RTEMS 6.1-rc1
regs.h File Reference
Standard MIPS register names. More...
#define PHYS_TO_K1(a)   ((unsigned)(a) | K1BASE)
Standard MIPS register names:
#define zero   $0
#define z0   $0
#define v0   $2
#define v1   $3
#define a0   $4
#define a1   $5
#define a2   $6
#define a3   $7
#define t0   $8
#define t1   $9
#define t2   $10
#define t3   $11
#define t4   $12
#define t5   $13
#define t6   $14
#define t7   $15
#define s0   $16
#define s1   $17
#define s2   $18
#define s3   $19
#define s4   $20
#define s5   $21
#define s6   $22
#define s7   $23
#define t8   $24
#define t9   $25
#define k0   $26
 kernel private register 0 *‍/
#define k1   $27
 kernel private register 1 *‍/
#define gp   $28
 global data pointer *‍/
#define sp   $29
 stack-pointer *‍/
#define fp   $30
 frame-pointer *‍/
#define ra   $31
 return address *‍/
#define pc   $pc
 pc, used on mips16 *‍/
#define fp0   $f0
#define fp1   $f1
Useful memory constants:
#define K0BASE   0x80000000
#define K1BASE   0xA0000000
Standard Co-Processor 0 register numbers:
#define C0_COUNT   $9
 Count Register *‍/.
#define C0_SR   $12
 Status Register *‍/.
#define C0_CAUSE   $13
 last exception description *‍/
#define C0_EPC   $14
 Exception error address *‍/.
#define C0_CONFIG   $16
 CPU configuration *‍/.
Standard Status Register bitmasks:
#define SR_CU1   0x20000000
 Mark CP1 as usable *‍/.
#define SR_FR   0x04000000
 Enable MIPS III FP registers *‍/.
#define SR_BEV   0x00400000
 Controls location of exception vectors *‍/.
#define SR_PE   0x00100000
 Mark soft reset (clear parity error) *‍/.
#define SR_KX   0x00000080
 Kernel extended addressing enabled *‍/.
#define SR_SX   0x00000040
 Supervisor extended addressing enabled *‍/.
#define SR_UX   0x00000020
 User extended addressing enabled *‍/.
Standard (R4000) cache operations.
Taken from "MIPS R4000 Microprocessor User's Manual" 2nd edition:
#define CACHE_I   (0)
 primary instruction *‍/
#define CACHE_D   (1)
 primary data *‍/
#define CACHE_SI   (2)
 secondary instruction *‍/
#define CACHE_SD   (3)
 secondary data (or combined instruction/data) *‍/
#define INDEX_INVALIDATE   (0)
 also encodes WRITEBACK if CACHE_D or CACHE_SD *‍/
#define INDEX_LOAD_TAG   (1)
#define INDEX_STORE_TAG   (2)
#define CREATE_DIRTY_EXCLUSIVE   (3)
 CACHE_D and CACHE_SD only *‍/.
#define HIT_INVALIDATE   (4)
#define CACHE_FILL   (5)
 CACHE_I only *‍/.
#define HIT_WRITEBACK_INVALIDATE   (5)
#define HIT_WRITEBACK   (6)
 CACHE_I, CACHE_D and CACHE_SD only *‍/.
#define HIT_SET_VIRTUAL   (7)
 CACHE_SI and CACHE_SD only *‍/.
#define BUILD_CACHE_OP(o, c)   (((o) << 2) | (c))
Individual cache operations:
#define INDEX_INVALIDATE_I   BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_I)
#define INDEX_WRITEBACK_INVALIDATE_D   BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_D)
#define INDEX_INVALIDATE_SI   BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SI)
#define INDEX_WRITEBACK_INVALIDATE_SD   BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SD)
#define INDEX_LOAD_TAG_I   BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_I)
#define INDEX_LOAD_TAG_D   BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_D)
#define INDEX_LOAD_TAG_SI   BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SI)
#define INDEX_LOAD_TAG_SD   BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SD)
#define INDEX_STORE_TAG_I   BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_I)
#define INDEX_STORE_TAG_D   BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_D)
#define INDEX_STORE_TAG_SI   BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SI)
#define INDEX_STORE_TAG_SD   BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SD)
#define CREATE_DIRTY_EXCLUSIVE_D   BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_D)
#define CREATE_DIRTY_EXCLUSIVE_SD   BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_SD)
#define HIT_INVALIDATE_I   BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_I)
#define HIT_INVALIDATE_D   BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_D)
#define HIT_INVALIDATE_SI   BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SI)
#define HIT_INVALIDATE_SD   BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SD)
#define CACHE_FILL_I   BUILD_CACHE_OP(CACHE_FILL,CACHE_I)
#define HIT_WRITEBACK_INVALIDATE_D   BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_D)
#define HIT_WRITEBACK_INVALIDATE_SD   BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_SD)
#define HIT_WRITEBACK_I   BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_I)
#define HIT_WRITEBACK_D   BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_D)
#define HIT_WRITEBACK_SD   BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_SD)
#define HIT_SET_VIRTUAL_SI   BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SI)
#define HIT_SET_VIRTUAL_SD   BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SD)
