RTEMS 6.1-rc1
mpc55xx-config.h
2
11/*
12 * Copyright (C) 2008, 2012 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H
37#define LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H
38
39#include <stddef.h>
40
42
43#include <bsp/start.h>
44
45#include <mpc55xx/regs.h>
46#include <mpc55xx/regs-mmu.h>
47#include <mpc55xx/siu.h>
48
49#ifdef __cplusplus
50extern "C" {
51#endif /* __cplusplus */
52
53typedef struct {
54 uint32_t index : 10;
55 uint32_t count : 10;
56 uint32_t output : 1;
57 union SIU_PCR_tag pcr;
59
60extern BSP_START_DATA_SECTION const mpc55xx_siu_pcr_config
61 mpc55xx_start_config_siu_pcr [];
62
63extern BSP_START_DATA_SECTION const size_t
64 mpc55xx_start_config_siu_pcr_count [];
65
66extern BSP_START_DATA_SECTION const struct
67 MMU_tag mpc55xx_start_config_mmu_early [];
68
69extern BSP_START_DATA_SECTION const size_t
70 mpc55xx_start_config_mmu_early_count [];
71
72extern BSP_START_DATA_SECTION const struct
73 MMU_tag mpc55xx_start_config_mmu [];
74
75extern BSP_START_DATA_SECTION const size_t
76 mpc55xx_start_config_mmu_count [];
77
78#ifdef MPC55XX_HAS_FMPLL
79 typedef struct {
80 union FMPLL_SYNCR_tag syncr_tmp;
81 union FMPLL_SYNCR_tag syncr_final;
82 } mpc55xx_clock_config;
83#endif
84
85#ifdef MPC55XX_HAS_FMPLL_ENHANCED
86 typedef struct {
87 union FMPLL_ESYNCR2_tag esyncr2_tmp;
88 union FMPLL_ESYNCR2_tag esyncr2_final;
89 union FMPLL_ESYNCR1_tag esyncr1_final;
90 } mpc55xx_clock_config;
91#endif
92
93#ifdef MPC55XX_HAS_MODE_CONTROL
94 typedef struct {
95 struct {
98 } fmpll [2];
100 CGM_OCDS_SC_32B_tag ocds_sc;
101 CGM_SC_DC0_3_32B_tag sc_dc0_3;
102 CGM_AUXCLK_tag auxclk [5];
103 } mpc55xx_clock_config;
104#endif
105
106extern BSP_START_DATA_SECTION const mpc55xx_clock_config
107 mpc55xx_start_config_clock [];
108
109#ifdef MPC55XX_HAS_EBI
110 typedef struct {
111 union EBI_MCR_tag ebi_mcr;
112 uint32_t siu_eccr_ebdf;
113 } mpc55xx_ebi_config;
114
115 extern BSP_START_DATA_SECTION const mpc55xx_ebi_config
116 mpc55xx_start_config_ebi [];
117
118 extern BSP_START_DATA_SECTION const size_t
119 mpc55xx_start_config_ebi_count [];
120
121 extern BSP_START_DATA_SECTION const struct EBI_CS_tag
122 mpc55xx_start_config_ebi_cs [];
123
124 extern BSP_START_DATA_SECTION const size_t
125 mpc55xx_start_config_ebi_cs_count [];
126
127 extern BSP_START_DATA_SECTION const struct EBI_CAL_CS_tag
128 mpc55xx_start_config_ebi_cal_cs [];
129
130 extern BSP_START_DATA_SECTION const size_t
131 mpc55xx_start_config_ebi_cal_cs_count [];
132#endif
133
147void mpc55xx_start_prologue(void);
148
149void mpc55xx_start_early(void);
150
151void mpc55xx_start_flash(void);
152
153void mpc55xx_start_cache(void);
154
155void mpc55xx_start_clock(void);
156
157void mpc55xx_start_watchdog(void);
158
159void mpc55xx_start_mmu_apply_config(const struct MMU_tag *config, size_t count);
160
161uint32_t mpc55xx_get_system_clock(void);
162
163LINKER_SYMBOL(bsp_ram_start)
164LINKER_SYMBOL(bsp_ram_end)
165LINKER_SYMBOL(bsp_ram_size)
166
167LINKER_SYMBOL(bsp_ram_1_start)
168LINKER_SYMBOL(bsp_ram_1_end)
169LINKER_SYMBOL(bsp_ram_1_size)
170
171LINKER_SYMBOL(bsp_rom_start)
172LINKER_SYMBOL(bsp_rom_end)
173LINKER_SYMBOL(bsp_rom_size)
174
175#ifdef MPC55XX_BOOTFLAGS
176 extern uint32_t mpc55xx_bootflag_0 [];
177#endif
178
179#ifdef __cplusplus
180}
181#endif /* __cplusplus */
182
183#endif /* LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H */
Start prologue.
Definition: start-prologue.c:38
General purpose assembler macros, linker command file support and some inline functions for direct re...
Register definitions for the MPC55xx and MPC56xx microcontroller family.
System Integration Unit Access (SIU).
Definition: fsl-mpc564xL.h:4910
Definition: fsl-mpc551x.h:473
Definition: fsl-mpc551x.h:441
Definition: regs-mmu.h:60
Definition: deflate.c:114
Definition: mpc55xx-config.h:53
Definition: fsl-mpc564xL.h:4828
Definition: fsl-mpc564xL.h:4817
Definition: fsl-mpc564xL.h:4853
Definition: fsl-mpc564xL.h:4657
Definition: fsl-mpc564xL.h:4678
Definition: fsl-mpc564xL.h:960
