39#ifndef LIBBSP_ARM_TMS570_ADC
40#define LIBBSP_ARM_TMS570_ADC
100 uint32_t MAGINT2MASK;
102 uint32_t MAGINT3MASK;
103 uint8_t reserved1 [24];
104 uint32_t MAGTHRINTENASET;
105 uint32_t MAGTHRINTENACLR;
106 uint32_t MAGTHRINTFLG;
107 uint32_t MAGTHRINTOFFSET;
108 uint32_t GxFIFORESETCR[3];
109 uint32_t EVRAMWRADDR;
110 uint32_t G1RAMWRADDR;
111 uint32_t G2RAMWRADDR;
114 uint32_t PWRUPDLYCTRL;
120#define TMS570_ADC_BUFx_G2_EMPTY_10bit_mode BSP_BIT32(15)
123#define TMS570_ADC_BUFx_G2_CHID_10bit_mode(val) BSP_FLD32(val,10, 14)
124#define TMS570_ADC_BUFx_G2_CHID_10bit_mode_GET(reg) BSP_FLD32GET(reg,10, 14)
125#define TMS570_ADC_BUFx_G2_CHID_10bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,10, 14)
128#define TMS570_ADC_BUFx_G2_DR_10bit_mode(val) BSP_FLD32(val,0, 9)
129#define TMS570_ADC_BUFx_G2_DR_10bit_mode_GET(reg) BSP_FLD32GET(reg,0, 9)
130#define TMS570_ADC_BUFx_G2_DR_10bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
133#define TMS570_ADC_BUFx_G2_EMPTY_12bit_mode BSP_BIT32(31)
136#define TMS570_ADC_BUFx_G2_CHID_12bit_mode(val) BSP_FLD32(val,16, 20)
137#define TMS570_ADC_BUFx_G2_CHID_12bit_mode_GET(reg) BSP_FLD32GET(reg,16, 20)
138#define TMS570_ADC_BUFx_G2_CHID_12bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,16, 20)
141#define TMS570_ADC_BUFx_G2_DR_12bit_mode(val) BSP_FLD32(val,0, 11)
142#define TMS570_ADC_BUFx_G2_DR_12bit_mode_GET(reg) BSP_FLD32GET(reg,0, 11)
143#define TMS570_ADC_BUFx_G2_DR_12bit_mode_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
148#define TMS570_ADC_RSTCR_RESET BSP_BIT32(0)
153#define TMS570_ADC_OPMODECR_10_12_BIT BSP_BIT32(31)
158#define TMS570_ADC_CLOCKCR_PS(val) BSP_FLD32(val,0, 4)
159#define TMS570_ADC_CLOCKCR_PS_GET(reg) BSP_FLD32GET(reg,0, 4)
160#define TMS570_ADC_CLOCKCR_PS_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
165#define TMS570_ADC_CALCR_SELF_TEST BSP_BIT32(24)
168#define TMS570_ADC_CALCR_CAL_ST BSP_BIT32(16)
171#define TMS570_ADC_CALCR_BRIDGE_EN BSP_BIT32(9)
174#define TMS570_ADC_CALCR_HILO BSP_BIT32(8)
177#define TMS570_ADC_CALCR_CAL_EN BSP_BIT32(0)
182#define TMS570_ADC_GxMODECR_No_Reset_on_ChnSel BSP_BIT32(16)
185#define TMS570_ADC_GxMODECR_EV_DATA_FMT(val) BSP_FLD32(val,8, 9)
186#define TMS570_ADC_GxMODECR_EV_DATA_FMT_GET(reg) BSP_FLD32GET(reg,8, 9)
187#define TMS570_ADC_GxMODECR_EV_DATA_FMT_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
192#define TMS570_ADC_EVSRC_EV_EDG_BOTH BSP_BIT32(4)
195#define TMS570_ADC_EVSRC_EV_EDG_SEL BSP_BIT32(3)
198#define TMS570_ADC_EVSRC_EV_SRC(val) BSP_FLD32(val,0, 2)
199#define TMS570_ADC_EVSRC_EV_SRC_GET(reg) BSP_FLD32GET(reg,0, 2)
200#define TMS570_ADC_EVSRC_EV_SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
205#define TMS570_ADC_G1SRC_GI_EDG_BOTH BSP_BIT32(4)
