RTEMS 6.1-rc1
barrierimpl.h
2
12/*
13 * COPYRIGHT (c) 1989-2011.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Copyright (c) 2017 embedded brains GmbH & Co. KG
17 *
18 * Redistribution and use in source and binary forms, with or without
19 * modification, are permitted provided that the following conditions
20 * are met:
21 * 1. Redistributions of source code must retain the above copyright
22 * notice, this list of conditions and the following disclaimer.
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in the
25 * documentation and/or other materials provided with the distribution.
26 *
27 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _RTEMS_POSIX_BARRIERIMPL_H
41#define _RTEMS_POSIX_BARRIERIMPL_H
42
43#include <errno.h>
44#include <pthread.h>
45
46#include <rtems/score/percpu.h>
48
49#ifdef __cplusplus
50extern "C" {
51#endif
52
53#define POSIX_BARRIER_MAGIC 0x1cf03773UL
54
55#define POSIX_BARRIER_TQ_OPERATIONS &_Thread_queue_Operations_FIFO
56
57typedef struct {
58 unsigned long flags;
60 unsigned int count;
61 unsigned int waiting_threads;
63
64static inline POSIX_Barrier_Control *_POSIX_Barrier_Get(
65 pthread_barrier_t *_barrier
66)
67{
68 return (POSIX_Barrier_Control *) _barrier;
69}
70
71static inline Thread_Control *_POSIX_Barrier_Queue_acquire(
72 POSIX_Barrier_Control *barrier,
73 Thread_queue_Context *queue_context
74)
75{
76 ISR_Level level;
77 Thread_Control *executing;
78
79 _Thread_queue_Context_initialize( queue_context );
80 _Thread_queue_Context_ISR_disable( queue_context, level );
81 _Thread_queue_Context_set_ISR_level( queue_context, level );
82 executing = _Thread_Executing;
83 _Thread_queue_Queue_acquire_critical(
84 &barrier->Queue.Queue,
85 &executing->Potpourri_stats,
86 &queue_context->Lock_context.Lock_context
87 );
88
89 return executing;
90}
91
92static inline void _POSIX_Barrier_Queue_release(
93 POSIX_Barrier_Control *barrier,
94 Thread_queue_Context *queue_context
95)
96{
97 _Thread_queue_Queue_release(
98 &barrier->Queue.Queue,
99 &queue_context->Lock_context.Lock_context
100 );
101}
102
103#define POSIX_BARRIER_VALIDATE_OBJECT( bar ) \
104 do { \
105 if ( \
106 ( bar ) == NULL \
107 || ( (uintptr_t) ( bar ) ^ POSIX_BARRIER_MAGIC ) != ( bar )->_flags \
108 ) { \
109 return EINVAL; \
110 } \
111 } while ( 0 )
112
113#ifdef __cplusplus
114}
115#endif
116
117#endif
118/* end of include file */
uint32_t ISR_Level
Definition: isrlevel.h:60
POSIX Threads Private Support.
This header file provides the interfaces of the Per-CPU Information.
Definition: barrierimpl.h:57
Thread queue context for the thread queue methods.
Definition: threadq.h:216
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition: threadq.h:221
ISR_lock_Context Lock_context
Definition: threadq.h:148
Thread queue with a layout compatible to struct _Thread_queue_Queue defined in Newlib <sys/lock....
Definition: threadqimpl.h:71
Definition: thread.h:812
This header file provides interfaces of the Thread Queue Handler which are only used by the implement...
