RTEMS
6.1-rc1
score
cpu
moxie
include
score
moxie.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
7
8
* This file contains information pertaining to the Moxie processor.
9
10
* COPYRIGHT (c) 2011, 2013
11
* Anthony Green
12
13
* Based on code with the following copyright...
14
* COPYRIGHT (c) 1989-1999, 2010.
15
* On-Line Applications Research Corporation (OAR).
16
17
18
* modification, are permitted provided that the following conditions
19
* are met:
20
* 1. Redistributions of source code must retain the above copyright
21
* notice, this list of conditions and the following disclaimer.
22
* 2. Redistributions in binary form must reproduce the above copyright
23
* notice, this list of conditions and the following disclaimer in the
24
* documentation and/or other materials provided with the distribution.
25
26
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36
* POSSIBILITY OF SUCH DAMAGE.
37
38
39
#ifndef _RTEMS_SCORE_MOXIE_H
40
#define _RTEMS_SCORE_MOXIE_H
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
46
47
* This file contains the information required to build
48
* RTEMS for a particular member of the "moxie"
49
* family when executing in protected mode. It does
50
* this by setting variables to indicate which implementation
51
* dependent features are present in a particular member
52
* of the family.
53
54
55
#define CPU_NAME "Moxie"
56
#define CPU_MODEL_NAME "MoxieLite"
57
58
#ifdef __cplusplus
59
60
#endif
61
62
#endif