208#define TMS570_ADC_G1SRC_G1_EDG_SEL BSP_BIT32(3)
211#define TMS570_ADC_G1SRC_G1_SRC(val) BSP_FLD32(val,0, 2)
212#define TMS570_ADC_G1SRC_G1_SRC_GET(reg) BSP_FLD32GET(reg,0, 2)
213#define TMS570_ADC_G1SRC_G1_SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
218#define TMS570_ADC_G2SRC_G2_EDG_BOTH BSP_BIT32(4)
221#define TMS570_ADC_G2SRC_G2_EDG_SEL BSP_BIT32(3)
224#define TMS570_ADC_G2SRC_G2_SRC(val) BSP_FLD32(val,0, 2)
225#define TMS570_ADC_G2SRC_G2_SRC_GET(reg) BSP_FLD32GET(reg,0, 2)
226#define TMS570_ADC_G2SRC_G2_SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
231#define TMS570_ADC_GxINTENA_EV_END_INT_EN BSP_BIT32(3)
234#define TMS570_ADC_GxINTENA_EV_OVR_INT_EN BSP_BIT32(1)
237#define TMS570_ADC_GxINTENA_EV_THR_INT_EN BSP_BIT32(0)
242#define TMS570_ADC_GxINTFLG_EV_END BSP_BIT32(3)
245#define TMS570_ADC_GxINTFLG_EV_MEM_EMPTY BSP_BIT32(2)
248#define TMS570_ADC_GxINTFLG_EV_MEM_OVERRUN BSP_BIT32(1)
251#define TMS570_ADC_GxINTFLG_EV_THR_INT_FLG BSP_BIT32(0)
256#define TMS570_ADC_GxINTCR_Sign_Extension(val) BSP_FLD32(val,9, 15)
257#define TMS570_ADC_GxINTCR_Sign_Extension_GET(reg) BSP_FLD32GET(reg,9, 15)
258#define TMS570_ADC_GxINTCR_Sign_Extension_SET(reg,val) BSP_FLD32SET(reg, val,9, 15)
261#define TMS570_ADC_GxINTCR_EV_THR(val) BSP_FLD32(val,0, 8)
262#define TMS570_ADC_GxINTCR_EV_THR_GET(reg) BSP_FLD32GET(reg,0, 8)
263#define TMS570_ADC_GxINTCR_EV_THR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
268#define TMS570_ADC_EVDMACR_EV_BLOCKS(val) BSP_FLD32(val,16, 24)
269#define TMS570_ADC_EVDMACR_EV_BLOCKS_GET(reg) BSP_FLD32GET(reg,16, 24)
270#define TMS570_ADC_EVDMACR_EV_BLOCKS_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
273#define TMS570_ADC_EVDMACR_DMA_EV_END BSP_BIT32(3)
276#define TMS570_ADC_EVDMACR_EV_BLK_XFER BSP_BIT32(2)
279#define TMS570_ADC_EVDMACR_EV_DMA_EN BSP_BIT32(0)
284#define TMS570_ADC_G1DMACR_G1_BLOCKS(val) BSP_FLD32(val,16, 24)
285#define TMS570_ADC_G1DMACR_G1_BLOCKS_GET(reg) BSP_FLD32GET(reg,16, 24)
286#define TMS570_ADC_G1DMACR_G1_BLOCKS_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
289#define TMS570_ADC_G1DMACR_DMA_G1_END BSP_BIT32(3)
292#define TMS570_ADC_G1DMACR_G1_BLK_XFER BSP_BIT32(2)
295#define TMS570_ADC_G1DMACR_G1_DMA_EN BSP_BIT32(0)
300#define TMS570_ADC_G2DMACR_G2_BLOCKS(val) BSP_FLD32(val,16, 24)
301#define TMS570_ADC_G2DMACR_G2_BLOCKS_GET(reg) BSP_FLD32GET(reg,16, 24)
302#define TMS570_ADC_G2DMACR_G2_BLOCKS_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
305#define TMS570_ADC_G2DMACR_DMA_G2_END BSP_BIT32(3)
308#define TMS570_ADC_G2DMACR_G2_BLK_XFER BSP_BIT32(2)
311#define TMS570_ADC_G2DMACR_G2_DMA_EN BSP_BIT32(0)
316#define TMS570_ADC_BNDCR_BNDA(val) BSP_FLD32(val,16, 24)
317#define TMS570_ADC_BNDCR_BNDA_GET(reg) BSP_FLD32GET(reg,16, 24)
