RTEMS 6.1-rc1
mqueueimpl.h
2
12/*
13 * COPYRIGHT (c) 1989-2013.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_POSIX_MQUEUE_INL
39#define _RTEMS_POSIX_MQUEUE_INL
40
41#include <rtems/posix/mqueue.h>
45
46#include <rtems/seterr.h>
47
48#ifdef __cplusplus
49extern "C" {
50#endif
51
60 Thread_queue_Context *queue_context
61);
62
63/*@
64 * @brief POSIX Message Queue Receive Support
65 *
66 * This routine supports the various flavors of receiving a message.
67 *
68 * @note The structure of the routines is identical to that of POSIX
69 * Message_queues to leave the option of having unnamed message
70 * queues at a future date. They are currently not part of the
71 * POSIX standard but unnamed message_queues are. This is also
72 * the reason for the apparently unnecessary tracking of
73 * the process_shared attribute. [In addition to the fact that
74 * it would be trivial to add pshared to the mq_attr structure
75 * and have process private message queues.]
76 *
77 * @note This code ignores the O_RDONLY/O_WRONLY/O_RDWR flag at open time.
78 */
79ssize_t _POSIX_Message_queue_Receive_support(
80 mqd_t mqdes,
81 char *msg_ptr,
82 size_t msg_len,
83 unsigned int *msg_prio,
84 const struct timespec *abstime,
85 Thread_queue_Enqueue_callout enqueue_callout
86);
87
94 mqd_t mqdes,
95 const char *msg_ptr,
96 size_t msg_len,
97 unsigned int msg_prio,
98 const struct timespec *abstime,
99 Thread_queue_Enqueue_callout enqueue_callout
100);
101
102static inline POSIX_Message_queue_Control *
103 _POSIX_Message_queue_Allocate_unprotected( void )
104{
106 _Objects_Allocate_unprotected( &_POSIX_Message_queue_Information );
107}
108
115static inline void _POSIX_Message_queue_Free(
117)
118{
119 _Objects_Free( &_POSIX_Message_queue_Information, &the_mq->Object );
120}
121
122
123static inline POSIX_Message_queue_Control *_POSIX_Message_queue_Get(
124 Objects_Id id,
125 Thread_queue_Context *queue_context
126)
127{
128 _Thread_queue_Context_initialize( queue_context );
130 id,
131 &queue_context->Lock_context.Lock_context,
133 );
134}
135
136/*
137 * @brief POSIX Message Queue Convert Message Priority to Score
138 *
139 * This method converts a POSIX message priority to the priorities used
140 * by the Score.
141 */
143 _POSIX_Message_queue_Priority_to_core(
144 unsigned int priority
145)
146{
147 return (CORE_message_queue_Submit_types) priority * -1;
148}
149
150
151/*
152 * @brief POSIX Message Queue Convert Message Priority from Score
153 *
154 * This method converts a POSIX message priority from the priorities used
155 * by the Score.
156 */
157static inline unsigned int _POSIX_Message_queue_Priority_from_core(
159)
160{
161 /* absolute value without a library dependency */
162 return (unsigned int) ((priority >= 0) ? priority : -priority);
163}
164
168static inline void _POSIX_Message_queue_Namespace_remove (
170)
171{
174 &the_mq->Object
175 );
176}
177
178static inline POSIX_Message_queue_Control *
179_POSIX_Message_queue_Get_by_name(
180 const char *name,
181 size_t *name_length_p,
182 Objects_Get_by_name_error *error
183)
184{
187 name,
188 name_length_p,
189 error
190 );
191}
192
193#ifdef __cplusplus
194}
195#endif
196
197#endif
198/* end of include file */
This header file provides interfaces of the Message Queue Handler which are used by the implementatio...
Objects_Information _POSIX_Message_queue_Information
The POSIX Message Queue objects information.
int CORE_message_queue_Submit_types
The modes in which a message may be submitted to a message queue.
Definition: coremsgimpl.h:87
Objects_Control * _Objects_Get_by_name(const Objects_Information *information, const char *name, size_t *name_length_p, Objects_Get_by_name_error *error)
Gets an object control block identified by its name.
Definition: objectnametoidstring.c:46
uint32_t Objects_Id
Definition: object.h:101
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:43
void _Objects_Namespace_remove_string(const Objects_Information *information, Objects_Control *the_object)
Removes object with a string name from its namespace.
Definition: objectnamespaceremove.c:45
void(* Thread_queue_Enqueue_callout)(Thread_queue_Queue *queue, Thread_Control *the_thread, struct Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
Thread queue enqueue callout.
Definition: threadq.h:90
void _POSIX_Message_queue_Delete(POSIX_Message_queue_Control *the_mq, Thread_queue_Context *queue_context)
Delete a POSIX Message Queue.
Definition: mqueuedeletesupp.c:42
int _POSIX_Message_queue_Send_support(mqd_t mqdes, const char *msg_ptr, size_t msg_len, unsigned int msg_prio, const struct timespec *abstime, Thread_queue_Enqueue_callout enqueue_callout)
POSIX Message Queue Send Support.
Definition: mqueuesendsupp.c:57
This header file provides interfaces used by the POSIX API implementation.
POSIX Message Queues Private Private Support.
This header file defines macros to set errno and return minus one.
Definition: mqueue.h:76
Thread queue context for the thread queue methods.
Definition: threadq.h:216
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition: threadq.h:221
ISR_lock_Context Lock_context
Definition: threadq.h:148
This header file provides interfaces of the Thread Queue Handler which are only used by the implement...
