RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_dcc.h
1
/* The header file is generated by make_header.py from DCC.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_DCC
40
#define LIBBSP_ARM_TMS570_DCC
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t GCTRL;
/*DCC Global Control Register*/
46
uint32_t REV;
/*DCC Revision Id Register*/
47
uint32_t CNT0SEED;
/*DCC Counter0 Seed Register*/
48
uint32_t VALID0SEED;
/*DCC Valid0 Seed Register*/
49
uint32_t CNT1SEED;
/*DCC Counter1 Seed Register*/
50
uint32_t STAT;
/*DCC Status Register*/
51
uint32_t CNT0;
/*DCC Counter0 Value Register*/
52
uint32_t VALID0;
/*DCC Valid0 Value Register*/
53
uint32_t CNT1;
/*DCC Counter1 Value Register*/
54
uint32_t CNT1CLKSRC;
/*DCC Counter1 Clock Source Selection Register*/
55
uint32_t CNT0CLKSRC;
/*DCC Counter0 Clock Source Selection Register*/
56
tms570_dcc_t
57
58
59
/*----------------------TMS570_DCC_GCTRL----------------------*/
60
/* field: DONE_INT_ENA - Done Interrupt Enable. */
61
#define TMS570_DCC_GCTRL_DONE_INT_ENA(val) BSP_FLD32(val,12, 15)
62
#define TMS570_DCC_GCTRL_DONE_INT_ENA_GET(reg) BSP_FLD32GET(reg,12, 15)
63
#define TMS570_DCC_GCTRL_DONE_INT_ENA_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
64
65
/* field: SINGLE_SHOT - Single-Shot Mode Enable. */
66
#define TMS570_DCC_GCTRL_SINGLE_SHOT(val) BSP_FLD32(val,8, 11)
67
#define TMS570_DCC_GCTRL_SINGLE_SHOT_GET(reg) BSP_FLD32GET(reg,8, 11)
68
#define TMS570_DCC_GCTRL_SINGLE_SHOT_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
69
70
/* field: ERR_ENA - Error Interrupt Enable. */
71
#define TMS570_DCC_GCTRL_ERR_ENA(val) BSP_FLD32(val,4, 7)
72
#define TMS570_DCC_GCTRL_ERR_ENA_GET(reg) BSP_FLD32GET(reg,4, 7)
73
#define TMS570_DCC_GCTRL_ERR_ENA_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
74
75
/* field: DCC_ENA - DCC Enable. */
76
#define TMS570_DCC_GCTRL_DCC_ENA(val) BSP_FLD32(val,0, 3)
77
#define TMS570_DCC_GCTRL_DCC_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
78
#define TMS570_DCC_GCTRL_DCC_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
79
80
81
/*-----------------------TMS570_DCC_REV-----------------------*/
82
/* field: SCHEME - Reads return 01, writes have no effect. */
83
#define TMS570_DCC_REV_SCHEME(val) BSP_FLD32(val,30, 31)
84
#define TMS570_DCC_REV_SCHEME_GET(reg) BSP_FLD32GET(reg,30, 31)
85
#define TMS570_DCC_REV_SCHEME_SET(reg,val) BSP_FLD32SET(reg, val,30, 31)
86
87
/* field: FUNC - Functional release number. Reads return 0x000, writes have no effect. */
88
#define TMS570_DCC_REV_FUNC(val) BSP_FLD32(val,16, 27)
89
#define TMS570_DCC_REV_FUNC_GET(reg) BSP_FLD32GET(reg,16, 27)
90
#define TMS570_DCC_REV_FUNC_SET(reg,val) BSP_FLD32SET(reg, val,16, 27)
91
92
/* field: RTL - Design release number. Reads return 0x00, writes have no effect. */
93
#define TMS570_DCC_REV_RTL(val) BSP_FLD32(val,11, 15)
94
#define TMS570_DCC_REV_RTL_GET(reg) BSP_FLD32GET(reg,11, 15)
95
#define TMS570_DCC_REV_RTL_SET(reg,val) BSP_FLD32SET(reg, val,11, 15)
96
97
/* field: MAJOR - Major revision number. Reads return 0x2, writes have no effect. */
98
#define TMS570_DCC_REV_MAJOR(val) BSP_FLD32(val,8, 10)
99
#define TMS570_DCC_REV_MAJOR_GET(reg) BSP_FLD32GET(reg,8, 10)
100
#define TMS570_DCC_REV_MAJOR_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
101
102
/* field: CUSTOM - Custom version number. Reads return 0x0, writes have no effect. */
103
#define TMS570_DCC_REV_CUSTOM(val) BSP_FLD32(val,6, 7)
104
#define TMS570_DCC_REV_CUSTOM_GET(reg) BSP_FLD32GET(reg,6, 7)
105
#define TMS570_DCC_REV_CUSTOM_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
106
107
/* field: MINOR - Minor revision number. Reads return 0x4, writes have no effect. */
108
#define TMS570_DCC_REV_MINOR(val) BSP_FLD32(val,0, 5)
109
