP_FLD32(val,0, 15)
395
#define TMS570_DMA_LFSINTENAS_LFSINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
396
#define TMS570_DMA_LFSINTENAS_LFSINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
397
398
399
/*-------------------TMS570_DMA_LFSINTENAR-------------------*/
400
/* field: LFSINTDIS - Last frame started (LFS) interrupt disable. */
401
#define TMS570_DMA_LFSINTENAR_LFSINTDIS(val) BSP_FLD32(val,0, 15)
402
#define TMS570_DMA_LFSINTENAR_LFSINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
403
#define TMS570_DMA_LFSINTENAR_LFSINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
404
405
406
/*-------------------TMS570_DMA_HBCINTENAS-------------------*/
407
/* field: HBCINTENA - Half block complete (HBC) interrupt enable. */
408
#define TMS570_DMA_HBCINTENAS_HBCINTENA(val) BSP_FLD32(val,0, 15)
409
#define TMS570_DMA_HBCINTENAS_HBCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
410
#define TMS570_DMA_HBCINTENAS_HBCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
411
412
413
/*-------------------TMS570_DMA_HBCINTENAR-------------------*/
414
/* field: HBCINTDIS - Half block complete (HBC) interrupt disable. */
415
#define TMS570_DMA_HBCINTENAR_HBCINTDIS(val) BSP_FLD32(val,0, 15)
416
#define TMS570_DMA_HBCINTENAR_HBCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
417
#define TMS570_DMA_HBCINTENAR_HBCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
418
419
420
/*-------------------TMS570_DMA_BTCINTENAS-------------------*/
421
/* field: BTCINTENA - Block transfer complete (BTC) interrupt enable. */
422
#define TMS570_DMA_BTCINTENAS_BTCINTENA(val) BSP_FLD32(val,0, 15)
423
#define TMS570_DMA_BTCINTENAS_BTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
424
#define TMS570_DMA_BTCINTENAS_BTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
425
426
427
/*-------------------TMS570_DMA_BTCINTENAR-------------------*/
428
/* field: BTCINTDIS - Block transfer complete (BTC) interurpt disable. */
429
#define TMS570_DMA_BTCINTENAR_BTCINTDIS(val) BSP_FLD32(val,0, 15)
430
#define TMS570_DMA_BTCINTENAR_BTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
431
#define TMS570_DMA_BTCINTENAR_BTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
432
433
434
/*--------------------TMS570_DMA_GINTFLAG--------------------*/
435
/* field: GINT - Global interrupt flags. */
436
#define TMS570_DMA_GINTFLAG_GINT(val) BSP_FLD32(val,0, 15)
437
#define TMS570_DMA_GINTFLAG_GINT_GET(reg) BSP_FLD32GET(reg,0, 15)
438
#define TMS570_DMA_GINTFLAG_GINT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
439
440
441
/*---------------------TMS570_DMA_FTCFLAG---------------------*/
442
/* field: FTCI - Frame transfer complete (FTC) flags. */
443
#define TMS570_DMA_FTCFLAG_FTCI(val) BSP_FLD32(val,0, 15)
444
#define TMS570_DMA_FTCFLAG_FTCI_GET(reg) BSP_FLD32GET(reg,0, 15)
445
#define TMS570_DMA_FTCFLAG_FTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
446
447
448
/*---------------------TMS570_DMA_LFSFLAG---------------------*/
449
/* field: LFSI - Last frame started (LFS) flags. */
450
#define TMS570_DMA_LFSFLAG_LFSI(val) BSP_FLD32(val,0, 15)
451
