RTEMS 6.1-rc1
#include <bsp.h>
#include <bsp/irq.h>
#include <rtems/clockdrv.h>
#include "clock.h"
#define | EXT_INT1 0x800 /* external interrupt 5 */ |
#define | CLOCK_VECTOR_MASK EXT_INT1 |
#define | CLOCK_VECTOR MIPS_INTERRUPT_BASE + 0x3 |
rtems_isr | USC_isr (void *unused) |
void | reset_wdt (void) |
void | enable_wdi (void) |
void | init_hbt (void) |
void | enable_hbi (void) |
void | disable_hbi (void) |
rtems_isr | Clock_isr (rtems_vector_number vector) |
rtems_isr | User_Clock_isr (rtems_vector_number vector) |
void | Install_clock (rtems_isr_entry clock_isr) |
void | _Clock_Initialize (void) |
Initialize the clock driver. | |
uint32_t | bsp_clicks_per_microsecond |
volatile uint32_t | Clock_driver_ticks |
Count of clock driver ticks since system boot or last overflow. More... | |
uint32_t | Clock_isrs |
rtems_isr_entry | Old_ticker |
This file contains the clock driver initialization for the Hurricane BSP.