318#define TMS570_ADC_BNDCR_BNDA_SET(reg,val) BSP_FLD32SET(reg, val,16, 24)
321#define TMS570_ADC_BNDCR_BNDB(val) BSP_FLD32(val,0, 8)
322#define TMS570_ADC_BNDCR_BNDB_GET(reg) BSP_FLD32GET(reg,0, 8)
323#define TMS570_ADC_BNDCR_BNDB_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
328#define TMS570_ADC_BNDEND_BUF_INIT_ACTIVE BSP_BIT32(16)
331#define TMS570_ADC_BNDEND_BNDEND(val) BSP_FLD32(val,0, 2)
332#define TMS570_ADC_BNDEND_BNDEND_GET(reg) BSP_FLD32GET(reg,0, 2)
333#define TMS570_ADC_BNDEND_BNDEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
338#define TMS570_ADC_EVSAMP_EV_ACQ(val) BSP_FLD32(val,0, 11)
339#define TMS570_ADC_EVSAMP_EV_ACQ_GET(reg) BSP_FLD32GET(reg,0, 11)
340#define TMS570_ADC_EVSAMP_EV_ACQ_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
345#define TMS570_ADC_G1SAMP_G1_ACQ(val) BSP_FLD32(val,0, 11)
346#define TMS570_ADC_G1SAMP_G1_ACQ_GET(reg) BSP_FLD32GET(reg,0, 11)
347#define TMS570_ADC_G1SAMP_G1_ACQ_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
352#define TMS570_ADC_G2SAMP_G2_ACQ(val) BSP_FLD32(val,0, 11)
353#define TMS570_ADC_G2SAMP_G2_ACQ_GET(reg) BSP_FLD32GET(reg,0, 11)
354#define TMS570_ADC_G2SAMP_G2_ACQ_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
359#define TMS570_ADC_EVSR_EV_MEM_EMPTY BSP_BIT32(3)
362#define TMS570_ADC_EVSR_EV_BUSY BSP_BIT32(2)
365#define TMS570_ADC_EVSR_EV_STOP BSP_BIT32(1)
368#define TMS570_ADC_EVSR_EV_END BSP_BIT32(0)
373#define TMS570_ADC_G1SR_G1_MEM_EMPTY BSP_BIT32(3)
376#define TMS570_ADC_G1SR_G1_BUSY BSP_BIT32(2)
379#define TMS570_ADC_G1SR_G1_STOP BSP_BIT32(1)
382#define TMS570_ADC_G1SR_G1_END BSP_BIT32(0)
387#define TMS570_ADC_G2SR_G2_MEM_EMPTY BSP_BIT32(3)
390#define TMS570_ADC_G2SR_G2_BUSY BSP_BIT32(2)
393#define TMS570_ADC_G2SR_G2_STOP BSP_BIT32(1)
396#define TMS570_ADC_G2SR_G2_END BSP_BIT32(0)
401#define TMS570_ADC_GxSEL_EV_SEL(val) BSP_FLD32(val,0, 15)
402#define TMS570_ADC_GxSEL_EV_SEL_GET(reg) BSP_FLD32GET(reg,0, 15)
403#define TMS570_ADC_GxSEL_EV_SEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
408#define TMS570_ADC_CALR_ADCALR(val) BSP_FLD32(val,0, 11)
409#define TMS570_ADC_CALR_ADCALR_GET(reg) BSP_FLD32GET(reg,0, 11)
410#define TMS570_ADC_CALR_ADCALR_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
415#define TMS570_ADC_SMSTATE_LAST_CONV(val) BSP_FLD32(val,0, 23)
416#define TMS570_ADC_SMSTATE_LAST_CONV_GET(reg) BSP_FLD32GET(reg,0, 23)
417#define TMS570_ADC_SMSTATE_LAST_CONV_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
422#define TMS570_ADC_LASTCONV_LAST_CONV(val) BSP_FLD32(val,0, 23)
423#define TMS570_ADC_LASTCONV_LAST_CONV_GET(reg) BSP_FLD32GET(reg,0, 23)
424#define TMS570_ADC_LASTCONV_LAST_CONV_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
429#define TMS570_ADC_GxBUF_ADEVT_DIR BSP_BIT32(0)
