RTEMS 6.1-rc1
md5.h
1/*
2 ***********************************************************************
3 ** md5.h -- header file for implementation of MD5 **
4 ** RSA Data Security, Inc. MD5 Message-Digest Algorithm **
5 ** Created: 2/17/90 RLR **
6 ** Revised: 12/27/90 SRD,AJ,BSK,JT Reference C version **
7 ** Revised (for MD5): RLR 4/27/91 **
8 ** -- G modified to have y&~z instead of y&z **
9 ** -- FF, GG, HH modified to add in last register done **
10 ** -- Access pattern: round 2 works mod 5, round 3 works mod 3 **
11 ** -- distinct additive constant for each step **
12 ** -- round 4 added, working mod 7 **
13 ***********************************************************************
14 */
15
16/*
17 ***********************************************************************
18 ** Copyright (C) 1990, RSA Data Security, Inc. All rights reserved. **
19 ** **
20 ** License to copy and use this software is granted provided that **
21 ** it is identified as the "RSA Data Security, Inc. MD5 Message- **
22 ** Digest Algorithm" in all material mentioning or referencing this **
23 ** software or this function. **
24 ** **
25 ** License is also granted to make and use derivative works **
26 ** provided that such works are identified as "derived from the RSA **
27 ** Data Security, Inc. MD5 Message-Digest Algorithm" in all **
28 ** material mentioning or referencing the derived work. **
29 ** **
30 ** RSA Data Security, Inc. makes no representations concerning **
31 ** either the merchantability of this software or the suitability **
32 ** of this software for any particular purpose. It is provided "as **
33 ** is" without express or implied warranty of any kind. **
34 ** **
35 ** These notices must be retained in any copies of any part of this **
36 ** documentation and/or software. **
37 ***********************************************************************
38 */
39
40#ifndef __MD5_INCLUDE__
41
42#include <stdint.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
48/* typedef a 32-bit type */
49typedef uint32_t UINT4;
50
51#define MD5_BLOCK_LENGTH 64
52#define MD5_DIGEST_LENGTH 16
53
54/* Data structure for MD5 (Message-Digest) computation */
55typedef struct {
56 UINT4 i[2]; /* number of _bits_ handled mod 2^64 */
57 UINT4 buf[4]; /* scratch buffer */
58 unsigned char in[64]; /* input buffer */
59 unsigned char digest[16]; /* actual digest after MD5Final call */
60} MD5_CTX;
61
62void MD5Init (MD5_CTX *);
63void MD5Update (MD5_CTX *, const void *, unsigned int);
64void MD5Final (unsigned char [16], MD5_CTX *);
65
66#ifdef __cplusplus
67}
68#endif /* __cplusplus */
69
70#define __MD5_INCLUDE__
71#endif /* __MD5_INCLUDE__ */
Definition: md5.h:55