#define TMS570_DMA_LFSFLAG_LFSI_GET(reg) BSP_FLD32GET(reg,0, 15)
452
#define TMS570_DMA_LFSFLAG_LFSI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
453
454
455
/*---------------------TMS570_DMA_HBCFLAG---------------------*/
456
/* field: HBCI - Half block transfer (HBC) complete flags. */
457
#define TMS570_DMA_HBCFLAG_HBCI(val) BSP_FLD32(val,0, 15)
458
#define TMS570_DMA_HBCFLAG_HBCI_GET(reg) BSP_FLD32GET(reg,0, 15)
459
#define TMS570_DMA_HBCFLAG_HBCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
460
461
462
/*---------------------TMS570_DMA_BTCFLAG---------------------*/
463
/* field: BTCI - Block transfer complete (BTC) flags. */
464
#define TMS570_DMA_BTCFLAG_BTCI(val) BSP_FLD32(val,0, 15)
465
#define TMS570_DMA_BTCFLAG_BTCI_GET(reg) BSP_FLD32GET(reg,0, 15)
466
#define TMS570_DMA_BTCFLAG_BTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
467
468
469
/*---------------------TMS570_DMA_BERFLAG---------------------*/
470
/* field: BERI - Bus error (BER) flags. */
471
#define TMS570_DMA_BERFLAG_BERI(val) BSP_FLD32(val,0, 15)
472
#define TMS570_DMA_BERFLAG_BERI_GET(reg) BSP_FLD32GET(reg,0, 15)
473
#define TMS570_DMA_BERFLAG_BERI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
474
475
476
/*-------------------TMS570_DMA_FTCAOFFSET-------------------*/
477
/* field: sbz - These bits should always be programmed as zero. */
478
#define TMS570_DMA_FTCAOFFSET_sbz(val) BSP_FLD32(val,6, 7)
479
#define TMS570_DMA_FTCAOFFSET_sbz_GET(reg) BSP_FLD32GET(reg,6, 7)
480
#define TMS570_DMA_FTCAOFFSET_sbz_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
481
482
/* field: FTCA - Channel causing FTC interrupt Group A. */
483
#define TMS570_DMA_FTCAOFFSET_FTCA(val) BSP_FLD32(val,0, 5)
484
#define TMS570_DMA_FTCAOFFSET_FTCA_GET(reg) BSP_FLD32GET(reg,0, 5)
485
#define TMS570_DMA_FTCAOFFSET_FTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
486
487
488
/*-------------------TMS570_DMA_LFSAOFFSET-------------------*/
489
/* field: LFSA - Channel causing LFS interrupt Group A. */
490
#define TMS570_DMA_LFSAOFFSET_LFSA(val) BSP_FLD32(val,0, 5)
491
#define TMS570_DMA_LFSAOFFSET_LFSA_GET(reg) BSP_FLD32GET(reg,0, 5)
492
#define TMS570_DMA_LFSAOFFSET_LFSA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
493
494
495
/*-------------------TMS570_DMA_HBCAOFFSET-------------------*/
496
/* field: HBCA - Channel causing HBC interrupt Group A. */
497
#define TMS570_DMA_HBCAOFFSET_HBCA(val) BSP_FLD32(val,0, 5)
498
#define TMS570_DMA_HBCAOFFSET_HBCA_GET(reg) BSP_FLD32GET(reg,0, 5)
499
#define TMS570_DMA_HBCAOFFSET_HBCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
500
501
502
/*-------------------TMS570_DMA_BTCAOFFSET-------------------*/
503
/* field: BTCA - Channel causing BTC interrupt Group A. */
504
#define TMS570_DMA_BTCAOFFSET_BTCA(val) BSP_FLD32(val,0, 5)
505
#define TMS570_DMA_BTCAOFFSET_BTCA_GET(reg) BSP_FLD32GET(reg,0, 5)
506
#define TMS570_DMA_BTCAOFFSET_BTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
507
508
509
/*-------------------TMS570_DMA_BERAOFFSET-------------------*/
510
/* field: BERA - Channel causing BER interrupt Group A. */
511
