RTEMS 6.1-rc1
Data Structures | Macros | Enumerations | Functions
ratemon.h File Reference
This header file defines the Rate-Monotonic Manager API. More...
#include <stdint.h>
#include <sys/_timespec.h>
#include <rtems/score/watchdogticks.h>
struct  rtems_rate_monotonic_period_statistics
 This structure provides the statistics of a period. More...
struct  rtems_rate_monotonic_period_status
 This structure provides the detailed status of a period. More...
#define RTEMS_PERIOD_STATUS   WATCHDOG_NO_TIMEOUT
 This constant is the interval passed to the rtems_rate_monotonic_period() directive to obtain status information.
enum  rtems_rate_monotonic_period_states { RATE_MONOTONIC_INACTIVE , RATE_MONOTONIC_ACTIVE , RATE_MONOTONIC_EXPIRED }
 This enumeration defines the states in which a period may be. More...
rtems_status_code rtems_rate_monotonic_create (rtems_name name, rtems_id *id)
 Creates a period. More...
rtems_status_code rtems_rate_monotonic_ident (rtems_name name, rtems_id *id)
 Identifies a period by the object name. More...
rtems_status_code rtems_rate_monotonic_cancel (rtems_id id)
 Cancels the period. More...
rtems_status_code rtems_rate_monotonic_delete (rtems_id id)
 Deletes the period. More...
rtems_status_code rtems_rate_monotonic_period (rtems_id id, rtems_interval length)
 Concludes the current period and start the next period, or gets the period status. More...
rtems_status_code rtems_rate_monotonic_get_status (rtems_id id, rtems_rate_monotonic_period_status *status)
 Gets the detailed status of the period. More...
rtems_status_code rtems_rate_monotonic_get_statistics (rtems_id id, rtems_rate_monotonic_period_statistics *status)
 Gets the statistics of the period. More...
rtems_status_code rtems_rate_monotonic_reset_statistics (rtems_id id)
 Resets the statistics of the period. More...
void rtems_rate_monotonic_reset_all_statistics (void)
 Resets the statistics of all periods. More...
void rtems_rate_monotonic_report_statistics (void)
 Reports the period statistics using the printk() printer. More...
void rtems_rate_monotonic_report_statistics_with_plugin (const struct rtems_printer *printer)
 Reports the period statistics using the printer plugin. More...