434#define TMS570_ADC_EVEMUBUFFER_ADEVT_DIR BSP_BIT32(0)
439#define TMS570_ADC_G1EMUBUFFER_ADEVT_DIR BSP_BIT32(0)
444#define TMS570_ADC_G2EMUBUFFER_ADEVT_DIR BSP_BIT32(0)
449#define TMS570_ADC_EVTDIR_ADEVT_DIR BSP_BIT32(0)
454#define TMS570_ADC_EVTOUT_ADEVT_OUT BSP_BIT32(0)
459#define TMS570_ADC_EVTIN_ADEVT_IN BSP_BIT32(0)
464#define TMS570_ADC_EVTSET_ADEVT_SET BSP_BIT32(0)
469#define TMS570_ADC_EVTCLR_ADEVT_CLR BSP_BIT32(0)
474#define TMS570_ADC_EVTPDR_ADEVT_PDR BSP_BIT32(0)
479#define TMS570_ADC_EVTPDIS_ADEVT_PDIS BSP_BIT32(0)
484#define TMS570_ADC_EVTPSEL_ADEVT_PSEL BSP_BIT32(0)
489#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_CYC(val) BSP_FLD32(val,8, 15)
490#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_CYC_GET(reg) BSP_FLD32GET(reg,8, 15)
491#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_CYC_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
494#define TMS570_ADC_EVSAMPDISEN_EV_SAMP_DIS_EN BSP_BIT32(0)
499#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_CYC(val) BSP_FLD32(val,8, 15)
500#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_CYC_GET(reg) BSP_FLD32GET(reg,8, 15)
501#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_CYC_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
504#define TMS570_ADC_G1SAMPDISEN_G1_SAMP_DIS_EN BSP_BIT32(0)
509#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_CYC(val) BSP_FLD32(val,8, 15)
510#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_CYC_GET(reg) BSP_FLD32GET(reg,8, 15)
511#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_CYC_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
514#define TMS570_ADC_G2SAMPDISEN_G2_SAMP_DIS_EN BSP_BIT32(0)
519#define TMS570_ADC_MAGINTCRx_MAG_CHID2(val) BSP_FLD32(val,26, 30)
520#define TMS570_ADC_MAGINTCRx_MAG_CHID2_GET(reg) BSP_FLD32GET(reg,26, 30)
521#define TMS570_ADC_MAGINTCRx_MAG_CHID2_SET(reg,val) BSP_FLD32SET(reg, val,26, 30)
524#define TMS570_ADC_MAGINTCRx_MAG_THR2(val) BSP_FLD32(val,16, 25)
525#define TMS570_ADC_MAGINTCRx_MAG_THR2_GET(reg) BSP_FLD32GET(reg,16, 25)
526#define TMS570_ADC_MAGINTCRx_MAG_THR2_SET(reg,val) BSP_FLD32SET(reg, val,16, 25)
529#define TMS570_ADC_MAGINTCRx_COMP_CHID2(val) BSP_FLD32(val,8, 12)
530#define TMS570_ADC_MAGINTCRx_COMP_CHID2_GET(reg) BSP_FLD32GET(reg,8, 12)
531#define TMS570_ADC_MAGINTCRx_COMP_CHID2_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
534#define TMS570_ADC_MAGINTCRx_CHN_THR_COMP2 BSP_BIT32(1)
537#define TMS570_ADC_MAGINTCRx_CMP_GE_LT2 BSP_BIT32(0)
542#define TMS570_ADC_MAGINTxMASK_MAG_INT0_MASK(val) BSP_FLD32(val,0, 9)
543#define TMS570_ADC_MAGINTxMASK_MAG_INT0_MASK_GET(reg) BSP_FLD32GET(reg,0, 9)
544#define TMS570_ADC_MAGINTxMASK_MAG_INT0_MASK_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