#define TMS570_DMA_BERAOFFSET_BERA(val) BSP_FLD32(val,0, 5)
512
#define TMS570_DMA_BERAOFFSET_BERA_GET(reg) BSP_FLD32GET(reg,0, 5)
513
#define TMS570_DMA_BERAOFFSET_BERA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
514
515
516
/*-------------------TMS570_DMA_FTCBOFFSET-------------------*/
517
/* field: FTCB - Channel causing FTC interrupt Group B. */
518
#define TMS570_DMA_FTCBOFFSET_FTCB(val) BSP_FLD32(val,0, 5)
519
#define TMS570_DMA_FTCBOFFSET_FTCB_GET(reg) BSP_FLD32GET(reg,0, 5)
520
#define TMS570_DMA_FTCBOFFSET_FTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
521
522
523
/*-------------------TMS570_DMA_LFSBOFFSET-------------------*/
524
/* field: LFSB - Channel causing LFS interrupt Group B. */
525
#define TMS570_DMA_LFSBOFFSET_LFSB(val) BSP_FLD32(val,0, 5)
526
#define TMS570_DMA_LFSBOFFSET_LFSB_GET(reg) BSP_FLD32GET(reg,0, 5)
527
#define TMS570_DMA_LFSBOFFSET_LFSB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
528
529
530
/*-------------------TMS570_DMA_HBCBOFFSET-------------------*/
531
/* field: HBCB - Channel causing HBC interrupt Group B. */
532
#define TMS570_DMA_HBCBOFFSET_HBCB(val) BSP_FLD32(val,0, 5)
533
#define TMS570_DMA_HBCBOFFSET_HBCB_GET(reg) BSP_FLD32GET(reg,0, 5)
534
#define TMS570_DMA_HBCBOFFSET_HBCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
535
536
537
/*-------------------TMS570_DMA_BTCBOFFSET-------------------*/
538
/* field: BTCB - interrupt for Group B if the corresponding interrupt enable is set. */
539
#define TMS570_DMA_BTCBOFFSET_BTCB(val) BSP_FLD32(val,0, 5)
540
#define TMS570_DMA_BTCBOFFSET_BTCB_GET(reg) BSP_FLD32GET(reg,0, 5)
541
#define TMS570_DMA_BTCBOFFSET_BTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
542
543
544
/*-------------------TMS570_DMA_BERBOFFSET-------------------*/
545
/* field: BERB - Channel causing BER interrupt Group B. */
546
#define TMS570_DMA_BERBOFFSET_BERB(val) BSP_FLD32(val,0, 5)
547
#define TMS570_DMA_BERBOFFSET_BERB_GET(reg) BSP_FLD32GET(reg,0, 5)
548
#define TMS570_DMA_BERBOFFSET_BERB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
549
550
551
/*----------------------TMS570_DMA_PTCRL----------------------*/
552
/* field: PENDB - Transfers pending for Port B. This flag determines if transfers are ongoing on port B. */
553
#define TMS570_DMA_PTCRL_PENDB BSP_BIT32(24)
554
555
/* field: BYB - Bypass FIFO B. */
556
#define TMS570_DMA_PTCRL_BYB BSP_BIT32(18)
557
558
/* field: PSFRHQPB - Priority scheme fix or rotate for high priority queue of Port B. */
559
#define TMS570_DMA_PTCRL_PSFRHQPB BSP_BIT32(17)
560
561
/* field: PSFRLQPB - Priority scheme fix or rotate for low priority queue of Port B. */
562
#define TMS570_DMA_PTCRL_PSFRLQPB BSP_BIT32(16)
563
564
565
/*---------------------TMS570_DMA_RTCTRL---------------------*/
566
/* field: RTC - RAM Test Control. */
567
#define TMS570_DMA_RTCTRL_RTC BSP_BIT32(0)
568
569
570
/*----------------------TMS570_DMA_DCTRL----------------------*/
571
/* field: CHNUM - Channel Number. */
572
#define TMS570_DMA_DCTRL_CHNUM(val) BSP_FLD32(val,24, 28)
573
#define TMS570_DMA_DCTRL_CHNUM_GET(reg) BSP_FLD32GET(reg,24, 28)
574