#define TMS570_DCC_REV_MINOR_GET(reg) BSP_FLD32GET(reg,0, 5)
110
#define TMS570_DCC_REV_MINOR_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
111
112
113
/*--------------------TMS570_DCC_CNT0SEED--------------------*/
114
/* field: COUNT0_SEED - Seed value for DCC Counter0. */
115
#define TMS570_DCC_CNT0SEED_COUNT0_SEED(val) BSP_FLD32(val,0, 19)
116
#define TMS570_DCC_CNT0SEED_COUNT0_SEED_GET(reg) BSP_FLD32GET(reg,0, 19)
117
#define TMS570_DCC_CNT0SEED_COUNT0_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
118
119
120
/*-------------------TMS570_DCC_VALID0SEED-------------------*/
121
/* field: VALID0_SEED - XXX */
122
#define TMS570_DCC_VALID0SEED_VALID0_SEED(val) BSP_FLD32(val,0, 15)
123
#define TMS570_DCC_VALID0SEED_VALID0_SEED_GET(reg) BSP_FLD32GET(reg,0, 15)
124
#define TMS570_DCC_VALID0SEED_VALID0_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
125
126
127
/*--------------------TMS570_DCC_CNT1SEED--------------------*/
128
/* field: COUNT1_SEED - Seed value for DCC Counter1. */
129
#define TMS570_DCC_CNT1SEED_COUNT1_SEED(val) BSP_FLD32(val,0, 19)
130
#define TMS570_DCC_CNT1SEED_COUNT1_SEED_GET(reg) BSP_FLD32GET(reg,0, 19)
131
#define TMS570_DCC_CNT1SEED_COUNT1_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
132
133
134
/*----------------------TMS570_DCC_STAT----------------------*/
135
/* field: DONE_FLG - Single-Shot Sequence Done flag. */
136
#define TMS570_DCC_STAT_DONE_FLG BSP_BIT32(1)
137
138
/* field: ERR_FLG - Error flag. Indicates that a DCC error has occurred. */
139
#define TMS570_DCC_STAT_ERR_FLG BSP_BIT32(0)
140
141
142
/*----------------------TMS570_DCC_CNT0----------------------*/
143
/* field: COUNT0 - Current value of DCC Counter0. */
144
#define TMS570_DCC_CNT0_COUNT0(val) BSP_FLD32(val,0, 19)
145
#define TMS570_DCC_CNT0_COUNT0_GET(reg) BSP_FLD32GET(reg,0, 19)
146
#define TMS570_DCC_CNT0_COUNT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
147
148
149
/*---------------------TMS570_DCC_VALID0---------------------*/
150
/* field: VALID0 - Current value for DCC Valid0. */
151
#define TMS570_DCC_VALID0_VALID0(val) BSP_FLD32(val,0, 15)
152
#define TMS570_DCC_VALID0_VALID0_GET(reg) BSP_FLD32GET(reg,0, 15)
153
#define TMS570_DCC_VALID0_VALID0_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
154
155
156
/*----------------------TMS570_DCC_CNT1----------------------*/
157
/* field: COUNT1 - Current value for DCC Counter1. */
158
#define TMS570_DCC_CNT1_COUNT1(val) BSP_FLD32(val,0, 19)
159
#define TMS570_DCC_CNT1_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19)
160
#define TMS570_DCC_CNT1_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
161
162
163
/*-------------------TMS570_DCC_CNT1CLKSRC-------------------*/
164
/* field: KEY - Key to enable clock source selection for Counter1. */
165
#define TMS570_DCC_CNT1CLKSRC_KEY(val) BSP_FLD32(val,12, 15)
166
#define TMS570_DCC_CNT1CLKSRC_KEY_GET(reg) BSP_FLD32GET(reg,12, 15)
167
#define TMS570_DCC_CNT1CLKSRC_KEY_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
168
169
/* field: CNT1_CLKSRC - Clock Source for Counter1 when KEY is programmed to be 0xA. */
170
#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC(val) BSP_FLD32(val,0, 3)
171
#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
172
#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
173
174
175
/*-------------------TMS570_DCC_CNT0CLKSRC-------------------*/
176
/* field: CNT0_CLKSRC - Clock Source for Counter0 */
177
#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC(val) BSP_FLD32(val,0, 3)
178
#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
179
#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
180
181
182
183
#endif
/* LIBBSP_ARM_TMS570_DCC */
utility.h
This header file provides utility macros for BSPs.
tms570_dcc_t
Definition:
reg_dcc.h:44