549#define TMS570_ADC_MAGTHRINTENASET_MAG_INT_ENA_SET(val) BSP_FLD32(val,0, 2)
550#define TMS570_ADC_MAGTHRINTENASET_MAG_INT_ENA_SET_GET(reg) BSP_FLD32GET(reg,0, 2)
551#define TMS570_ADC_MAGTHRINTENASET_MAG_INT_ENA_SET_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
556#define TMS570_ADC_MAGTHRINTENACLR_MAG_INT_ENA_CLR(val) BSP_FLD32(val,0, 2)
557#define TMS570_ADC_MAGTHRINTENACLR_MAG_INT_ENA_CLR_GET(reg) BSP_FLD32GET(reg,0, 2)
558#define TMS570_ADC_MAGTHRINTENACLR_MAG_INT_ENA_CLR_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
563#define TMS570_ADC_MAGTHRINTFLG_MAG_INT_FLG(val) BSP_FLD32(val,0, 2)
564#define TMS570_ADC_MAGTHRINTFLG_MAG_INT_FLG_GET(reg) BSP_FLD32GET(reg,0, 2)
565#define TMS570_ADC_MAGTHRINTFLG_MAG_INT_FLG_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
570#define TMS570_ADC_MAGTHRINTOFFSET_MAG_INT_OFF(val) BSP_FLD32(val,0, 3)
571#define TMS570_ADC_MAGTHRINTOFFSET_MAG_INT_OFF_GET(reg) BSP_FLD32GET(reg,0, 3)
572#define TMS570_ADC_MAGTHRINTOFFSET_MAG_INT_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
577#define TMS570_ADC_GxFIFORESETCR_EV_FIFO_RESET BSP_BIT32(0)
582#define TMS570_ADC_EVRAMWRADDR_G1_RAM_ADDR(val) BSP_FLD32(val,0, 8)
583#define TMS570_ADC_EVRAMWRADDR_G1_RAM_ADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
584#define TMS570_ADC_EVRAMWRADDR_G1_RAM_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
589#define TMS570_ADC_G1RAMWRADDR_G1_RAM_ADDR(val) BSP_FLD32(val,0, 8)
590#define TMS570_ADC_G1RAMWRADDR_G1_RAM_ADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
591#define TMS570_ADC_G1RAMWRADDR_G1_RAM_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
596#define TMS570_ADC_G2RAMWRADDR_G2_RAM_ADDR(val) BSP_FLD32(val,0, 8)
597#define TMS570_ADC_G2RAMWRADDR_G2_RAM_ADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
598#define TMS570_ADC_G2RAMWRADDR_G2_RAM_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
603#define TMS570_ADC_PARCR_TEST BSP_BIT32(8)
606#define TMS570_ADC_PARCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
607#define TMS570_ADC_PARCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
608#define TMS570_ADC_PARCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
613#define TMS570_ADC_PARADDR_ERROR_ADDRESS(val) BSP_FLD32(val,2, 11)
614#define TMS570_ADC_PARADDR_ERROR_ADDRESS_GET(reg) BSP_FLD32GET(reg,2, 11)
615#define TMS570_ADC_PARADDR_ERROR_ADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,2, 11)
620#define TMS570_ADC_PWRUPDLYCTRL_PWRUP_DLY(val) BSP_FLD32(val,0, 9)
621#define TMS570_ADC_PWRUPDLYCTRL_PWRUP_DLY_GET(reg) BSP_FLD32GET(reg,0, 9)
622#define TMS570_ADC_PWRUPDLYCTRL_PWRUP_DLY_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
This header file provides utility macros for BSPs.