#define TMS570_DMA_DCTRL_CHNUM_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
575
576
/* field: DMADBGS - DMA debug status. */
577
#define TMS570_DMA_DCTRL_DMADBGS BSP_BIT32(16)
578
579
/* field: DBGEN - Debug Enable. */
580
#define TMS570_DMA_DCTRL_DBGEN BSP_BIT32(0)
581
582
583
/*-----------------------TMS570_DMA_WPR-----------------------*/
584
/* field: WP - Watch point. */
585
/* Whole 32 bits */
586
587
/*-----------------------TMS570_DMA_WMR-----------------------*/
588
/* field: WM - Watch mask. */
589
/* Whole 32 bits */
590
591
/*--------------------TMS570_DMA_PBACSADDR--------------------*/
592
/* field: PBACSA - Port B Active Channel Source Address. */
593
/* Whole 32 bits */
594
595
/*--------------------TMS570_DMA_PBACDADDR--------------------*/
596
/* field: PBACDA - address of the active channel as broadcasted in Section 16.3.1.3 for Port B. */
597
/* Whole 32 bits */
598
599
/*---------------------TMS570_DMA_PBACTC---------------------*/
600
/* field: PBFTCOUNT - Port B active channel frame count. */
601
#define TMS570_DMA_PBACTC_PBFTCOUNT(val) BSP_FLD32(val,16, 28)
602
#define TMS570_DMA_PBACTC_PBFTCOUNT_GET(reg) BSP_FLD32GET(reg,16, 28)
603
#define TMS570_DMA_PBACTC_PBFTCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,16, 28)
604
605
/* field: PBETCOUNT - Port B active channel element count. */
606
#define TMS570_DMA_PBACTC_PBETCOUNT(val) BSP_FLD32(val,0, 12)
607
#define TMS570_DMA_PBACTC_PBETCOUNT_GET(reg) BSP_FLD32GET(reg,0, 12)
608
#define TMS570_DMA_PBACTC_PBETCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 12)
609
610
611
/*---------------------TMS570_DMA_DMAPCR---------------------*/
612
/* field: ERRA - Error action. */
613
#define TMS570_DMA_DMAPCR_ERRA BSP_BIT32(16)
614
615
/* field: TEST - When this bit is set, the parity bits are memory mapped to make them accessible by the CPU. */
616
#define TMS570_DMA_DMAPCR_TEST BSP_BIT32(8)
617
618
/* field: PARITY_ENA - Parity error detection enable. */
619
#define TMS570_DMA_DMAPCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
620
#define TMS570_DMA_DMAPCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
621
#define TMS570_DMA_DMAPCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
622
623
624
/*---------------------TMS570_DMA_DMAPAR---------------------*/
625
/* field: EDFLAG - Parity Error Detection Flag. */
626
#define TMS570_DMA_DMAPAR_EDFLAG BSP_BIT32(24)
627
628
/* field: ERRORADDRESS - Error address. These bits hold the address of the first parity error generated in the RAM. */
629
#define TMS570_DMA_DMAPAR_ERRORADDRESS(val) BSP_FLD32(val,0, 11)
630
#define TMS570_DMA_DMAPAR_ERRORADDRESS_GET(reg) BSP_FLD32GET(reg,0, 11)
631
#define TMS570_DMA_DMAPAR_ERRORADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
632
633
634
/*--------------------TMS570_DMA_DMAMPCTRL--------------------*/
635
/* field: INT3AB - Interrupt assignment of region 3 to Group A or Group B. */
636
#define TMS570_DMA_DMAMPCTRL_INT3AB BSP_BIT32(28)
637
638
/* field: INT3ENA - Interrupt enable of region 3. */
639
#define TMS570_DMA_DMAMPCTRL_INT3ENA BSP_BIT32(27)
640
641
