enum | MCan_IdType { CAN_STD_ID = 0
, CAN_EXT_ID = 1
enum | MCan_DlcType {
CAN_DLC_0 = 0
, CAN_DLC_1 = 1
, CAN_DLC_2 = 2
, CAN_DLC_3 = 3
CAN_DLC_4 = 4
, CAN_DLC_5 = 5
, CAN_DLC_6 = 6
, CAN_DLC_7 = 7
CAN_DLC_8 = 8
, CAN_DLC_12 = 9
, CAN_DLC_16 = 10
, CAN_DLC_20 = 11
CAN_DLC_24 = 12
, CAN_DLC_32 = 13
, CAN_DLC_48 = 14
, CAN_DLC_64 = 15
enum | MCan_FifoType { CAN_FIFO_0 = 0
, CAN_FIFO_1 = 1
enum | MCan_IntrLineType { CAN_INTR_LINE_0 = 0
, CAN_INTR_LINE_1 = 1
__STATIC_INLINE uint32_t | MCAN_IsTxComplete (const MCan_ConfigType *mcanConfig) |
__STATIC_INLINE void | MCAN_ClearTxComplete (const MCan_ConfigType *mcanConfig) |
__STATIC_INLINE uint32_t | MCAN_IsMessageStoredToRxDedBuffer (const MCan_ConfigType *mcanConfig) |
__STATIC_INLINE void | MCAN_ClearMessageStoredToRxBuffer (const MCan_ConfigType *mcanConfig) |
__STATIC_INLINE uint32_t | MCAN_IsMessageStoredToRxFifo0 (const MCan_ConfigType *mcanConfig) |
__STATIC_INLINE void | MCAN_ClearMessageStoredToRxFifo0 (const MCan_ConfigType *mcanConfig) |
__STATIC_INLINE uint32_t | MCAN_IsMessageStoredToRxFifo1 (const MCan_ConfigType *mcanConfig) |
__STATIC_INLINE void | MCAN_ClearMessageStoredToRxFifo1 (const MCan_ConfigType *mcanConfig) |
void | MCAN_Init (const MCan_ConfigType *mcanConfig) |
| Initializes the MCAN hardware for giving peripheral. Default: Mixed mode TX Buffer + FIFO. More...
void | MCAN_InitFdEnable (const MCan_ConfigType *mcanConfig) |
| Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More...
void | MCAN_InitFdBitRateSwitchEnable (const MCan_ConfigType *mcanConfig) |
| Enables a FUTURE switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More...
void | MCAN_InitTxQueue (const MCan_ConfigType *mcanConfig) |
| Initializes MCAN queue for TX INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More...
void | MCAN_InitLoopback (const MCan_ConfigType *mcanConfig) |
| Initializes the MCAN in loop back mode. INIT must be set - so this should be called between MCAN_Init() and MCAN_Enable() More...
void | MCAN_Enable (const MCan_ConfigType *mcanConfig) |
| Enable MCAN peripheral. INIT must be set - so this should be called between MCAN_Init() More...
void | MCAN_RequestIso11898_1 (const MCan_ConfigType *mcanConfig) |
| Requests switch to Iso11898-1 (standard / classic) mode (tx & rx payloads up to 8 bytes). More...
void | MCAN_RequestFd (const MCan_ConfigType *mcanConfig) |
| Requests switch to FD mode (tx & rx payloads up to 64 bytes) but transmits WITHOUT bit rate switching. requested mode should have been enabled at initialization. More...
void | MCAN_RequestFdBitRateSwitch (const MCan_ConfigType *mcanConfig) |
| Request switch to FD mode (tx & rx payloads up to 64 bytes) and transmits WITH bit rate switching. requested mode should have been enabled at initialization. More...
void | MCAN_LoopbackOn (const MCan_ConfigType *mcanConfig) |
| Switch on loop back mode. TEST must be set in MCAN_CCCR - e.g. by a prior call to MCAN_InitLoopback() More...
void | MCAN_LoopbackOff (const MCan_ConfigType *mcanConfig) |
| Switch off loop back mode. More...
void | MCAN_IEnableMessageStoredToRxDedBuffer (const MCan_ConfigType *mcanConfig, MCan_IntrLineType line) |
| Enable message line and message stored to Dedicated Receive Buffer Interrupt Line. More...
uint8_t * | MCAN_ConfigTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, uint32_t id, MCan_IdType idType, MCan_DlcType dlc) |
| Configures a Dedicated TX Buffer. More...
void | MCAN_SendTxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer) |
| Send Tx buffer. More...
uint32_t | MCAN_AddToTxFifoQ (const MCan_ConfigType *mcanConfig, uint32_t id, MCan_IdType idType, MCan_DlcType dlc, uint8_t *data) |
| Adds Message to TX Fifo / Queue. More...
uint8_t | MCAN_IsBufferTxd (const MCan_ConfigType *mcanConfig, uint8_t buffer) |
| Check if data transmitted from buffer/fifo/queue. More...
void | MCAN_ConfigRxBufferFilter (const MCan_ConfigType *mcanConfig, uint32_t buffer, uint32_t filter, uint32_t id, MCan_IdType idType) |
| Configure RX Buffer Filter ID must match exactly for a RX Buffer Filter. More...
void | MCAN_ConfigRxClassicFilter (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, uint8_t filter, uint32_t id, MCan_IdType idType, uint32_t mask) |
| Configure Classic Filter Classic Filters direct accepted messages to a FIFO & include both a ID and a ID mask. More...
uint8_t | MCAN_IsNewDataInRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer) |
| check if data received into buffer More...
void | MCAN_GetRxDedBuffer (const MCan_ConfigType *mcanConfig, uint8_t buffer, Mailbox64Type *pRxMailbox) |
| Get Rx buffer. More...
uint32_t | MCAN_GetRxFifoBuffer (const MCan_ConfigType *mcanConfig, MCan_FifoType fifo, Mailbox64Type *pRxMailbox) |
| Get from the receive FIFO and place in a application mailbox. More...
Purpose
Interface for configuring and using Timer Counter (TC) peripherals.
Usage
- Optionally, use TC_FindMckDivisor() to let the program find the best TCCLKS field value automatically.
- Configure a Timer Counter in the desired mode using TC_Configure().
- Start or stop the timer clock using TC_Start() and TC_Stop().