/* field: REG3AP - Region 3 access permission. */
642
#define TMS570_DMA_DMAMPCTRL_REG3AP(val) BSP_FLD32(val,25, 26)
643
#define TMS570_DMA_DMAMPCTRL_REG3AP_GET(reg) BSP_FLD32GET(reg,25, 26)
644
#define TMS570_DMA_DMAMPCTRL_REG3AP_SET(reg,val) BSP_FLD32SET(reg, val,25, 26)
645
646
/* field: REG3ENA - Region 3 enable. */
647
#define TMS570_DMA_DMAMPCTRL_REG3ENA BSP_BIT32(24)
648
649
/* field: INT2AB - Interrupt assignment of region 2 to Group A or Group B. */
650
#define TMS570_DMA_DMAMPCTRL_INT2AB BSP_BIT32(20)
651
652
/* field: INT2ENA - Interrupt enable of region 2. */
653
#define TMS570_DMA_DMAMPCTRL_INT2ENA BSP_BIT32(19)
654
655
/* field: REG2AP - Region 2 access permission. These bits determine the access permission for region 2. */
656
#define TMS570_DMA_DMAMPCTRL_REG2AP(val) BSP_FLD32(val,17, 18)
657
#define TMS570_DMA_DMAMPCTRL_REG2AP_GET(reg) BSP_FLD32GET(reg,17, 18)
658
#define TMS570_DMA_DMAMPCTRL_REG2AP_SET(reg,val) BSP_FLD32SET(reg, val,17, 18)
659
660
/* field: REG2ENA - Region 2 enable. */
661
#define TMS570_DMA_DMAMPCTRL_REG2ENA BSP_BIT32(16)
662
663
/* field: INT1AB - Interrupt assignment of region 1 to Group A or Group B. */
664
#define TMS570_DMA_DMAMPCTRL_INT1AB BSP_BIT32(12)
665
666
/* field: INT1ENA - Interrupt enable of region 1. */
667
#define TMS570_DMA_DMAMPCTRL_INT1ENA BSP_BIT32(11)
668
669
/* field: REG1AP - Region 1 access permission. */
670
#define TMS570_DMA_DMAMPCTRL_REG1AP(val) BSP_FLD32(val,9, 10)
671
#define TMS570_DMA_DMAMPCTRL_REG1AP_GET(reg) BSP_FLD32GET(reg,9, 10)
672
#define TMS570_DMA_DMAMPCTRL_REG1AP_SET(reg,val) BSP_FLD32SET(reg, val,9, 10)
673
674
/* field: REG1ENA - Region 1 enable. */
675
#define TMS570_DMA_DMAMPCTRL_REG1ENA BSP_BIT32(8)
676
677
/* field: INT0AB - Interrupt assignment of region 0 to Group A or Group B. */
678
#define TMS570_DMA_DMAMPCTRL_INT0AB BSP_BIT32(4)
679
680
/* field: INT0ENA - Interrupt enable of region 0. */
681
#define TMS570_DMA_DMAMPCTRL_INT0ENA BSP_BIT32(3)
682
683
/* field: REG0AP - Region 0 access permission. These bits determine the access permission for region 0. */
684
#define TMS570_DMA_DMAMPCTRL_REG0AP(val) BSP_FLD32(val,1, 2)
685
#define TMS570_DMA_DMAMPCTRL_REG0AP_GET(reg) BSP_FLD32GET(reg,1, 2)
686
#define TMS570_DMA_DMAMPCTRL_REG0AP_SET(reg,val) BSP_FLD32SET(reg, val,1, 2)
687
688
/* field: REG0ENA - Region 0 enable. */
689
#define TMS570_DMA_DMAMPCTRL_REG0ENA BSP_BIT32(0)
690
691
692
/*---------------------TMS570_DMA_DMAMPST---------------------*/
693
/* field: REG3FT - Region 3 fault. */
694
#define TMS570_DMA_DMAMPST_REG3FT BSP_BIT32(24)
695
696
/* field: REG2FT - Region 2 fault. */
697
#define TMS570_DMA_DMAMPST_REG2FT BSP_BIT32(16)
698
699
/* field: REG1FT - Region 1 fault. */
700
#define TMS570_DMA_DMAMPST_REG1FT BSP_BIT32(8)
701
702
/* field: REG0FT - Region 0 fault. */
703
#define TMS570_DMA_DMAMPST_REG0FT BSP_BIT32(0)
704
705
706
/*--------------------TMS570_DMA_DMAMPROS--------------------*/
707
708
/* Whole 32 bits */
709
710
711
#endif
/* LIBBSP_ARM_TMS570_DMA */
utility.h
This header file provides utility macros for BSPs.
tms570_dma_t
Definition:
reg_dma.h:49
Definition:
reg_dma.h:44
